    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.2k Views 41 Watching
      Cool new version! β˜€
      Let see if I will make better this time! πŸ˜„
      Translation of the text file multi language done! β˜€
      Must be inserted on the dialog boxes for verification!
      (because French text is some bigger than English )
      Tomorrow will be made. πŸ˜„
      • deaneauD
        deaneau
        german language have longer words πŸ˜‰
        german language is ready
        dean
        • eneroth3E
          eneroth3
          dean
          It already supports Spanish which has short words but a lot of them so I think it'll work πŸ˜‰
          My website: http://julia-christina-eneroth.se/
            mwm5053
            Downloaded new ver. and still get empty dialogue boxes.
            2011 iMac
            SU 2015 Pro, 2017 Make
            V2 Twilight
            macOS Sierra 10.12.5
            • eneroth3E
              eneroth3
              Odd 😲 . What OS version is it? Do you know if it's older or newer than Oxer's?
                Aerilius
                I remember there was the set_html issue (although it was reported not to happen anymore). Is that a possible cause?
                • OxerO
                  Oxer
                  I have the last version of OSX 10.9.4 & Safari 7.0.5, updated yesterday and for me all work fine.
                    mwm5053
                    Currently using a computer with 10.7.5 Lion & Safari 6.1.4 which is latest for Lion I have a Macbook Pro with 10.9.4 but don't have access to it right now.
                    2011 iMac
                    V2 Twilight
                    • deaneauD
                      deaneau
                      _2014.07.02_14h37m22s_005_00836.wmv
                      now i have my first truck test finished.
                        Cool but seems wheels don't rotate! πŸ˜‰
                          All works fine but this box is a little bit smaller!
                          (and French texts are full inside)
                            French Interface πŸ˜„
                            fr.l10n linked
                            fr.zip
                            • deaneauD
                              deaneau
                              fr.l10n linked
                              Pilou
                              look inside your language file. set the punctuation mark at end of the phrase. i have had this forgotten,too.
                              dean
                              • deaneauD
                                deaneau
                                [attachment=1:1ht2tazh]<!-- ia1 -->box.jpg<!-- ia1 -->[/attachment:1ht2tazh]
                                close sketchup
                                delete the entry
                                WebDialog_ene_railroad_drive_train
                                in the registry
                                and start sketchup again.
                                when this will not solve your problem than change the hight etc in the registry.
                                [attachment=0:1ht2tazh]<!-- ia0 -->Registrierungs-Editor_2014.07.02_18h08m14s_008_00839.jpg<!-- ia0 -->[/attachment:1ht2tazh]
                                dean
                                • deaneauD
                                  deaneau
                                  ok the wheel will not rotate however for the first test is it ok
                                    It's not a little dangerous for the following ?
                                    Of all phrases ? There are no point in certain original phrases! 😲
                                    • deaneauD
                                      deaneau
                                      no not at all. look by your self πŸ˜‰ i could write the line numbers, if you use notpad++
                                      dangerous? not realy. the registry isnΒ΄t saved in the plugin, it is saved loacaly on your pc. i believe you know this. eneroth have write this to me, to solve this.
                                      • eneroth3E
                                        eneroth3
                                        Dean: There's no need to make those wheel rotate since they are completely round without anything else in them. Hide the hidden geometry and endpoints and no one will see the difference. I've only made the wheel with wheel spokes in my own rolling stocks rotate. πŸ˜‰
                                        I think it's an error with javascript not being executed from dialog.load_modal. According to the screenshot some pages ago the content's isn't shown in the Add Track dialog. When the dialog is created the model selection should determine what tab is opened (if no track is selected user probably want to create one from scratch, if one is selected new tracks based on the selection will be suggested). According to the additional screenshots the other dialogs works fine.
                                        Some should have a period, some a question mark, some a colon, some parenthesis, some have capital letters at the start of each word and 2 should even start with a lower case letter since it's within a sentence spanning several text entries. Look at the text in its context when translating and do as the original string is done.
                                        • eneroth3E
                                          eneroth3
                                          Btw, nice truck Dean!
                                          • eneroth3E
                                            eneroth3
                                            French Interface Updated πŸ˜„
                                            [attachment=1:u0nh033n]<!-- ia1 -->fr1.zip<!-- ia1 -->[/attachment:u0nh033n]
                                            I'll look at it! πŸ‘
                                            is missing Down menu "Type or track", "Type of Signal" ...
                                            I must refind the original file
                                            What does that mean in English?
                                            • 18
                                            • 19
                                            • 8 / 19
