    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 145.9k Views 41 Watching
    • deaneauD Offline
      deaneau
      All works fine but this box is a little bit smaller!
      (and French texts are full inside)
      [attachment=1:1ht2tazh]<!-- ia1 -->box.jpg<!-- ia1 -->[/attachment:1ht2tazh]
      close sketchup
      delete the entry
      WebDialog_ene_railroad_drive_train
      in the registry
      and start sketchup again.
      when this will not solve your problem than change the hight etc in the registry.
      [attachment=0:1ht2tazh]<!-- ia0 -->Registrierungs-Editor_2014.07.02_18h08m14s_008_00839.jpg<!-- ia0 -->[/attachment:1ht2tazh]
      dean
      • deaneauD Offline
        deaneau
        ok the wheel will not rotate however for the first test is it ok
          It's not a little dangerous for the following ?
          look inside your language file. set the punctuation mark at end of the phrase.
          Of all phrases ? There are no point in certain original phrases! ๐Ÿ˜ฒ
          • deaneauD Offline
            deaneau
            no not at all. look by your self ๐Ÿ˜‰ i could write the line numbers, if you use notpad++
            dangerous? not realy. the registry isnยดt saved in the plugin, it is saved loacaly on your pc. i believe you know this. eneroth have write this to me, to solve this.
            • eneroth3E Offline
              eneroth3
              Dean: There's no need to make those wheel rotate since they are completely round without anything else in them. Hide the hidden geometry and endpoints and no one will see the difference. I've only made the wheel with wheel spokes in my own rolling stocks rotate. ๐Ÿ˜‰
              @aerilius said:
              I remember there was the set_html issue (although it was reported not to happen anymore). Is that a possible cause?
              I think it's an error with javascript not being executed from dialog.load_modal. According to the screenshot some pages ago the content's isn't shown in the Add Track dialog. When the dialog is created the model selection should determine what tab is opened (if no track is selected user probably want to create one from scratch, if one is selected new tracks based on the selection will be suggested). According to the additional screenshots the other dialogs works fine.
              Some should have a period, some a question mark, some a colon, some parenthesis, some have capital letters at the start of each word and 2 should even start with a lower case letter since it's within a sentence spanning several text entries. Look at the text in its context when translating and do as the original string is done.
              My website: http://julia-christina-eneroth.se/
              • eneroth3E Offline
                eneroth3
                Btw, nice truck Dean!
                • eneroth3E Offline
                  eneroth3
                  French Interface Updated ๐Ÿ˜„
                  [attachment=1:u0nh033n]<!-- ia1 -->fr1.zip<!-- ia1 -->[/attachment:u0nh033n]
                  I'll look at it! ๐Ÿ‘
                  is missing Down menu "Type or track", "Type of Signal" ...
                  I must refind the original file
                  What does that mean in English?
                    is missing Pop UP menu "Type or track", "Type of Signal" ...
                    I must refind the original file if existing multi language?
                    fr1.zip
                      I don't find these texts...
                      And new update linked!
                      fr2.zip
                      • eneroth3E Offline
                        eneroth3
                        [attachment=1:6fu5hukj]<!-- ia1 -->train11.jpg<!-- ia1 -->[/attachment:6fu5hukj]
                        I've said a long long time ago that those wouldn't be updated since it's a part of the content that may be user created, not a part of the system. That was one of the reason I said there probably wouldn't be translation support ๐Ÿ˜’ .
                        Also after spending quite some time searching (thatI could have spend coding) it seems like the correct translation (the one consistent to how the word is used in this context) of Cancel is Annuler, not Abandonner. Please make sure the translation is correct. Otherwise it's more harm than help.
                        Edit: the quote from page 4
                        @eneroth3 said:
                        The work of manually translating would be lost in some week or so. Unless the text strings are separated from the code there's not really any idea doing it. %(red)[However I'm not really sure of what to do since user created content (including track types shipped with the extension) would just be in the user's language unless the user translates it themselves to all languages.
                        Randomly mixed languages is just annoying and one of the reasons I really hate it when websites and softwares tries to make Swedish translations.]
                        • deaneauD Offline
                          deaneau
                          [attachment=1:1h84akcy]<!-- ia1 -->train11.jpg<!-- ia1 -->[/attachment:1h84akcy]
                          pilou the entries in the drop down menue you canยดt change, this is a entries written by the user.
                          this will be the best idea, that all name of the objects, bridges, tunnel etc. is in english.
                          what do you want do if a russian or japanese people write all entries in the own language. nobody will understand this.
                          "..Type or track", "Type of Signal" ...
