    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.0k Views 155 Watching
    • tt_suT
      tt_su
      Have you disabled Dynamic Components by any chance?
      • fredo6F
        Yes. weird. It is strange that a Model object has no entityID method defined (which is normally "Model").
        This may explain why some users cannot select faces in JPP if this problem occurs.
        • tt_suT
          tt_su
          Yea, Model doesn't inherit from Entity and some methods are not mirrored. It's an annoying inconsistency.
            StamatisPsarras
            @tt_su
            You were right dynamic components was disabled! Now it works, thanks!
              StamatisPsarras
              I am also getting this error in a complex model.
              Any ideas what I should avoid when modeling, so it wont happen again?
              Date; 29-Apr-14 18;16;21
              An error occured in Joint Push Pull
              Error in generation of the geometry
              undefined method `smooth?' for nil;NilClass
              JointPushPullGeometry.rb; 1107 -- block in geometry_coplanar_edges_overhang
              JointPushPullGeometry.rb; 1105 -- each
              JointPushPullGeometry.rb; 1105 -- each_with_index
              JointPushPullGeometry.rb; 1105 -- geometry_coplanar_edges_overhang
              JointPushPullGeometry.rb; 354 -- block in geometry_robot_erase_coplanar_edges
              JointPushPullGeometry.rb; 352 -- each
              JointPushPullGeometry.rb; 352 -- geometry_robot_erase_coplanar_edges
              JointPushPullGeometry.rb; 214 -- robot_call_action
              JointPushPullGeometry.rb; 177 -- geometry_robot_exec
              JointPushPullGeometry.rb; 160 -- geometry_robot
              JointPushPullGeometry.rb; 75 -- block in geometry_execute
              Lib6Operation.rb; 317 -- call
              Lib6Operation.rb; 317 -- step_geometry
              Lib6Operation.rb; 278 -- block in yield?
              -e; 1 -- call
              • fredo6F
                Unfortunately, these kind of errors may happen with complex models where the generated offset surface contains overlaps. This is due to the fast method of generation. I have the plan to have a default safe generation method to takeover when there are such errors. Should go in a next release.
                  martccs
                  Good afternoon everyone. I am Brazilian and I have read all this post and already tried almost everything here was suggestible. my problem is this: I have windows 8.1 64bit and working with sketchup pro 2014 beixei all files and procedures as indicated and it worked for about 20 minutes and then the Joint push pull bar disappeared.. since then redo all the steps as before to have it installed and do not get any results. Nothing happens. I no longer need to install it and use this to my architectural projects. I'm getting disappointed and frustrated with this and am about to give this application which is great but does not work.
                  OBS:. I have other plugins in sketchup and whenever I open the program pops up a list of read error indicating several or all plugins.
                  Thanks in advance,
                  Marcelo Cordeiro.
                  • cottyC
                    cotty
                    Have you upgraded from a previous version of SU and copied older plugins from there?
                    my SketchUp gallery
                    • fredo6F
                      Marcelo,
                      The best is that you install PluginStore once, and then make all the Plugin installations by Auto-install from the PluginStore.
                      Note: to run JointPushPull, you also need to install LibFredo6
                      PS: if you have errors at startup, could you post them in this forum so that we can have a look. This may help
                        rv1974
                        Fredo, (hope it sounds intriguing enough to you)
                        would it be possible to add some importantfeature-
                        The Inset (a.k.a. Offset) on push-pulled face?
                        and if push-pull value=0 it could become 'multiple offset tool'.
                        and.. it'd be desirable if the offset faces would stay selected after routine execution.
                        Side note: Generally speaking it's about the 3D chamfer with one of two* distances set to 0, and maybe some part of the code could expand the functionality of your 'Sharp corner'?
                        the general idea.
                        The Acad's Chamfer command with 'Distance' option selected. 2 diffrent distances were set (10 and 5 in this example). The selection order sets the
                        orientation of the 'distance chamfer'.
                        PS The file can be opened in any web browser.
                          dedmin
                          See the video - SU 2014 Pro, Win 7 64 bit
                          Video_2014-06-01_171452.wmv
                          • fredo6F
                            [attachment=0:im4gt3by]<!-- ia0 -->Video_2014-06-01_171452.wmv<!-- ia0 -->[/attachment:im4gt3by]
                            I'll have a look. Even, if holding the mouse wheel while entering a value in the VCB is not exactly the standard behavior, I think I need to make JPP a little bit safer.
                              martccs
                              @fredo6 said:
                              [attachment=0:g6nhkill]<!-- ia0 -->Video_2014-06-01_171452.wmv<!-- ia0 -->[/attachment:g6nhkill]
                              So Fredo I'm getting use push pull join but only after having given up version skp 2014 to 2013 and returned to the pro version and only then. Thus use of a plugin with more efficiency. I have LibFredo6. Do you have the link to the Pluginstore? I can not connect or download anything through the warehouse extension.
                              Cotty I only use the 2013 version of skp and plugins are the LibFredo6 versions that were downloaded the most recent and only use these.
                              AOBS:. Now I can not use the tool 1001bittools =^(
                              Thank you all.
