    Upholstered furniture
    328 Posts 54 Posters 224.5k Views 54 Watching
      cuttingedge
      @alvis said:
      because in the world is a better programs. Slowly, I can see a few steps ahead, how to do it. Excellent Plugin (VertexTool, FredoTools, Artisan and many other) improved capabilities, but...
      I'm starting to think that Sketchup evolution is too slow... 😒
      Im always challenged with this tufted furnitures. Its kind of tidious to come up with
      a proxy that would yield a good subdivision.- (non destructive). Much much easier with Max for example. But i still do it in Sketchup for the love of the software... Yeah, we are everyday hoping for better handling of polys..πŸ˜„
      • alvisA Offline
        alvis
        Thanks for the coments, guys. next model...and render from THEA
        • HieruH Offline
          Hieru
          Just curious, did you get rid of the ngons after stage three in your workflow?
          www.davidhier.co.uk
          • alexandre skA Offline
            alexandre sk
            Great models.
            How many entities have the last couch?
              cuttingedge
              lovely... you have mastered this incredibly. May I ask you one question. This last sofa you made, (the red one)how much time will it take you to do a typical sofa like this, if you have the idea in your mind how the proxy should look like?
              • alvisA Offline
                alvis
                I will not lie, it takes 4 to 6 hours. The most commonly used UNDO and SAVE function. How to look like a proxy, as a sculptor does. stylized shape formed long for good result
                • jo-keJ Offline
                  jo-ke
                  I don't understand the step between the 3rd and 4th step. How do you built the vertikal lines for the chesterfield pattern before artisan?
                  http://www.zz7.de
                    sketchuh
                    this is insanely Amazing. i bet the process has to be very precise. i modelled a tufted cushion in modo which is easier to do in sketchup. in the end , sketchup is Not a sub-d modelling program. even with artisan, and other plugins, still not perfect. but from your post. it's possible!. great job. i will stick with modo or blender or 3ds max πŸ˜›
                    • olisheaO Offline
                      olishea
                      +1
                      Looks like subdividing with hard edges.
                      oli
                      • RichardR Offline
                        Richard
                        Mate, seriously you are getting just enough subtle variances in the models - you have that NAILED!
                        BUILTBRAND.COM.AU
                          catialilianacoelho
                          I need your help, how i draw this beds please, what plugin i need too? thanks
                          bed
                          • massimoM Offline
                            massimo Moderator
                            Hi, I think that the thread itself can give an answer to your questions. No? πŸ˜‰
                              catialilianacoelho
                              i dont know how make capitone with this organic shape bed...
                                Surely you have some attempts to display?
                                • alvisA Offline
                                  alvis
                                  Well, a short course on how to make a simple and rather realistic tuft with Sketchup. Step by step ... day by day making lessons. You must have Artisan and VertexTool.
                                  First lessons:
                                  Photomatch your model, Draw the contour of the bed and double lines by tuft.
                                  To be continued...
                                  • olisheaO Offline
                                    olishea
                                    This is awesome! 100% convincing models and renders. The creases, tufts, everything just spectacular. πŸ‘
                                    oli
                                      Safa
                                      can you make a video to learn us why you do this?
                                      • ken28875K Offline
                                        ken28875
                                        Really excellent models and renders, Alvydas. πŸ‘ πŸ‘
                                        Are the textures done in SketchUp or do you add them in postwork/Photoshop (e.g. overlay)?
                                        Thanks and have a great day!
                                        _KN
                                        Follow Your Dreams.
                                        • alvisA Offline
                                          alvis
                                          Thanks, Oli! πŸ˜‰
                                          A lot of video lessons are online. I have not shown anything new πŸ˜’
                                          _KN
                                          Thanks. All textures done in SketchUp. In other projects, I use a whole arsenal (postwork)
                                          As promised, how I do this...
                                          Pushing small square edges (center only). There will be buttons
                                          Pushing large square edges (center only). There will be a tuft
                                          Pushing the edges where  is tension of tuft (only center).
                                          Everything looks like this (Must be very accurate)
                                          Extrude external edges
                                          Made a small slope
                                          copy, paste, flip along axis
                                          Well done
                                          Well done
                                          Little magic with Artisan
                                          presto, presto !
                                          Tweaking...
                                            Safa
                                            sorry ,, I'm new in woodworking .. can u help me (link video or what's plugins used)
                                            • 16
                                            • 17
                                            • 2 / 17
