    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 164.1k Views 79 Watching
    • ppoublanP Offline
      ppoublan
      @bigstick said:
      This is truly fantastic - epic work Pascal! The improvement from version 1 (which was good) is immense.
      I'm going to buy this, it's what I've been waiting for for a long time!
      Just released this night Version 1.10 on my website:
      See : http://www.3darcstudio.com/downloads-files/24-3d-tree-maker-sketchup-plugin.html
      with new features including grass. Will update asap Sketchucation and Sketchup Extension sites.
      Yours
      Pascal
      • ppoublanP Offline
        ppoublan
        @kaas said:
        A decrease in size of the leaves relative to the position on the branch might be a nice idea as well (advanced section).
        Available in last version 1.10
        @kaas said:
        Finally, it seems like the vertices of the trunk are not welded together somehow. If I do a LightUp rendering I get artifacts on the trunk. If I use the weld plugin on the trunk the artifacts are gone. The branches seem not affected by this.
        Hi Max,
        Could you post tree sample (skp) here in order to try to debug ? I was not able to reproduce the problem. Will do more tests.
        Yours
        Pascal
          kaas
          @ppoublan said:
          Hi Max,Could you post tree sample (skp) here in order to try to debug ? I was not able to reproduce the problem. Will do more tests.
          Hi Pascal, Just installed and tried the new plugin. Tried a few trees and can't reproduce the problem as well...Strange.. Will try more after I'm back from a trip abroad.
          Max
            jaceguay
            Very nice plugin, Thanks. All I need now itΒ΄s a people maker πŸ’š
            • bigstickB Offline
              bigstick
              Great work with the updated version Pascal!
              One suggestion however, when inserting multiple instances of the same plant/tree, what would be very cool would be an option in the 'Settings' dialog to randomly scale and rotate each new instance.
              With 3D plants, you can naturally get a degree of variation just by rotating and scaling components. The benefit of this is that it works with instancing for render engines, and keeps the file size down πŸ˜„
              • Bob JamesB Offline
                Bob James
                Totally, unequivocally, without question, absolutely OUTSTANDING 😍
                Note: Does not work if loaded into "additional folder". Needs to reside in the SU standard plugin location.
                  dtrarch
                  Great work Pascal
                  A quantum leap for in-SU bushing up.
                  Really quite amazing and only 10 Euro.
                  πŸ‘ πŸ‘ πŸ‘
                  Thank you β˜€
                  dtr
                  • ppoublanP Offline
                    ppoublan
                    Hi Bob,
                    Thanks for your support. Yes you're right regarding plugin files location that needs to stay within default Sketchup Plugins dir. I started to make changes to fix that, but was blocked by limits of .rbs files (scrambled scripts) that does not work the same way as non scrambled scripts with ruby Files/Dirs functions. Hope to find a workaround for future versions. Will have to get help from the developers forum experts...
                    Yours
                    Pascal
                    • ppoublanP Offline
                      ppoublan
                      This is the way it works. When you place multiple trees, or duplicate (right click a tree to access this feature), new instances are randomly rotated around their z axis and randomly scaled. The only thing is that the "amplitude" of scale cant be chosen.
                      +1 on my "todo" list
                      Yours
                      Pascal
                        lebsays
                        Just got this PLugin today... and it may be my favorite ever!!! I'm always struggling to find good trees when I'm modeling landscapes.
                        Can I turn the grass proxy on and off?
                        If the grass is turned on proxy will it render in photo-realistic renderers?
                        • ppoublanP Offline
                          ppoublan
                          Yes, grass is just handled like other trees and plants
                          No. But :
                          • renders that can use SU components will only take one copy/export of one grass and use it to build all the grass plants into the final render.
                          • for those not taking into account SU components, you may sometimes "tcheat" them by exporting once the grass object and separately the components places/scales (like for Octane now).
                            Check the forum of your prefered render to learn more on that.
                            Yours
                            Pascal
                            matt.gordon320
                            This plugin is absolutely amazing, a steal at 10 euro, and once of my top favorites! I wanted to throw a feature request out there that might be a little odd (or specialist) but figured it might be helpful for certain types of plants.
                            I'd love to see an eventual option for root systems, and especially on option for Aerial root systems like on the mangrove or banyan trees.
                            I do a lot of work in China's more tropical regions, and the clients would absolutely love local species in the models.
                            Thanks again for an incredible plugin!
                            • ppoublanP Offline
                              ppoublan
                              Hi Matt,
                              This is a good idea. I've seen this feature in more complex trees/plants generators.
                              I will look how to develop it, but it can take me long. Will try.
                              A kind of cheat/workaround to achieve this with the current version may be :
                              • create your root system as a second tree
                              • when happy with the result, flip it vertically, scale, and place under the first tree.
                              Here is an example :
                              Yours
                              Pascal
                                Works fine with LightUp! β˜€
                                And the fabulous Rail road system by Eneroth! β˜€
                                  laudhi
                                  i wish there is more option for vine/ivy.it will be amazing.... πŸ˜›
                                  • ppoublanP Offline
                                    ppoublan
                                    Hi Laudhi,
                                    Have you checked the Ivy tool from pierreden publihed in this forum ? I'm also using it and maybe it will allow you to achieve what you want.
                                    Regarding 3D Tree Maker, you can use existing parameters to make "ivy like" trees. Let me know if they are any others you are thinking of ?
                                    but it is not interactive (like Ivy) and does not take into account existing objects in the model, as 3D Tree Maker is only based on predefined parameters.
                                    I think that both tools are complementary.
                                    Yours
                                    Pascal
                                      laudhi
                                      [attachment=0:kzqk1sgm]<!-- ia0 -->Capture.JPG<!-- ia0 -->[/attachment:kzqk1sgm][/quote]
                                      I'm just curious if there are plans for vines, there may be an easier way to make vines on the pole ...
                                      Your plugin is amazing, worth to buy the pro version.... πŸ‘
                                        rubenamaroh
                                        Help!!!
                                        I can't run this ruby, the program display in "Plugins" folder but dont display
                                        right next to the arrow the window options " New" , "License" and "About", whats wrong?
                                        Thanks.
                                        • TIGT Online
                                          Have you got available, and then activated its Toolbar ?
                                          How did you 'install' it ?
                                          • deaneauD Offline
                                            deaneau
                                            hi TIG
                                            i have the same problem in 2013
                                            in the menue appear only 3d ArcStudio.
                                            i have installed via sketchucation pluginstore plugin.
                                            if i try to open the toolbar this will not show in the windows.
                                            regards dean
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
