    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 357.4k Views 109 Watching
    • sdmitchS Offline
      sdmitch
      Floor Generator has been moved to the Plugin Store.
      http://sdmitch.blogspot.com/
      • guanjinG Offline
        guanjin
        The plug-in is perfect, but unfortunately does not support Chinese language πŸ˜’
        • OxerO Offline
          Oxer
          ~~There is a conflict with offset.rb required for Protude.rb, the next Patterns don't work:
          • Irregular Polygons
          • HopScotch3
          • I_Block
            The rest of patterns work fine.~~
          Another question, is it possible give support to translate the plugin?
          EDIT: I found a version of offset.rb that it isn't conflict with Floor Generator.
          • sdmitchS Offline
            sdmitch
            • HopScotch3
            • I_Block
            I can't see how Floor Generator could ever have a conflict with offset.rb since I use a method of my own creation to do the offsets and every pattern uses the same offset method.
            I have no ability or plans to do any translations of the plugin.
            • OxerO Offline
              Oxer
              Thanks for the reply.
              • tt_suT Offline
                tt_su
                I think offset.rb modifies core classes which breaks plugins.
                • O Offline
                  Openspaces
                  Thank you so very much, very useful Plugin. πŸ‘
                  • sdmitchS Offline
                    sdmitch
                    Shortly after finding and using offset.rb, it was pointed out that that could be a potential problem so I did away with the class and just used it as a method. The first versions of Floor Generator used this offset method until I tried to add the Herringbone pattern. It failed apparently because the way the faces are arranged it cause multiple edges to be reversed in the face and it couldn't handle that. So I had to create my own version.
                      azumayugo
                      hi,
                      i've used your script for several times, it's nice and run well. But suddenly, the script didn't load. When I check ruby console, it show some error message like this :
                      Error: #<NoMethodError: undefined method to_l' for nil:NilClass> C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:89:in dialog'
                      C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:63:in initialize' C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:33:in new'
                      C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:33:in block in <top (required)>' -e:1:in call'
                      What should I do to make the script run again?
                      Thank's before
                      • sdmitchS Offline
                        sdmitch
                        @azumayugo said:
                        hi,
                        Thank's before
                        It is probably a problem related to the saved defaults. If the plugin runs at all, choose the reset option at the bottom of the pattern list to reset the defaults.
                        If that isn't possible, paste the following into the Ruby Console and press Enter.
                        ["Brick","Tile","Wood","Tweed","Hbone","BsktWv","HpScth1","HpScth2",'HpScth3',"HpScth4","IrPoly","Hexgon","Octgon","Wedge","I_Block"].each{|o| Sketchup.write_default("FloorGenerator",o,nil)};
                          azumayugo
                          @sdmitch said:
                          @azumayugo said:
                          hi,
                          Thank's before
                          Thank's sdmitch. It work again πŸ‘
                          • U Offline
                            unsuns
                            Hello Everyone !
                            First of all, thank you for the great job you did to bring us that tool.
                            However, I have an issue : I wanted to be able to run it through a toolbar button (which I successfully did, but when I close the FG window the button is still activated and if I try to run it again the FG window doesnt show up anymore (even if I use other tools after that).
                            Could you please help me to fix it ? πŸ˜•
                            My issue
                            • sdmitchS Offline
                              sdmitch
                              @unsuns said:
                              Hello Everyone !
                              Just don't "X" out of the WebDialog window, instead Right click in space or select any other tool. This will close the WebDialog window an unselect the Toolbar Icon.
                              • jolranJ Offline
                                jolran
                                Sam. I think you could try trigger some actions during the closing of the dialog with "X", using @yourdialog.set_on_close { #set closing action here }. If you are not already using it, that is.
                                As usual concerning webdialogs, I don't know how reliable that method is..
                                • U Offline
                                  unsuns
                                  I tried what you said jolran but I couldn't figure it out. How should I do it ?
                                  Here is the code:
                                  [mod=:3izmkj1d]Please don't post entire blocks of code from other authors - it's bad manners...
                                  Extracts are fine...[/mod:3izmkj1d]
                                  • sdmitchS Offline
                                    sdmitch
                                    I wasn't. Another one of those things that is there but not a necessity so I just ignored it. Thanks for the suggestion.
                                    • jolranJ Offline
                                      jolran
                                      unsuns, I meant this to be tried by Sam at developer-level. I havent dug in his script, so this suggestion was a shot in the dark.
                                      Hope it helps.
                                      /Joel
                                      • U Offline
                                        unsuns
                                        Can't I do it myself ? To help improve that script
                                        • sdmitchS Offline
                                          sdmitch
                                          Posted new version.
                                          Unsuns, I would appreciate it if you would let me take care of my plugins. Thank you.
                                          • U Offline
                                            unsuns
                                            That's alright ! Thank you !
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
