    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 168.3k Views 41 Watching
    • eneroth3E
      eneroth3
      Can you give me an example and addresse page?
      For correction if necessary 😄
      I don't know if you changed the capital letter because now I can't find them but the Create Rolling stock page mentions an attribute called "rayon" that doesn't exist in the plugin. Also there are no headers in the text except for in a few random places so it's quite hard to see what text belongs to what.
      My website: http://julia-christina-eneroth.se/
        Effectivelly I had changed some capitals 😄
        yes it's all the difficulty of translation!
        What translate or not! 😄
        So imagine in the Ruby code Text! 😄
        "radius" and all few little things corrected
        This is very mysterious for me!
        Have you an example of that ? Or a Copy screen ?
        • eneroth3E
          eneroth3
          "Les pièces en mouvement" is a little bigegr than normal text and has the same color even though it is a second level header. "Toutes les pièces mécaniques" looks the same even though it's a third level header. "translation_circular" is also a third level header but it's white unlike all other text.
          • deaneauD
            deaneau
            is a translation of the plugin realy important?. ok the manual in other languages is ok.
            pilou i would understand your wish, if eneroth to have written the plugin in swedish.
            i think this is not the main problem.
            my native language is german, and i don´t ask about any translations.
            the common denominator is english i think.
            will you let play your kids with this plugin? 😉
            i must say in don´t missing german in this plugin.
            best regards to a wonderful france. i watching in ARTE(TV)any documentaions about france.
            dean from berlin
            p.s.
            here some text from mark twain about german language.
            (www.crossmyt.com)
            or here
            http://usa.usembassy.de/classroom/Mark%20Twain/Mark%20Twain%20Awful%20Broschuere.pdf
            german have very long words and if i see the plugin, the layout must be changed.
            • deaneauD
              deaneau
              Something that RailRoadsystem can do! ☀
              Just replace locomotive by planes! 😄
              pilou the same i have written to eneroth.
              not only plane you can use ships , too.
              oops my sailboat is flooding,
              ok i have find a life guard 😄
              • eneroth3E
                eneroth3
                If there is a translation it has to be 100% correct and not fool the user into problems with the plugin. However I don't see a very big need for it. Learning English, today's lingua franca, is a long term solution that is also very beneficial in other situations throughout life.
                • deaneauD
                  deaneau
                  translation is on part, the translator must understand the subject,too.
                  i need only a translation, if the subject will be very difficult to understand.
                  difficult for me is the way to setup the rolling stock like the flying scotman.
                  dean
                  • eneroth3E
                    eneroth3
                    dean
                    That's also the part hardest to translate because if anything is not 100% perfect it will go wrong and not work. I might some day look into the docs and try to make it easier to understand with more images, perhaps even videos of certain steps. Perhaps there will even be a graphical interface in the distant future to initialize the moving parts more easily.
                    • deaneauD
                      deaneau
                      yes, one movie or picture tell more than thousand words.
                        Some Titles corrections You are very strict! 😄
                        As the page text is some long, reader has forgotten the level of reading and me too! 😄
                        • OxerO
                          Oxer
                          Excuse for no reply before. All web dialogs work fine now on Mac 10.9.3 & SU2014, included "Insert Track".
                          One question, the Track Properties icon is off although you have selected a Track, you can to access to the Properties Track only by Contextual Menu.
                          To translate the web dialogs BGSketchup_Composants plugin have a file named Loacalization.rb that include all languages, I don't know the ruby code but perhaps this can be a solution to give support to translation.
                            With new version 1.11 on 2014 (previous version was fine)
                            Seems Connect Ends system from Selection between roads create rails! 😲
                            Does this normal ?
                            And Add a Rolling Stock adds an image and not a volume! 😮
                            • eneroth3E
                              eneroth3
                              No worry about not replying earlier:). It's good that the web dialogs work but I don't understand why it didn't for
                              mwm5053.
                              That's odd. Perhaps Mac doesn't run the Proc determining its state as often as Windows.
                              It's quite easy to just load strings in ruby from localized files but getting it into web dialogs that are saved as HTML documents is a bit tricker but there are solutions. However the names and description of track types would not b4e translated since that's custom often user created content.
                              • eneroth3E
                                eneroth3
                                Does this normal ?
                                So far default track is always used to connect other tracks. I really have no idea about the image though. Have you been renaming files in the rolling stock folder? Does it happen with other rolling stocks?
                                Edit: btw, the latest version is called 0.1.11, there will not be a 1.11[.someting] for a year or so.
                                • eneroth3E
                                  eneroth3
                                  @deaneau said:
                                  i have try connect, too. however if i try to change the properties nothing happend in 2013.
                                  Doesn't it work to open track properties and change track type after the track is connected?
                                  • deaneauD
                                    deaneau
                                    i have try connect, too. however if i try to change the properties nothing happend in 2013. than if i try to add road or track , nothing happend.
                                    i have close the file.
                                    if i open a new empty sketchupfile, i can´t set a track. i must restart sketchup.
                                    dean
                                    • deaneauD
                                      deaneau
                                      i have edit my text.
                                      yes. and i can´t add the track.
                                      when i open an new empty sketchup file i can´t set the track. i must restart sketchup.
                                      • eneroth3E
                                        eneroth3
                                        It's not about remembering but about understanding what text is under what header. "rotation" for instance is a sub header of "Les pièces en mouvement" which is a sub header of "Dessin du Matériel roulant". Without this relation the text loses it's meaning.
                                        I found some more errors. The path "r_stocks / " is wrong, there is no such folder. Also there is nothing called "Modifier les Textes" in the context menu of a rolling stock.
                                        • deaneauD
                                          deaneau
                                          @pilou****
                                          the idea to translate the manual is a good idea, however only if this doesn´t produce errors and misstakes.
                                          eneroth must invest more energy to correct your translations.
                                          this is not the right way.
                                          i would recommend to wait. could be, eneroth have a big change in the pipeline, than you must change all your text in the manual again and again etc..
                                          dean
                                            No problem that is named a re-reading 😉
                                            For the path ...i don't know ?
                                            "Change Texts" corrected 😄 But the French word was a synonym 😉
                                            Problem of the image against volume seems resolved by a mysterious reason! ☀
                                            (maybe conflict with another plugin...
                                            • 18
                                            • 19
                                            • 7 / 19
