    Hole through cavity walls
    17 Posts 8 Posters 2.2k Views 8 Watching
    • cottyC Offline
      cotty
      Fredo is working in this: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57873%26amp;start=1#p526758
      my SketchUp gallery
        caspajack
        Thanks Guys, it looks like Fredo is on the case, but I will have a look at your "hole in the wall" plugin sdmitch.
        I appreciate the replies.
          My 'Hole Punching Tool' also does multiple 'leaves' in the same context, and the punched-hole selects and moves with the cutting-component too... It will also punch holes into groups etc, BUT the paired-linking is more fraught!
          http://sketchucation.com/pluginstore?pln=HolePunchTool
          • fredo6F Offline
            VisuHole can cut holes though several groups and components. But it is far from being ready. At the moment, I am exploring algorithms to adjust hole directions on a curved surface, as shown in the video.
              A new hit for Hilti world! πŸ˜‰
              http://insider-language.de/wordpress/wp-content/uploads/2013/04/hilti-1.jpg
                pcmoor
                if the geometry is within same group, could use a DC
                opening (1).skp
                  caspajack
                  Your plugin look promising Fredo, but will it cut through two individula walls separated by a gap? As in the example shown by pcmoor above?
                  pcmoor not sure what you're showing me there, I'm not familiar with DC? Also the example you show doesn't cut through both walls. Please clarify if you would.
                  Thanks everyone, except pilou who is using the forum for advertising and should be banned!
                  • fredo6F Offline
                    VisuHole is designed to cut through the objects selected, regardless of whether they are connected or not. If all objects are enclosed in a top group or component, then selecting this top group / component will select all objects inside (VisuHole has anyway several options to adjust the selection)
                    So answer is Yes
                      caspajack
                      That will certainly do the trick, can't wait... when can we have it????
                        Can we wish the same but like Boolean Diff ?
                        So "Screw" and "Srew thread " inside the wall;)
                        • fredo6F Offline
                          This can be done.
                          Anything else?
                            caspajack
                            Any news on when you might release VisuHole Fredo?
                            Regards
                            Joe.
                            • fredo6F Offline
                              Unfortunately, I am not working on it at the moment.
                              And anyway, I still need some work to finish the algorithm and put a decent GUI. So not for this month I am afraid.
                              Here is the last addition, where you can now pick shapes from faces, groups and components in the model to use as a stencil for digging or carving holes.
                                dedmin
                                SketchUP is just a plugin for the Fredo's universe!
                                  caspajack
                                  I think you're right dedmin.
                                  No problem Fredo, it's looking better at every stage. WOrth waiting for I'm sure.
                                  Regards,
                                  Joe.
