    [Plugin] Add comments to your file
    104 Posts 20 Posters 28.7k Views 20 Watching
      alexanor
      All clear! So we will wait for new updates with new features!
      Have a good trip and all the best to you and your family.
      • inteloideI Offline
        inteloide
        Hello,
        Just work a bit on plugin (lots of hours actually... 😉 )
        I integrated the CKEditor javascript code, that allow to have rich text editor.
        Please find here an overview of the result :
        Version 2.0.0
        Just one thing that worry me is that the toolbar icons can take a lots of place :
        Too much place for toolbar
        Pending also to add options required by alexanor.
        Inteloide
        Humanity will do a huge step when the IT professionals will understand that computers are tools...
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Maybe make your design responsive, so that when the dialog is too narrow, these icons collapse into single icons that pop up a menu with all the other icons nested?
            inteloide
            Hello !
            Just post the new version (on first post), with follwing updates :
            2.0.0: Added : Change text editor to CKEditor, to add possibilty to have rich text format
            Added : Function to add calculator formula and result in the text area
            Added : Options to close or not the calculator after result inserting
            Removed : Option to show bottom of content (could not program it with CKEditor)
            Corrected : Missing tab action button translation for last tab.
            Optimized : Change action buttons size
            %(#FF0000)[Please note that this version is for test : lots of modifications have been introduced.
            Pay attention not to lose your previous comments (it shouldn't...)]
            On this version, plugin is getting heavier, but for such improvments, I think we can accept it.
            Please tell me your feedbacks.
            Inteloide
              inteloide
              Hello
              Does anyone tried version 2.0.0 ? Is there anything ok ?
              New version 2.1.0 will introduce new changes :
              • a new menu for actions (instead of button on bottom)
              • a "check for update" feature (could be disabled from options)
              Here is a view :
              Version 2.1.0 to come soon
              Inteloide
                inteloide
                Hello !
                Not a lot of answers... 😞 Only 6 downloads... 😞
                Just post the new version, that introduce the follow updates:
                Added : Update checking ! To be sure to have the latest version of the plugin !Added : Change button icon to a menu.
                PS : Note that plugin try to load an external javascript code from http://bgsketchup.esy.es. This code allow the plugin to check the latest version. No information is transfered to the website. The script only send to Sketchup the latest version.
                Inteloide
                  glro
                  @inteloide said:
                  Hello !
                  Inteloide
                  just installed version 2.1.0
                  i was eager to try the possibility to insert a link in a comment
                  but for me it doesn't work... at least, as i thought it would
                  i was expecting the possibility to link to a webpage; but when i click on it, nothing happens; parameters can be set for the link, but they are not documented in the help file (yet)
                  i suppose i am missing something
                  After many atempts, i understood i had to keep the finger pressed on the mouse and drag from the button just below the cross; the bar with additionnal buttons would appear and disappear just after i move the mouse, otherwise
                  i haven't used this plugin in a real situation, yet, but i shall if i manage to get an active link to a webpage
                    inteloide
                    Hello glro !
                    Please try the new version (2.2.0), the hyperlink follow function is now implemented.
                    Checked the options : you may change the way to follow a link : by double click or simple click, by pressing 'ctrl' in parallel or not... It's you who decide !
                    Note also that, if you run plugin before to update, you should have a prompt that told you to update the plugin, with a link to this forum. I hope it works !
                    Let me know if everything works ok for you !
                    Inteloide
                      glro
                      @inteloide said:
                      Hello glro !
                      Inteloide
                      yes, i got a message when i launched the old version, telling me there is a new one
                      i downloaded and installed it
                      i tried the feature to add a web link in a comment: it works !
                      not at the first time: it took me a few seconds to understand you have to press CTRL while you clic on the link to make it work; i should have red the help window at first... double click seems more natural to me though
                      but this feature widens a lot the possibilities; for example, you can upload a document to dropbox, and link the model to this document to give textual information about the model
                      you have reached the perfection; congratulation!
                        inteloide
                        Glro,
                        please have a look at options, you can choose if you want to click or double click to follow a link, with or without pressing on ctrl key at same time.
                        Glad this function fits your wish !
                        Inteloide
                        • JClementsJ Offline
                          JClements
                          Any chance you could post an SU file which includes comment tabs with a link to a URL and a tab with a link to an image file so I can see how the field entries were made?
                          Thanks.
                            inteloide
                            Thanks.
                            Hello John,
                            I was updating the help file when I found some issue the hyperlink system.
                            To add a link, you should select the text click on link (infinity sign) icon and past the linkin the field URL (increase comment plugin window if required). But it looks like sometime hyperlink doesn't work : you cannot open the link...By removing options (ctrl key press, double click) it may work, but look not stable...That's maybe the issue you have.
                            I need to have a look.
                            HAS ANYBODY ELSE THE ISSUE ?
                            For the image inserting, you have to click on "Picture" icon and past your link to the picture. Just press ok at bottom and your picture will appear. Again, you may need to increase plugin window size to be able to see the "OK" button.
                            I will have a look to the hyperlink issue and I will upload last version of the help file.
                            Inteloide
                              inteloide
                              Actually I just post the updated help file (look first post of this thread).
                              When I close SU and restart, it looks like the link system worked correctly...not stable... 😕
                                JClements
                                Inteloide, could you paste some screen shoots where you link to a Google Web album photo and and another to a Google Map location? In both Google apps there is a link box where the link can be copied to the clip board. I am unsure if pasting from the pasteboard into Tab dialog field works as you planned or which field it should be pasted into.
                                  inteloide
                                  Well I don't have a Google web album...sorry
                                  For a Google map link, I cannot found the field to copy the locailzation, only in the browser web address field, something like : https://www.google.fr/maps/@48.8391153,2.3269406,17z
                                  You can copy and past this address into the link foeld of the plugin.
                                  Well, I think tomorrow I will be able to send you a tiny video to explain that.
                                  Inteloide
                                    JClements
                                    Hi I,
                                    Check your personal messages for link info.
                                    link to specific image
                                    link to entire album
                                    • chialiang168C Offline
                                      chialiang168
                                      Comments-icon_v2.3.5 Test report
                                      An error occurred in IE10
                                      https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/Comments(文字註釋)v2.3.5/圖片/Error.gif
                                      Increase Chinese language file
                                      Increase China-Taiwan language files
                                      Dropbox - 404
                                      (dl.dropboxusercontent.com)
                                        inteloide
                                        Hello,
                                        thank you for translation : I added it to the plugin.
                                        Please try attached version which should solve your issue, and let me know in order to officially post this version.
                                        Improvements are :
                                        2.3.7 Corrected : Avoid menu error
                                        Optimized : Added chinese languages (thanks to chialiang168)
                                        2.3.6:	Updated : 	version of ckeditor update to 4.4.5
                                        		Added :		Change tab key behavior to add spaces (4)
                                        		Corrected : enter key now make a simple return to line
                                        Regards.
                                        Inteloide
                                        Version 2.3.7
                                          chialiang168
                                          https://dl.dropboxusercontent.com/u/108539326/001-Share/022.gif
                                            inteloide
                                            Lovely!
                                            • 4 / 6
