    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 109.6k Views 41 Watching
      Animation works very fine with LightUp ! ๐Ÿ˜Ž
      You can orbit, zoom etc around anything during the animation! Terrific! โ˜€
      Just a little question : there is no negative speed? Restart in the other side ? ?
      How makes the inverse walk of the train ? (I am very beginner to this! ๐Ÿ˜ณ
      Button "Reverse" seems stuck ?
      http://s6.postimg.org/u33hd7ftd/train.jpg
      • deaneauD Offline
        deaneau
        Or coupled with City Street generator by Thomthom?
        Hello Pilou,
        i have experimented with Railroad as "Street Designer".
        my problem will be crossroads (X 90ยฐ,45ยฐ etc. and Y like a switch in railroad.
        look here
        Regards Dean
          Generally crossroad are some dangerous for rails' train! ๐Ÿ˜„
          • deaneauD Offline
            deaneau
            Yes i know. I was an enginedriver Student.
            I think the crossroads must be a separate objects or a group with street objects and a crossroad object.
            Il try to experiment with some objects.
            This plugin is marvelous. Some times will crash in 2013 however this will inspire me to experimentalize.
            If anybody will have streets...it's possible. Look in the documentation and look in all parts (sketchup files) how do you make an object. It's easy. Ok a car or loko isn't easy. A steam loko is difficult I think.
            Regards Dean
            • eneroth3E Offline
              eneroth3
              Hi all.
              I've made a street version of the track now. I've also made a 90 degrees and a 45 degrees intersection by combining several track parts that you can just copy into other models. The new track types and intersections are attached. Just copy the track the folders into the track folder within the ene_railroad folder.
              The upcoming version of the plugin wont draw switch indicators to these tracks. Also I might look into hiding the edges between each half of the street when adding new street tracks.
              To change the direction of travel the velocity needs to be set to 0. You can't change direction while moving.
              streets.zip
              My website: http://julia-christina-eneroth.se/
                Thanks for the info! โ˜€
                You have made a true gem! ๐Ÿ˜Ž
                Will try the Streets maker as soon as possible! ๐Ÿค“
                Can you show the image of the arborescence of the new Files Folders Streets supposed to be ? ๐Ÿ˜‰
                Because beside or inside nothing appears! ๐Ÿ˜ฎ
                • eneroth3E Offline
                  eneroth3
                  place the folders in "<plugin folder>/ene_railroad/tracks/". If you can't find the plugin folder you can activate the Insert Rolling Stock tool and click the Open Rolling Stock folder button, then go up one level and open you'll see tracks/.
                    Thx! Cool now! โ˜€
                    No sure that streets was for trains?
                    • eneroth3E Offline
                      eneroth3
                      You can initialize cars as rolling stocks to drive them on the roads.
                      You can also right click on the streets with the sidewalk in the middle, open their properties and reverse them to put the sidewalk on the side.
                        For create a new one car or train...
                        Can I take any volume as one group ?
                        Does this group must be ont the rail or street during the creation?
                        Where must be this new on after I give it a name ?
                        Because seems nothing is created after the naming! ๐Ÿ˜„
                        • eneroth3E Offline
                          eneroth3
                          It must be standing on a track/street to be driven so it's easiest to initialize it there too. To find the center plane of the street you can draw a temporary edge between the painted lines at the sides of that lane and position the group at its midpoint.
                            Ok but about the naming?
                            If it's ask a name, that want to say that all points are fully ...so in what folder goes the new one created ?
                            Creation was success after the naming but...
                            and I see nowhere where is the "Bull" that I had created! ๐Ÿ˜„
                              All this new creation can be done in SU Make ?
                              A new one must follow all the parts of an existing One?
                              A simple box volume can't be work ?
                              • deaneauD Offline
                                deaneau
                                @eneroth3 said:
                                Hi all.
                                I've made a street version of the track now....
                                many thanks thats looks good.
                                you have pm about streets in berlin
                                regards dean
                                • deaneauD Offline
                                  deaneau
                                  pilou look here
                                    Thx ๐Ÿ˜‰
                                    My problem is now how make a new thing for go to the rail ! ๐Ÿ˜„
                                    • deaneauD Offline
                                      deaneau
                                      Thx ๐Ÿ˜‰
                                      what do you mean with new things? locos, cars or what?
                                        See the bottom of the previous page! ๐Ÿ˜‰
                                        • deaneauD Offline
                                          deaneau
                                          Here some parts based on the intersections
                                          • deaneauD Offline
                                            deaneau
                                            my suggestion copy a loco in a separate folder and open this in sketchup and look where the wheels must be.
                                            • 18
                                            • 19
                                            • 3 / 19
