    [Plugin] ImageTrimmer
    364 Posts 58 Posters 319.0k Views 58 Watching
      rahdad1
      Ran the test.
      Seems to be the right version that I installed.
      Do you know of at least one other person running this ruby script in win8.1 and sketchup 8?
      Just trying to figure out where the problem might be. (other than me)
        driven
        interestingly if I run this[includes the link] in Menu >> Window >> 'Ruby Console' using
        @dlg = UI;;WebDialog.new("Java", true,"java", 900, 900, 200, 200, true, true)
        @dlg.set_url("http://java.com/en/download/installed.jsp")
        @dlg.show_modal
        I get a missing plugin alert? which may be signs of a permissions issue?
        I'll dig deeper
          @driven
          I'm using Win7 on this PC.
          I find that running your @dlg code in the Ruby Console worked fine for me - no errors, and it confirms latest Java is installed [v7.45].
          @rahdad1
          One very odd thing I noticed in your 'SKMtools' folder...
          Where did that 'META-INF' subfolder come from?
          It's not in the standard install RBZ etc ?
          What's in it ?
          Incidentally, are you an Administartor ?
          If not, then give yourself that power in the Users Control-Panel...
          Also, as well as FULL security permissions 'for all' to your Plugins folder... is SketchUp.exe set to 'always run as administrator' under Properties > Compatibility ?
            rahdad1
            After total frustration, I decided to delete the SKMtools files and folder and START over.
            The problems probably started in the installation itself.
            This is the same procedure I originally used........
            I downloaded the file SKMtools_V20121214.rbz
            While in Sketchup under preferences/extensions/ install extension
            I "chose" SKMtools_V20121214.rbz
            It seemed to load however when I went looking for image trimmer under the tools drop-down
            it was missing.
            I then separately downloaded the file "SKMtools_loader.rb and put it in the plugins folder.
            Now Imagetrimmer is listed in the drop-down menu.
            Clicking it the first time brings up an error window that says it can't find SKMtools_loader.rb even though it's in the Google SketchUp 8\Plugins folder
            Obviously I've done something wrong from the very beginning.
            Please explain the correct way to install this.
              If you auto-install the toolset from its current RBZ that is all you need to do.
              You get a 'SKMtools.rb' and its subfolder of several helper files, called 'SKMtools'.
              The obsolete 'SKMtools_loader.rb' file is NOT needed.
              In fact having it will break things !
              I assume you found it and then downloaded that from somewhere else, and installed it in frustration.
              It is now several years out of date !
              Please remove it from your Plugins folder...
              It will break things if it's forced in there !
              If you have proper FULL security permission for your Plugins folder then the current toolset actually deletes that very file from the Plugins folder [if you have it installed] as it loads, and it does a tidy-up.
              If you have limited permissions, or you have subsequently manually reinstall the '_loader', then you could get issues as it loads and messes with the latest code...
              Can I suggest that you manually delete all SKM files and the whole 'SKMtools' subfolder.
              Then reinstall the SKMtools toolset from its latest RBZ.
              Then restart SketchUp and then retry the tools.
              Things are getting very tangled πŸ˜’
                rahdad1
                I totally removed the SKMtools folder, SKMtools.rb, SKMtools_loader.rb and anything left in the user-temp-skmtools folder.
                I am administrator and I have full control in the plugins folder and SKMtools folder as shown in the attached images.
                From the SketchUcation toolbar within Sketchup, I found and auto-installed the SKMtools.
                It confirmed successful install when it was completed.
                I ran imagetrimmer and, like always, the java error window pops up with the same message about "can't find or locate main class c:......\edgedetector.jar"
                It's probably a java / win8 problem which I don't expect you to help me solve.
                Your program obviously works fine based on other users successfully using it.
                I'll keep researching and hopefully figure it out.
                If you want to continue to suggest other things to try, I'm welcome to that also.
                  You have it as good as we can get from the SketchUp/Ruby side...
                  It MUST be a Win/Java issue πŸ˜’
                    KO1134
                    How do I use this plug-in?
                    I can't get it to work!
                      Reread the instructions, and comments in the thread.
                      The Image must be imported as an Image, NOT a texture.
                      It must be a PNG.
                      It must have a transparency alpha-channel.
                      The background pixels to be removed must on that.
                      ALL other pixels must be 100% opaque.
                      If they have any transparency at all they will also be removed !
                      The simplest way to sort this is to open the PNG in Gimp [or PhotoShop] and 'Flatten' it to remove transparency, then add in the transparency alpha-channel, then use the magic-wand to select all of the background pixels and <delete>.
                      Save the PNG and import it as an Image into your SKP.
                      Select it.
                      Choose ImageTrimmer on the Tools menu.
                      Answer the prompts...
                      Run with the Ruby Console open to see if there are any error-massages...
                      Because this tool uses Java '.jar' files [small executables] to process images, you need to have Java installed and enabled on your computer [the usual default].
                      Also check that the .jar file-type is set to open with Java [execute] and NOT to open in your [de]compression application - some hijack various file extensions that are used by things like Java and stop them executing...
                      If all of this fails, post clear details of what is wrong...
                        bitslapped
                        I have tried this numerous different ways and couldn't get it to work.
                        -Saved PNG as GIF to remove semitransparent pixels, then back to PNG
                        -Most of the time doesn't get past 'scanning pixels'even on a 600x600px image
                        -When it does complete I am left with a hidden outline of the image with no actual image in it.
