    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 111.6k Views 41 Watching
    • OxerO Offline
      Oxer
      Incredible work, all work fine on Mac & SU2014. πŸ‘ πŸ‘
        Cool new version! β˜€
        Let see if I will make better this time! πŸ˜„
        Translation of the text file multi language done! β˜€
        Must be inserted on the dialog boxes for verification!
        (because French text is some bigger than English )
        Tomorrow will be made. πŸ˜„
        • deaneauD Offline
          deaneau
          german language have longer words πŸ˜‰
          german language is ready
          dean
          • eneroth3E Offline
            eneroth3
            dean
            It already supports Spanish which has short words but a lot of them so I think it'll work πŸ˜‰
            My website: http://julia-christina-eneroth.se/
              mwm5053
              Downloaded new ver. and still get empty dialogue boxes.
              2011 iMac
              SU 2015 Pro, 2017 Make
              V2 Twilight
              macOS Sierra 10.12.5
              • eneroth3E Offline
                eneroth3
                Odd 😲 . What OS version is it? Do you know if it's older or newer than Oxer's?
                  Aerilius
                  I remember there was the set_html issue (although it was reported not to happen anymore). Is that a possible cause?
                  • OxerO Offline
                    Oxer
                    I have the last version of OSX 10.9.4 & Safari 7.0.5, updated yesterday and for me all work fine.
                      mwm5053
                      Currently using a computer with 10.7.5 Lion & Safari 6.1.4 which is latest for Lion I have a Macbook Pro with 10.9.4 but don't have access to it right now.
                      2011 iMac
                      V2 Twilight
                      • deaneauD Offline
                        deaneau
                        _2014.07.02_14h37m22s_005_00836.wmv
                        now i have my first truck test finished.
                          Cool but seems wheels don't rotate! πŸ˜‰
                            All works fine but this box is a little bit smaller!
                            (and French texts are full inside)
                              French Interface πŸ˜„
                              fr.l10n linked
                              fr.zip
                              • deaneauD Offline
                                deaneau
                                fr.l10n linked
                                Pilou
                                look inside your language file. set the punctuation mark at end of the phrase. i have had this forgotten,too.
                                dean
                                • deaneauD Offline
                                  deaneau
                                  [attachment=1:1ht2tazh]<!-- ia1 -->box.jpg<!-- ia1 -->[/attachment:1ht2tazh]
                                  close sketchup
                                  delete the entry
                                  WebDialog_ene_railroad_drive_train
                                  in the registry
                                  and start sketchup again.
                                  when this will not solve your problem than change the hight etc in the registry.
                                  [attachment=0:1ht2tazh]<!-- ia0 -->Registrierungs-Editor_2014.07.02_18h08m14s_008_00839.jpg<!-- ia0 -->[/attachment:1ht2tazh]
                                  dean
                                  • deaneauD Offline
                                    deaneau
                                    ok the wheel will not rotate however for the first test is it ok
                                      It's not a little dangerous for the following ?
                                      Of all phrases ? There are no point in certain original phrases! 😲
                                      • deaneauD Offline
                                        deaneau
                                        no not at all. look by your self πŸ˜‰ i could write the line numbers, if you use notpad++
                                        dangerous? not realy. the registry isnΒ΄t saved in the plugin, it is saved loacaly on your pc. i believe you know this. eneroth have write this to me, to solve this.
                                        • eneroth3E Offline
                                          eneroth3
                                          Dean: There's no need to make those wheel rotate since they are completely round without anything else in them. Hide the hidden geometry and endpoints and no one will see the difference. I've only made the wheel with wheel spokes in my own rolling stocks rotate. πŸ˜‰
                                          I think it's an error with javascript not being executed from dialog.load_modal. According to the screenshot some pages ago the content's isn't shown in the Add Track dialog. When the dialog is created the model selection should determine what tab is opened (if no track is selected user probably want to create one from scratch, if one is selected new tracks based on the selection will be suggested). According to the additional screenshots the other dialogs works fine.
                                          Some should have a period, some a question mark, some a colon, some parenthesis, some have capital letters at the start of each word and 2 should even start with a lower case letter since it's within a sentence spanning several text entries. Look at the text in its context when translating and do as the original string is done.
                                          • eneroth3E Offline
                                            eneroth3
                                            Btw, nice truck Dean!
                                            • 18
                                            • 19
                                            • 8 / 19
