    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 395.3k Views 109 Watching
    • U Offline
      unsuns
      Did you test it ?
      Now when I select a pattern it closes the window, so I have to reopen to adjust settings and if I select another pattern it's the same.
      • guanjinG Offline
        guanjin
        @sdmitch said:
        Posted new version.
        Unsuns, I would appreciate it if you would let me take care of my plugins. Thank you.
        Each pattern, cannot directly activate command, to repeat the icon to perform。
        • sdmitchS Offline
          sdmitch
          @unsuns said:
          Did you test it ?
          Apparently not enough!
          The .set_on_close had unintended consequences and has been removed. Although it did seem to fix the problem of X'ing out, it, for some bazaar reason, was triggered when the pattern was changed. My bad 🤢
          http://sdmitch.blogspot.com/
          • U Offline
            unsuns
            The X-ing problem is back again !
            • sdmitchS Offline
              sdmitch
              Yes I know and it will be until I can figure out why changing the pattern selection causes the window to close.
              Why do you insist on X'ing out of the window? If it is in your way then minimize it.
              • sdmitchS Offline
                sdmitch
                @jolran said:
                Sam I'm looking at your code here. Cant remember which version this is. So you may have changed this behavior.
                But in a callback you have a dialog close ?
                You have a select with an event onchange:
                <select onChange='patternchanged(value)'>
                The function then sends the callback
                function patternchanged(value){
                >    window.location='skp;PatternChanged@'+value;
                In the callback block you have a dlg.close. So everytime select change dialog closes..
                @@dlg.add_action_callback("PatternChanged") {|d,p|
                > 	@@opt=p; puts p
                > 	if @@opt=="Reset" then
                > 						["Brick","Tile","Wood","Tweed","Hbone","BsktWv","HpScth","Hexgon","Octgon","Two2One" ,"IrPoly"].each{|o|
                >   Sketchup.write_default("FloorGenerator",o,nil)};@@opt="Tile";
                >   end
                >   @@dlg.close; @@dlg=nil; self.dialog
                I also see you have the command self.dialog trying to reopend the dialog ?
                But it is set to nil before. Don't know if that messes things up..
                Maybe a timing issue.
                Edit: sorry meant to post this in the devlopper forum where you posted specific question. Copied and pasted wrong...
                Yes I finally figured that all out. I just had to add a variable that I set to true if the PatternChanged and the window was closed and recreated. I deleted the post to the Developer forum as soon as I figured it out so as not to embarrass my self further.
                • jolranJ Offline
                  jolran
                  	@@opt=p; puts p
                  Maybe a timing issue ?
                  • jolranJ Offline
                    jolran
                    Ha ha ! Ah ok! 👍
                    I thought I was getting high or something. One minute I thought I read about it in the developper section, then it was gone. So I removed my last sentence as well, just in case I was wrong 😆 😆
                      stagelight
                      Thank you for another great plugin !!
                      This is what I've been working on lately, with your script.
                      • sdmitchS Offline
                        sdmitch
                        It's a rather funny floor but a very nice bridge.
                          djrique
                          Thank you guy for that great plugin. I'm a brazilian and translated it for portuguese. Do you think that it's good?
                          • sdmitchS Offline
                            sdmitch
                            Good by me.
                              djrique
                              Upload .Rb file PT-BR Language: https://drive.google.com/file/d/0BwqiSt9yjVQDVHZCM1JCOS1wb0U/edit?usp=sharing
                              i don´t know to create .rbz file... 😳
                              THX.
                              • sdmitchS Offline
                                sdmitch
                                THX.
                                An .rbz file is just a .zip file with the extension changed to .rbz
                                • Mistro11M Offline
                                  Mistro11
                                  Hope this render reflects my gratitude. 👍
                                  i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                  Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                  • sdmitchS Offline
                                    sdmitch
                                    It's beautiful. Thanks for making me look so good.
                                      sidewalk
                                      Excellent plugin! A tool like this has been on my wishlist for years.
                                      One suggestion: Is it possible to add an exterior clapboard/lap siding setting? The parameters could be very similar to the wood setting.
                                        toto ete
                                        great plugin! super work and thanks for sharing it!
                                        keep up the wonderful work!
                                        • PixeroP Offline
                                          Pixero
                                          Suddenly I get the same error as mentioned above.
                                          When I change pattern the window closes.
                                          I've re installed the latest version and tried it on two PCs.
                                          Weird. 😕
                                          • sdmitchS Offline
                                            sdmitch
                                            Weird. 😕
                                            That makes no sense at all. Have you installed any new plugins lately? Maybe there is a conflict. Does the Ruby Console show any errors?
                                            • 16
                                            • 17
                                            • 5 / 17
