    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 461.3k Views 109 Watching
    • sdmitchS
      sdmitch
      @oxer said:
      ~~There is a conflict with offset.rb required for Protude.rb, the next Patterns don't work:
      • Irregular Polygons
      • HopScotch3
      • I_Block
        The rest of patterns work fine.~~
      Another question, is it possible give support to translate the plugin?
      EDIT: I found a version of offset.rb that it isn't conflict with Floor Generator.
      I can't see how Floor Generator could ever have a conflict with offset.rb since I use a method of my own creation to do the offsets and every pattern uses the same offset method.
      I have no ability or plans to do any translations of the plugin.
      http://sdmitch.blogspot.com/
      • OxerO
        Oxer
        Thanks for the reply.
        • tt_suT
          tt_su
          I think offset.rb modifies core classes which breaks plugins.
          • O
            Openspaces
            Thank you so very much, very useful Plugin. πŸ‘
            • sdmitchS
              sdmitch
              Shortly after finding and using offset.rb, it was pointed out that that could be a potential problem so I did away with the class and just used it as a method. The first versions of Floor Generator used this offset method until I tried to add the Herringbone pattern. It failed apparently because the way the faces are arranged it cause multiple edges to be reversed in the face and it couldn't handle that. So I had to create my own version.
                azumayugo
                hi,
                i've used your script for several times, it's nice and run well. But suddenly, the script didn't load. When I check ruby console, it show some error message like this :
                Error: #<NoMethodError: undefined method to_l' for nil:NilClass> C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:89:in dialog'
                C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:63:in initialize' C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:33:in new'
                C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:33:in block in <top (required)>' -e:1:in call'
                What should I do to make the script run again?
                Thank's before
                • sdmitchS
                  sdmitch
                  @azumayugo said:
                  hi,
                  Thank's before
                  It is probably a problem related to the saved defaults. If the plugin runs at all, choose the reset option at the bottom of the pattern list to reset the defaults.
                  If that isn't possible, paste the following into the Ruby Console and press Enter.
                  ["Brick","Tile","Wood","Tweed","Hbone","BsktWv","HpScth1","HpScth2",'HpScth3',"HpScth4","IrPoly","Hexgon","Octgon","Wedge","I_Block"].each{|o| Sketchup.write_default("FloorGenerator",o,nil)};
                    azumayugo
                    @sdmitch said:
                    @azumayugo said:
                    hi,
                    Thank's before
                    Thank's sdmitch. It work again πŸ‘
                    • U
                      unsuns
                      Hello Everyone !
                      First of all, thank you for the great job you did to bring us that tool.
                      However, I have an issue : I wanted to be able to run it through a toolbar button (which I successfully did, but when I close the FG window the button is still activated and if I try to run it again the FG window doesnt show up anymore (even if I use other tools after that).
                      Could you please help me to fix it ? πŸ˜•
                      My issue
                      • sdmitchS
                        sdmitch
                        @unsuns said:
                        Hello Everyone !
                        Just don't "X" out of the WebDialog window, instead Right click in space or select any other tool. This will close the WebDialog window an unselect the Toolbar Icon.
                        • jolranJ
                          jolran
                          Sam. I think you could try trigger some actions during the closing of the dialog with "X", using @yourdialog.set_on_close { #set closing action here }. If you are not already using it, that is.
                          As usual concerning webdialogs, I don't know how reliable that method is..
                          • U
                            unsuns
                            I tried what you said jolran but I couldn't figure it out. How should I do it ?
                            Here is the code:
                            [mod=:3izmkj1d]Please don't post entire blocks of code from other authors - it's bad manners...
                            Extracts are fine...[/mod:3izmkj1d]
                            • sdmitchS
                              sdmitch
                              I wasn't. Another one of those things that is there but not a necessity so I just ignored it. Thanks for the suggestion.
                              • jolranJ
                                jolran
                                unsuns, I meant this to be tried by Sam at developer-level. I havent dug in his script, so this suggestion was a shot in the dark.
                                Hope it helps.
                                /Joel
                                • U
                                  unsuns
                                  Can't I do it myself ? To help improve that script
                                  • sdmitchS
                                    sdmitch
                                    Posted new version.
                                    Unsuns, I would appreciate it if you would let me take care of my plugins. Thank you.
                                    • U
                                      unsuns
                                      That's alright ! Thank you !
                                      • U
                                        unsuns
                                        Did you test it ?
                                        Now when I select a pattern it closes the window, so I have to reopen to adjust settings and if I select another pattern it's the same.
                                        • guanjinG
                                          guanjin
                                          @sdmitch said:
                                          Posted new version.
                                          Each pattern, cannot directly activate command, to repeat the icon to perform。
                                          • sdmitchS
                                            sdmitch
                                            @unsuns said:
                                            Did you test it ?
                                            Apparently not enough!
                                            The .set_on_close had unintended consequences and has been removed. Although it did seem to fix the problem of X'ing out, it, for some bazaar reason, was triggered when the pattern was changed. My bad 🀒
                                            • 16
                                            • 17
                                            • 5 / 17
