    Upholstered furniture
    328 Posts 54 Posters 238.6k Views 54 Watching
      Excellent! β˜€
      I suppose Artisan as Subdivisions making ?
      • C
        cuttingedge
        @alvis said:
        because in the world is a better programs. Slowly, I can see a few steps ahead, how to do it. Excellent Plugin (VertexTool, FredoTools, Artisan and many other) improved capabilities, but...
        I'm starting to think that Sketchup evolution is too slow... 😒
        Im always challenged with this tufted furnitures. Its kind of tidious to come up with
        a proxy that would yield a good subdivision.- (non destructive). Much much easier with Max for example. But i still do it in Sketchup for the love of the software... Yeah, we are everyday hoping for better handling of polys..πŸ˜„
        • alvisA
          alvis
          Thanks for the coments, guys. next model...and render from THEA
          • HieruH
            Hieru
            Just curious, did you get rid of the ngons after stage three in your workflow?
            www.davidhier.co.uk
            • alexandre skA
              alexandre sk
              Great models.
              How many entities have the last couch?
              • C
                cuttingedge
                lovely... you have mastered this incredibly. May I ask you one question. This last sofa you made, (the red one)how much time will it take you to do a typical sofa like this, if you have the idea in your mind how the proxy should look like?
                • alvisA
                  alvis
                  I will not lie, it takes 4 to 6 hours. The most commonly used UNDO and SAVE function. How to look like a proxy, as a sculptor does. stylized shape formed long for good result
                  • jo-keJ
                    jo-ke
                    I don't understand the step between the 3rd and 4th step. How do you built the vertikal lines for the chesterfield pattern before artisan?
                    http://www.zz7.de
                      sketchuh
                      this is insanely Amazing. i bet the process has to be very precise. i modelled a tufted cushion in modo which is easier to do in sketchup. in the end , sketchup is Not a sub-d modelling program. even with artisan, and other plugins, still not perfect. but from your post. it's possible!. great job. i will stick with modo or blender or 3ds max πŸ˜›
                      • olisheaO
                        olishea
                        +1
                        Looks like subdividing with hard edges.
                        oli
                        • RichardR
                          Richard
                          Mate, seriously you are getting just enough subtle variances in the models - you have that NAILED!
                          BUILTBRAND.COM.AU
                          • C
                            catialilianacoelho
                            I need your help, how i draw this beds please, what plugin i need too? thanks
                            bed
                            • massimoM
                              massimo Moderator
                              Hi, I think that the thread itself can give an answer to your questions. No? πŸ˜‰
                              • C
                                catialilianacoelho
                                i dont know how make capitone with this organic shape bed...
                                  Surely you have some attempts to display?
                                  • alvisA
                                    alvis
                                    Well, a short course on how to make a simple and rather realistic tuft with Sketchup. Step by step ... day by day making lessons. You must have Artisan and VertexTool.
                                    First lessons:
                                    Photomatch your model, Draw the contour of the bed and double lines by tuft.
                                    To be continued...
                                    • olisheaO
                                      olishea
                                      This is awesome! 100% convincing models and renders. The creases, tufts, everything just spectacular. πŸ‘
                                      oli
                                        Safa
                                        can you make a video to learn us why you do this?
                                        • ken28875K
                                          ken28875
                                          Really excellent models and renders, Alvydas. πŸ‘ πŸ‘
                                          Are the textures done in SketchUp or do you add them in postwork/Photoshop (e.g. overlay)?
                                          Thanks and have a great day!
                                          _KN
                                          Follow Your Dreams.
                                          • alvisA
                                            alvis
                                            Thanks, Oli! πŸ˜‰
                                            A lot of video lessons are online. I have not shown anything new πŸ˜’
                                            _KN
                                            Thanks. All textures done in SketchUp. In other projects, I use a whole arsenal (postwork)
                                            As promised, how I do this...
                                            Pushing small square edges (center only). There will be buttons
                                            Pushing large square edges (center only). There will be a tuft
                                            Pushing the edges where  is tension of tuft (only center).
                                            Everything looks like this (Must be very accurate)
                                            Extrude external edges
                                            Made a small slope
                                            copy, paste, flip along axis
                                            Well done
                                            Well done
                                            Little magic with Artisan
                                            presto, presto !
                                            Tweaking...
                                            • 16
                                            • 17
                                            • 2 / 17
