    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.2k Views 41 Watching
      mwm5053
      Downloaded new ver. and still get empty dialogue boxes.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • eneroth3E
        eneroth3
        Odd 😲 . What OS version is it? Do you know if it's older or newer than Oxer's?
        My website: http://julia-christina-eneroth.se/
          Aerilius
          I remember there was the set_html issue (although it was reported not to happen anymore). Is that a possible cause?
          • OxerO
            Oxer
            I have the last version of OSX 10.9.4 & Safari 7.0.5, updated yesterday and for me all work fine.
              mwm5053
              Currently using a computer with 10.7.5 Lion & Safari 6.1.4 which is latest for Lion I have a Macbook Pro with 10.9.4 but don't have access to it right now.
              2011 iMac
              V2 Twilight
              • deaneauD
                deaneau
                _2014.07.02_14h37m22s_005_00836.wmv
                now i have my first truck test finished.
                  Cool but seems wheels don't rotate! 😉
                    All works fine but this box is a little bit smaller!
                    (and French texts are full inside)
                      French Interface 😄
                      fr.l10n linked
                      fr.zip
                      • deaneauD
                        deaneau
                        French Interface 😄
                        fr.l10n linked
                        Pilou
                        look inside your language file. set the punctuation mark at end of the phrase. i have had this forgotten,too.
                        dean
                        • deaneauD
                          deaneau
                          [attachment=1:1ht2tazh]<!-- ia1 -->box.jpg<!-- ia1 -->[/attachment:1ht2tazh]
                          close sketchup
                          delete the entry
                          WebDialog_ene_railroad_drive_train
                          in the registry
                          and start sketchup again.
                          when this will not solve your problem than change the hight etc in the registry.
                          [attachment=0:1ht2tazh]<!-- ia0 -->Registrierungs-Editor_2014.07.02_18h08m14s_008_00839.jpg<!-- ia0 -->[/attachment:1ht2tazh]
                          dean
                          • deaneauD
                            deaneau
                            ok the wheel will not rotate however for the first test is it ok
                              It's not a little dangerous for the following ?
                              Of all phrases ? There are no point in certain original phrases! 😲
                              • deaneauD
                                deaneau
                                no not at all. look by your self 😉 i could write the line numbers, if you use notpad++
                                dangerous? not realy. the registry isn´t saved in the plugin, it is saved loacaly on your pc. i believe you know this. eneroth have write this to me, to solve this.
                                • eneroth3E
                                  eneroth3
                                  Dean: There's no need to make those wheel rotate since they are completely round without anything else in them. Hide the hidden geometry and endpoints and no one will see the difference. I've only made the wheel with wheel spokes in my own rolling stocks rotate. 😉
                                  I think it's an error with javascript not being executed from dialog.load_modal. According to the screenshot some pages ago the content's isn't shown in the Add Track dialog. When the dialog is created the model selection should determine what tab is opened (if no track is selected user probably want to create one from scratch, if one is selected new tracks based on the selection will be suggested). According to the additional screenshots the other dialogs works fine.
                                  Some should have a period, some a question mark, some a colon, some parenthesis, some have capital letters at the start of each word and 2 should even start with a lower case letter since it's within a sentence spanning several text entries. Look at the text in its context when translating and do as the original string is done.
                                  • eneroth3E
                                    eneroth3
                                    Btw, nice truck Dean!
                                    • eneroth3E
                                      eneroth3
                                      French Interface Updated 😄
                                      [attachment=1:u0nh033n]<!-- ia1 -->fr1.zip<!-- ia1 -->[/attachment:u0nh033n]
                                      I'll look at it! 👍
                                      is missing Down menu "Type or track", "Type of Signal" ...
                                      I must refind the original file
                                      What does that mean in English?
                                        is missing Pop UP menu "Type or track", "Type of Signal" ...
                                        I must refind the original file if existing multi language?
                                        fr1.zip
                                          I don't find these texts...
                                          And new update linked!
                                          fr2.zip
                                          • eneroth3E
                                            eneroth3
                                            [attachment=1:6fu5hukj]<!-- ia1 -->train11.jpg<!-- ia1 -->[/attachment:6fu5hukj]
                                            I've said a long long time ago that those wouldn't be updated since it's a part of the content that may be user created, not a part of the system. That was one of the reason I said there probably wouldn't be translation support 😒 .
                                            Also after spending quite some time searching (thatI could have spend coding) it seems like the correct translation (the one consistent to how the word is used in this context) of Cancel is Annuler, not Abandonner. Please make sure the translation is correct. Otherwise it's more harm than help.
                                            Edit: the quote from page 4
                                            @eneroth3 said:
                                            The work of manually translating would be lost in some week or so. Unless the text strings are separated from the code there's not really any idea doing it. %(red)[However I'm not really sure of what to do since user created content (including track types shipped with the extension) would just be in the user's language unless the user translates it themselves to all languages.
                                            Randomly mixed languages is just annoying and one of the reasons I really hate it when websites and softwares tries to make Swedish translations.]
                                            • 18
                                            • 19
                                            • 8 / 19