                          Type of Track. of not or
                          the best way is to download a notepad++
                          http://notepad-plus-plus.org/
                          and than ask for the line number to find text. other way is to search text.
                          nice night "mon vieux pote !" ๐Ÿ˜‰
                          Dean
                          • eneroth3E Offline
                            eneroth3
                            That's how it works with rolling stocks but I'm afraid track types are more complicated. Besides predefined strings such as bridge, tunnel etc the user must be able to add new words like arc, beam, low polygon or whatever describes that track type. I can't think of all possible terms and there can't be translations for them all because they are just too many.
                            However I can write in the documentation that this info should be in English so track types can be shared but it will still, as I've said long ago, be mixed languages.
                            • deaneauD Offline
                              deaneau
                              this is not my own i have downloaded in the 3dwarehouse for test only.
                              rotation problem. yes when the wheel is rounding. however i will learn to rotate the wheel. ๐Ÿ˜›
                              do you have this in your making off movie?
                              i hope so.
                              i hate mixed language, too. i dont need german translation. ok i have now written the translation file, however i donยดt use this.
                              why? if i publish a screenshot all other can read this text of windows and dialogues.
                              if i have an error and i publish this error in a german translation, nobody will understand this.
                              least common denominator (LCD) is english.
                              this would be difficult when pilou asking in french and eneroth answer in swedish ๐Ÿ˜„
                              Dean
                              • deaneauD Offline
                                deaneau
                                @ Pilou
                                if the english text begin with uppercase you must translate this in uppercase, too. look at your picture. i know in german is that the same. some words will written in lowercase. thats look better.
                                example:
                                Il fait mauvais temps.
                                It's foul weather today.
                                when the english text look like this
                                It's Foul Weather Today.
                                you must write
                                Il Fait Mauvais Temps.
                                Dean
                                p.s. i know this look terrible,
                                let eneroth smile and write this again
                                  Ok About the Pop UP Menu ๐Ÿ˜‰
                                  I will just add that to the Documentation ๐Ÿ˜‰
                                  About the number of lines : no problem I have them! (mรชme les lignes vides sont numรฉrotรฉes! ๐Ÿ˜‰
                                  About the Cancel : that is made ๐Ÿ˜„ (But synonym ๐Ÿ˜‰
                                  fr3.zip
                                  • deaneauD Offline
                                    deaneau
                                    even empty lines are numbered! <> mรชme les lignes vides sont numรฉrotรฉes
                                    yes you can translate the empty lines ,too ๐Ÿ˜„
                                      dtrarch
                                      Hi Eneroth
                                      Thanks so very much for your Railroad System for all to play with.
                                      I have just loved trains since I can remember.
                                      Here is one of the really great American Locomotives.
                                      Pulled freight in Colorado USA
                                      My model at home and C.B & Q. photo 1930.
                                      Owner: Chicago Burlington & Quincy
                                      Model: BLW 4-8-4 Built As:CBQ 5601 (4-8-4)
                                      Serial Number:61444
                                      Built: 9/1930
                                      Notes: blt 9/30, retired 5/61 sold for scrap
                                      Note:My model has a later boiler than in the photo.
                                      ๐Ÿ˜ž
                                      How sad to loose such an awesome machine.
                                      dtr
                                      • deaneauD Offline
                                        deaneau
                                        mother of all steam locos
                                        3D Warehouse
                                        (3dwarehouse.sketchup.com)
                                        https://3dwarehouse.sketchup.com/3dw/getpubliccontent?contentId=a83b837b-28b2-4487-a27e-2d585bfbf2fb
                                        • deaneauD Offline
                                          deaneau
                                          @dtrarch said:
                                          Hi Eneroth
                                          Serial Number:61444
                                          Built: 9/1930
                                          ๐Ÿ˜ž
                                          dtr
                                          wow cool steamlooco.
                                          could be if you setup this for eneroth railroad, this will be very high poly.
                                          EDIT: oops this is a model in HO gauge.
                                          my favorite american steamloco is the "BIG BOY"
                                          http://www.american-rails.com/images/Big_Boy_JP_Litho_Sm.jpg
                                          http://www.railart.co.uk/gallery/images/williamson7.jpg
                                          regards dean
                                          • ElibjrE Offline
                                            Elibjr
                                            Wow! After reading these posts, this is one of the most promising productive plugins I have seen for Sketchup since I started using the software in 2009. Keep up the good work and someone will complete a whole Hollywood movie using your plug-in (with many others). I won't be able to do anything with it for the next few weeks but, this could be packaged with Vali Architects Instant Site Grader Nui and Plusspec to do a complete city. Awesome! ๐Ÿ‘
                                            • 11
                                            • 18
                                            • 19
                                            • 9 / 19