                                @Marcello
                                404 Not Found
                                (sketchucation.com)
                                πŸ˜’
                                • B
                                  BorgMan
                                  OK, I've been trying, but I can't seem to get this plugin to work properly and it's been pissing me off 😑
                                  In the former version, whenever I wanted to push-pull, I clicked the surface (because P-P didn't do that automatically), select the desired tool, went into a direction and then entered the dimension I wanted it to have. Worked like a charm.
                                  With the new update... HOORAY! I don't need to pre-select!.. but... why won't you do stuff? Why do you keep telling me the next time I click you'll deselect? I don't want that, because I want to enter a dimension in the VCB, which I can't do if I hold down my mouse button! Hey, one way or another, I kind of figured it out! Great, then now I'll enter a dimension!
                                  ... eh... no... that's not right. When hitting enter, it took the dimension in the Push-Pull menu bar, instead of the one I just entered in sketchup itself in the lower right corner. Wait. That's strange. You never did that? And why are you accepting it as that value anyway when I hit backspace to change my value?
                                  I'm confused and annoyed, especially because the former version was as simple as selecting the desired face and then just a click with the selected tool πŸ‘Š And... well... it's kind of slow in selecting faces when not preselecting and using the new selectionable method with the tool of your choice... Which is strange because I'm running both SketchUp and the tools suite from a hyperthreaded quad-core on 2,25GHz and an SSD. What's going on? What am I doing wrong?
                                  OK, select my face. According to the RTFM, this is now unnecesary, but these are multiple faces, so I like to pre-select :)
                                  So, now I'll select the desired Push-Pull tool...
                                  ... eh? I already told you which faces I want to extrude? Why are you telling me to deselect? Do not want!
                                  OK... Managed to get it to work some way or another but not exactly sure how after all the fiddling I did... but why won't you listen to my input? (lower right corner: 0,05 vs value P-P menu bar: 0,100)
                                  More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                  You've gotta love Slivers.
                                    It works great if you do it right. Click and hold the mouse button while moving to start the extrusion. Then just let go of the mouse and type the distance. Don't click again. Or are you clicking in the VCB? If you are doing that, don't. There's no reason to do that. It's the same as with the native tools.
                                    The value in the JPP info bar shows the Offset value you type in the VCB. If you want to change the value after you've entered one, don't hit Backspace. Just type a new value. This is exactly the same behavior as with any native tool which accepts values in the VCB.
                                    It doesn't matter that you have a quad-core CPU and a SSD. SketchUp only uses a single core anyway.
                                    If you really want to use the obsolete JPP instead, you can. This version has so much more capability, though, I don't know why you wouldn't just want to learn to use it correctly.
                                    Hmmm.....
                                    By the way, why don't you complete your profile with SU version and OS?
                                    • B
                                      BorgMan
                                      I tried your tips, Dave R. I click on the face, move it, but when I let go of my mouse button, this tells the program that I'm done with whatever I was doing and render. I just now tried this with the Vector tool. I'm trying to let it follow a line I just drew, which in the obsolete tool suite I did by selecting a face, selecting the Vector tool, click on an endpoint and then dragging it so that it follows a predefined straight line I had set up. When I just tried to do that, it won't accept it. When trying to emulate what I did in the obsolete version, I tried to get as close to the endpoint on the left as possible while staying on the desired face; that red dot is as close as I can get, because it'll go off to another face if I get any closer. Select the face instead so that I don't trail off won't work as it will go off to that other faces anyway?
                                      I then tried to let it regular Follow Me, but this creates a gap in faces; that's the whole reason why I'm using Vector Push-Pull. I also tried to use the JPP Follow Me tool, although in a way I use the regular Follow Me: select a line I want it to follow, and then select the face with JPP Follow Me tool, but it won't follow.
                                      You're right about my SU version and OS; I'll change that right away.
                                      On a side note: as in why I'm not "willing" to learn to use it properly? I'm more than willing, it's just that, coming from a former version of JPP, it feels sluggish to relearn a lot of stuff I thought I had already mastered, only to find that the whole suite works differently than before. I hope you understand that if someone says "just do it such and so and etc" instead of the suite working the same way as it did, is kind of a bummer...
                                      • BoxB
                                        I may be wrong but it feels like you may be missing some of the fundamentals of sketchup. Check your work flow in case you have accidentally picked up some bad habits.
                                        • B
                                          BorgMan
                                          If you're referencing to the fact that there'll be a gap when using Follow Me: I know it'll be there, as Following from a slanted surface always will result in a gap. I wanted to use the Vector tool to close of some stuff after Round Corner operation.
                                          Next point in case: I'll see if there's something I'm doing wrong. The model I'm working on right now does have some errors (it's old) and some of the things I did with it are out of the system already in new models. Fact remains that I'm struggling with the new JPP suite because of a change in flow 😞
                                          • fredo6F
                                            @BorgMan
                                            When you select faces or surfaces, you just click / release on them.
                                            When you are on the last one you wish to select, then click / release again. You are now in dragging mode and can use inferences in the model.
                                            • 30
                                            • 31
                                            • 7 / 31
