    Looking for "Z" plugin
    extensions
    4 Posts 3 Posters 707 Views 3 Watching
    • maxhouserocksM Offline
      maxhouserocks
      I have used a plugin in the past that had a "Z" as the icon. Dont have it on new machine and cant find it. Any suggestions welcome.
      Basically, i just need to be able to select lines or vertices, hit the script command and enter what "z" coordinate i want the selection to move to.
      Looking for ANY and ALL scripts that will achieve that.
      thanks,
      bob
      Robert A. Christman
      http://rachristman.blogspot.com/
      • mitcorbM Offline
        mitcorb
        Hi.
        I see you have not had a reply. See if this is related to the plugin you used to have?
        http://sketchuptips.blogspot.com/
        I want to do a little more checking, so I may return.
        Edit:
        Well, I thought either thomthom or TIG had a plugin that repositioned a selection to a different z. I could not find it.
          My DropVerts http://sketchucation.com/pluginstore?pln=dropverts
          Does many things... including relocating selected vertices to a set Z ?
            maxhouserocks
            Beautiful! Thank you so much for your time, and of course hard work. This is a great community!!
            Bob
            Robert A. Christman
