    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 439.8k Views 109 Watching
    • U
      unsuns
      That's alright ! Thank you !
      • U
        unsuns
        Did you test it ?
        Now when I select a pattern it closes the window, so I have to reopen to adjust settings and if I select another pattern it's the same.
        • guanjinG
          guanjin
          @sdmitch said:
          Posted new version.
          Unsuns, I would appreciate it if you would let me take care of my plugins. Thank you.
          Each pattern, cannot directly activate command, to repeat the icon to perform。
          • sdmitchS
            sdmitch
            @unsuns said:
            Did you test it ?
            Apparently not enough!
            The .set_on_close had unintended consequences and has been removed. Although it did seem to fix the problem of X'ing out, it, for some bazaar reason, was triggered when the pattern was changed. My bad 🤢
            http://sdmitch.blogspot.com/
            • U
              unsuns
              The X-ing problem is back again !
              • sdmitchS
                sdmitch
                Yes I know and it will be until I can figure out why changing the pattern selection causes the window to close.
                Why do you insist on X'ing out of the window? If it is in your way then minimize it.
                • sdmitchS
                  sdmitch
                  @jolran said:
                  Sam I'm looking at your code here. Cant remember which version this is. So you may have changed this behavior.
                  But in a callback you have a dialog close ?
                  You have a select with an event onchange:
                  <select onChange='patternchanged(value)'>
                  The function then sends the callback
                  function patternchanged(value){
                  >    window.location='skp;PatternChanged@'+value;
                  In the callback block you have a dlg.close. So everytime select change dialog closes..
                  @@dlg.add_action_callback("PatternChanged") {|d,p|
                  > 	@@opt=p; puts p
                  > 	if @@opt=="Reset" then
                  > 						["Brick","Tile","Wood","Tweed","Hbone","BsktWv","HpScth","Hexgon","Octgon","Two2One" ,"IrPoly"].each{|o|
                  >   Sketchup.write_default("FloorGenerator",o,nil)};@@opt="Tile";
                  >   end
                  >   @@dlg.close; @@dlg=nil; self.dialog
                  I also see you have the command self.dialog trying to reopend the dialog ?
                  But it is set to nil before. Don't know if that messes things up..
                  Maybe a timing issue.
                  Edit: sorry meant to post this in the devlopper forum where you posted specific question. Copied and pasted wrong...
                  Yes I finally figured that all out. I just had to add a variable that I set to true if the PatternChanged and the window was closed and recreated. I deleted the post to the Developer forum as soon as I figured it out so as not to embarrass my self further.
                  • jolranJ
                    jolran
                    	@@opt=p; puts p
                    Maybe a timing issue ?
                    • jolranJ
                      jolran
                      Ha ha ! Ah ok! 👍
                      I thought I was getting high or something. One minute I thought I read about it in the developper section, then it was gone. So I removed my last sentence as well, just in case I was wrong 😆 😆
                        stagelight
                        Thank you for another great plugin !!
                        This is what I've been working on lately, with your script.
                        • sdmitchS
                          sdmitch
                          It's a rather funny floor but a very nice bridge.
                            djrique
                            Thank you guy for that great plugin. I'm a brazilian and translated it for portuguese. Do you think that it's good?
                            • sdmitchS
                              sdmitch
                              Good by me.
                                djrique
                                Upload .Rb file PT-BR Language: https://drive.google.com/file/d/0BwqiSt9yjVQDVHZCM1JCOS1wb0U/edit?usp=sharing
                                i don´t know to create .rbz file... 😳
                                THX.
                                • sdmitchS
                                  sdmitch
                                  THX.
                                  An .rbz file is just a .zip file with the extension changed to .rbz
                                  • Mistro11M
                                    Mistro11
                                    Hope this render reflects my gratitude. 👍
                                    Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                    • sdmitchS
                                      sdmitch
                                      It's beautiful. Thanks for making me look so good.
                                        sidewalk
                                        Excellent plugin! A tool like this has been on my wishlist for years.
                                        One suggestion: Is it possible to add an exterior clapboard/lap siding setting? The parameters could be very similar to the wood setting.
                                        • T
                                          toto ete
                                          great plugin! super work and thanks for sharing it!
                                          keep up the wonderful work!
                                          • PixeroP
                                            Pixero
                                            Suddenly I get the same error as mentioned above.
                                            When I change pattern the window closes.
                                            I've re installed the latest version and tried it on two PCs.
                                            Weird. 😕
                                            • 16
                                            • 17
                                            • 5 / 17