                        I am trying to put a plant library together and this would make life soo much easier.
                          All transparent pixels are assumed to be background and are ignored by ImageTrimmer.
                          So even slightly transparent ones go !
                          Using Gimp.
                          Flatten the PNG to remove transparency.
                          The 'background' usually reverts to opaque white pixels [or sometimes black]
                          Add a transparent alpha layer.
                          Use the magic wand to select all of the opaque white pixels forming the background.
                          Press the 'Delete' key to remove them,
                          Now you should see a transparent background - two-tone gray checks.
                          Save the PNG file [in Gimp this is called 'Export...'].
                          That PNG when Imported as an Image into SketchUp should now ImageTrim properly.
                          Note that the ImageTrimming is only accurate to a 'pixel width' - so areas of opaque pixels that are only one [or sometimes two] pixels wide will be missed out too - because the transparent ones are taken as the 'border' and if a border's edges are effectively 'coincident' no face can form and the unfaced edges are auto-removed too...
                            What face style do you have selected? The image becomes a texture during the process so if you have Monochrome selected as the current face style, you'll get the result you describe.
                              Well spotted Dave !
                              That might well be the issue πŸ˜’
                                bitslapped
                                Face style is shaded with textures.
                                -I loaded a 500x600px plant png with transparent background into photoshop
                                -I flattened the image, selected colour 'white' and deleted out pure white pixels, leaving the white frame around my plant, i.e. no semi-transparency.
                                -import the image into sketchup 2014 pro with only imagetrimmer plugin installed.
                                -scanning pixels frozen at 91%.
                                I should point out that I have got this to work for some files, just not these plants.
                                Are there any other specific png settings?
                                I get 'not responding' from sketchup plugins all the time on big jobs, but this doesn't seem to complete no matter how long i leave it, and on such a small image it seems there is something else wrong.
                                Cheers
                                edit: for anyone wanting to try it out with these images, they are at ozbreed.com.au.
                                having tried a few images now it seems the edge complexity of these plants is killing it
                                  bitslapped
                                  It was a compromise between VRay and Sketchup.
                                  I ended up exporting the transparency selection path from photoshop to illustrator to dwg then overlaying the outline onto the image in sketchup. It meant I could use the antialiasing in the images for vray renders (where they do catch shadows) and produce quite smooth shadows in sketchup.
                                  The hope is that in future versions of sketchup, png with alpha will catch shadows.
                                  https://3dwarehouse.sketchup.com/model.html?id=uff66f099-c698-496c-b131-c13c1e197243
                                  Thanks for your work TIG. I will keep trying this one as new releases come out.
                                    rv1974
                                    ❓ Nothing happens after 'making edges' stage.
                                    Ruby console message:
                                    Error: #<Errno::ENOENT: No such file or directory - C:\autosave\TrimmedImages\uuu[Edges].dat>
                                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:264:in readlines' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:264:in make_edges'
                                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:196:in process_image' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:165:in initialize'
                                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:818:in new' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:818 C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:264:in call'
                                    P.S. If I run che check mentioned above I have this:
                                    UI.openURL("file:///"+"../full/path/to/EdgeDetector.jar")
                                    false
                                    the png I tried to get trimmed
                                      Here's a PNG I reprocessed... BUT the original works as it uploaded anyway, and a v8 SKP showing that Image and ImageTrimmed Cutout...
                                      SSO it works fine for me. πŸ˜•
                                      Do you have Java installed/enabled and .jar files set to open with Java ?
                                      Some decompression apps hijack that file suffix and stop them executing properly...
                                      As outlined more fully here... http://sketchucation.com/forums/viewtopic.php?p=518232#p518232
                                      uuu.skp
                                        manifestphoto
                                        Hi there, I'm new to sketchup and glad I found your plugin, however it keeps crashing the application when I try to trim an image. If I do anything else with my computer at all, even resizing the Sketchup window or typing in this box, while it is running, the program hangs. If I leave it focused on Sketchup and do not use my PC at all, it gets through the "scanning pixels" function, but hangs during the "processing edges" operation, never getting past about 15%.
                                        My PC is not brand new, but it's also not that old and is fairly capable . . . so I don't think it's a processing issue. Are other people experiencing this? Is there a fix?
                                        Thanks.
                                          Read back through the posts...
                                          Sticking at around 15% is indicative of a failure in the image-processing...
                                          It is hanging not crashing, as it never completes its processing.
                                          ImageTrimmer uses .jar files to process some aspects of its image-files etc.
                                          These are small executable Java apps that come with the toolset.
                                          Sometimes a compression exe will hijack that .jar file-type suffix and thereby prevent them 'running'.
                                          So ensure that you have Java installed and activated, and that .jar is a file-type which will 'open' with Java etc...
                                          Also the PNG file needs to be a reasonable size - the number of pixels will obviously influence the time to process it, but a minute or so should suffice.
                                          Also crop the PNG so that the number of 'background' pixels is minimized - every pixel is considered, even those that will eventually be removed.
                                          Also remember that ALL transparent pixels will be removed - even slightly transparent ones - so ensure that the PNG consists of opaque pixels where you want to keep the face and transparent ones for the 'background' you want to remove...
                                          If you still have issues please post the PNG you are trying to trim, and a screen-shot of your Java setup...
                                          • H Offline
                                            hendrygunawan
                                            I have the same problem too, and I try something funny. Just make sure your extensions in preferences got checked all. It solved my problems.
                                            Just want to share. πŸ˜„
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 14 / 19
