    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 168.4k Views 41 Watching
    • eneroth3E
      eneroth3
      Version 0.1.12 is now published! πŸ˜„
      The main new features are a better interface to save rolling stocks to library and support for translations (big thanks to Oxer for Spanish translation now shipped in the extension πŸ‘ ).
      Download
      The new interface for saving rolling stocks along with the improved documentation has made it easier to add rolling stocks to the library. Now rolling stocks can be saved from within any model instead of having to be alone. Images are also automatically generated now even if it's a bit buggy and a better image can be generated manually (more info in documentation). The new dialog for saving rolling stocks now suggests IDs for them so the user doesn't need to worry to much about that either.
      To save a rolling stocks to library, select it (after it's initialized) and run Ene_Railroad.ss_2_rs_library to open the dialog (graphical interface to open dialog is planned for a later version).
      The translation system allows for translated versions of all strings within the plugin itself. The documentation will however stay in English since it constantly changes.
      You can change between available languages in Plugins > Railroad > Change Language.
      To translate the plugin download the attached file, add the language name and your name at the top 2 lines. The syntax for the translation is "original string"="translated string". When adding the translation remember to look at the string in its context inside the plugin and be consistent with reoccurring terms such as track and rolling stock. Save the file as <language code>.l10n inside the folder "lang/" in the plugin's folder.
      If you want to I can include the translation in the next version πŸ˜„ .
      I hope to see pictures of people's own rolling stocks posted here now πŸ˜„ .
      template.txt
      My website: http://julia-christina-eneroth.se/
      • OxerO
        Oxer
        Incredible work, all work fine on Mac & SU2014. πŸ‘ πŸ‘
          Cool new version! β˜€
          Let see if I will make better this time! πŸ˜„
          Translation of the text file multi language done! β˜€
          Must be inserted on the dialog boxes for verification!
          (because French text is some bigger than English )
          Tomorrow will be made. πŸ˜„
          • deaneauD
            deaneau
            german language have longer words πŸ˜‰
            german language is ready
            dean
            • eneroth3E
              eneroth3
              dean
              It already supports Spanish which has short words but a lot of them so I think it'll work πŸ˜‰
                mwm5053
                Downloaded new ver. and still get empty dialogue boxes.
                2011 iMac
                SU 2015 Pro, 2017 Make
                V2 Twilight
                macOS Sierra 10.12.5
                • eneroth3E
                  eneroth3
                  Odd 😲 . What OS version is it? Do you know if it's older or newer than Oxer's?
                    Aerilius
                    I remember there was the set_html issue (although it was reported not to happen anymore). Is that a possible cause?
                    • OxerO
                      Oxer
                      I have the last version of OSX 10.9.4 & Safari 7.0.5, updated yesterday and for me all work fine.
                        mwm5053
                        Currently using a computer with 10.7.5 Lion & Safari 6.1.4 which is latest for Lion I have a Macbook Pro with 10.9.4 but don't have access to it right now.
                        2011 iMac
                        V2 Twilight
                        • deaneauD
                          deaneau
                          _2014.07.02_14h37m22s_005_00836.wmv
                          now i have my first truck test finished.
                            Cool but seems wheels don't rotate! πŸ˜‰
                              All works fine but this box is a little bit smaller!
                              (and French texts are full inside)
                                French Interface πŸ˜„
                                fr.l10n linked
                                fr.zip
                                • deaneauD
                                  deaneau
                                  fr.l10n linked
                                  Pilou
                                  look inside your language file. set the punctuation mark at end of the phrase. i have had this forgotten,too.
                                  dean
                                  • deaneauD
                                    deaneau
                                    [attachment=1:1ht2tazh]<!-- ia1 -->box.jpg<!-- ia1 -->[/attachment:1ht2tazh]
                                    close sketchup
                                    delete the entry
                                    WebDialog_ene_railroad_drive_train
                                    in the registry
                                    and start sketchup again.
                                    when this will not solve your problem than change the hight etc in the registry.
                                    [attachment=0:1ht2tazh]<!-- ia0 -->Registrierungs-Editor_2014.07.02_18h08m14s_008_00839.jpg<!-- ia0 -->[/attachment:1ht2tazh]
                                    dean
                                    • deaneauD
                                      deaneau
                                      ok the wheel will not rotate however for the first test is it ok
                                        It's not a little dangerous for the following ?
                                        Of all phrases ? There are no point in certain original phrases! 😲
                                        • deaneauD
                                          deaneau
                                          no not at all. look by your self πŸ˜‰ i could write the line numbers, if you use notpad++
                                          dangerous? not realy. the registry isnΒ΄t saved in the plugin, it is saved loacaly on your pc. i believe you know this. eneroth have write this to me, to solve this.
                                          • eneroth3E
                                            eneroth3
                                            Dean: There's no need to make those wheel rotate since they are completely round without anything else in them. Hide the hidden geometry and endpoints and no one will see the difference. I've only made the wheel with wheel spokes in my own rolling stocks rotate. πŸ˜‰
                                            I think it's an error with javascript not being executed from dialog.load_modal. According to the screenshot some pages ago the content's isn't shown in the Add Track dialog. When the dialog is created the model selection should determine what tab is opened (if no track is selected user probably want to create one from scratch, if one is selected new tracks based on the selection will be suggested). According to the additional screenshots the other dialogs works fine.
                                            Some should have a period, some a question mark, some a colon, some parenthesis, some have capital letters at the start of each word and 2 should even start with a lower case letter since it's within a sentence spanning several text entries. Look at the text in its context when translating and do as the original string is done.
                                            • 18
                                            • 19
                                            • 8 / 19
