    [Plugin] Add comments to your file
    104 Posts 20 Posters 30.7k Views 20 Watching
      alexanor
      @aerilius said:
      Can't you do calculations already in the operating system's calculator, in SketchUp's Ruby Console and in various Ruby Console plugins? You can then copy&paste the calculations that you want to keep.
      I do not want to open many windows in Sketchup. If this plugin can do "Add comments".
      Inteloide, thank you for the effort!
      • U
        unearthed
        Great plugin, very, very useful, and seconding the idea of building a/the calculator into the comment box.
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
        • inteloideI
          inteloide
          Hello !
          I'm back after one week of holidays in Rome. Such a nice town !
          So if I understand correctly your request, you want me to add a button that allow you to have a calculator, like Windows'one, in the "add comment" plugin, without openning another window, correct ?
          If yes does anybody knows a free plugin I can insert in my script ? This will make my work easier !
          Inteloide
          Humanity will do a huge step when the IT professionals will understand that computers are tools...
          • inteloideI
            inteloide
            Let me guess, you look for something like this :
            Future version 1.7.0
            Isn't it ?
            I'm close to release it...
            I'll try to link it with VCB.
            Inteloide
              alexanor
              Yes, yes! Has what you need! Great!
              • inteloideI
                inteloide
                Just post the new version for trial.
                Note that you can type formula directly in the calculator "screen" area.
                Updates :
                1.7.0:	Added :		Calculator feature added ([http://www.supportduweb.com/scripts_tutoriaux-code-source-12-calculatrice-en-javascript-avec-bouttons.html](http://www.supportduweb.com/scripts_tutoriaux-code-source-12-calculatrice-en-javascript-avec-bouttons.html))
                		Added :		Rounded corner for tabs
                		Modified :	Selecting and mouse over colors
                		Optimized :	Improve tab color display
                		Optimized :	Optimize CSS code
                		Corrected : Small bug in tab scrolling when resizing the window
                Main
                Inteloide
                  alexanor
                  Thank you Inteloide for your work!
                  There are a few comments on the plugin.
                  If you enter a value in the calculator and press the button "Insert result in current tab", then the value is inserted into the Notes box and the cursor remains in the value column. You need to insert your cursor after moves to a new line, as it is done with the button "Add current date and time.
                  When you click "Insert result in current tab" calculator is turned off, is not useful when there is a need to perform calculations, you need to open the calculator.
                  Propose to add another button in the calculator. The button will turn on/off the ability to log the current note values as a calculator. For example, enter in the Calculator 2 +2 = 4, and this article is written 2 +2 = 4. I think such a feature would be useful.
                  I apologize if something is not clear, since I use a translator and I know English not well.
                  Success in everything!
                  P.s. Why does not update the plugin in the "SketchUcation Plugin Store"
                  http://f5.s.qip.ru/qGVcUGst.png
                  • inteloideI
                    inteloide
                    Hello Alexanor,
                    Thank you for your post.
                    I'am currently abroad but I will make some update when comming back to France.
                    I think I will add more options or more buttons to let people choose.Options would be :
                    • close calculator after result inserted
                    • add return to line after result inserted
                    • show calculation formula
                    I'm also working on having the possibility to have the text area with colors, links... But I think it will reduce such optimizations as I will use a script not developped by me.
                    But let's see.
                    About the fact thag plugin is not update in the store, it's just because I post it on forum before store to avoid publishing plugin with big error inside.Once stable, I do an official release. That the way I work.
                    I keep you informed soon !
                    Inteloide (in direct from Tchek Republic)
                      alexanor
                      All clear! So we will wait for new updates with new features!
                      Have a good trip and all the best to you and your family.
                      • inteloideI
                        inteloide
                        Hello,
                        Just work a bit on plugin (lots of hours actually... 😉 )
                        I integrated the CKEditor javascript code, that allow to have rich text editor.
                        Please find here an overview of the result :
                        Version 2.0.0
                        Just one thing that worry me is that the toolbar icons can take a lots of place :
                        Too much place for toolbar
                        Pending also to add options required by alexanor.
                        Inteloide
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          Maybe make your design responsive, so that when the dialog is too narrow, these icons collapse into single icons that pop up a menu with all the other icons nested?
                          • inteloideI
                            inteloide
                            Hello !
                            Just post the new version (on first post), with follwing updates :
                            2.0.0: Added : Change text editor to CKEditor, to add possibilty to have rich text format
                            Added : Function to add calculator formula and result in the text area
                            Added : Options to close or not the calculator after result inserting
                            Removed : Option to show bottom of content (could not program it with CKEditor)
                            Corrected : Missing tab action button translation for last tab.
                            Optimized : Change action buttons size
                            %(#FF0000)[Please note that this version is for test : lots of modifications have been introduced.
                            Pay attention not to lose your previous comments (it shouldn't...)]
                            On this version, plugin is getting heavier, but for such improvments, I think we can accept it.
                            Please tell me your feedbacks.
                            Inteloide
                            • inteloideI
                              inteloide
                              Hello
                              Does anyone tried version 2.0.0 ? Is there anything ok ?
                              New version 2.1.0 will introduce new changes :
                              • a new menu for actions (instead of button on bottom)
                              • a "check for update" feature (could be disabled from options)
                              Here is a view :
                              Version 2.1.0 to come soon
                              Inteloide
                              • inteloideI
                                inteloide
                                Hello !
                                Not a lot of answers... 😞 Only 6 downloads... 😞
                                Just post the new version, that introduce the follow updates:
                                Added : Update checking ! To be sure to have the latest version of the plugin !Added : Change button icon to a menu.
                                PS : Note that plugin try to load an external javascript code from http://bgsketchup.esy.es. This code allow the plugin to check the latest version. No information is transfered to the website. The script only send to Sketchup the latest version.
                                Inteloide
                                • G
                                  glro
                                  @inteloide said:
                                  Hello !
                                  Inteloide
                                  just installed version 2.1.0
                                  i was eager to try the possibility to insert a link in a comment
                                  but for me it doesn't work... at least, as i thought it would
                                  i was expecting the possibility to link to a webpage; but when i click on it, nothing happens; parameters can be set for the link, but they are not documented in the help file (yet)
                                  i suppose i am missing something
                                  After many atempts, i understood i had to keep the finger pressed on the mouse and drag from the button just below the cross; the bar with additionnal buttons would appear and disappear just after i move the mouse, otherwise
                                  i haven't used this plugin in a real situation, yet, but i shall if i manage to get an active link to a webpage
                                  • inteloideI
                                    inteloide
                                    Hello glro !
                                    Please try the new version (2.2.0), the hyperlink follow function is now implemented.
                                    Checked the options : you may change the way to follow a link : by double click or simple click, by pressing 'ctrl' in parallel or not... It's you who decide !
                                    Note also that, if you run plugin before to update, you should have a prompt that told you to update the plugin, with a link to this forum. I hope it works !
                                    Let me know if everything works ok for you !
                                    Inteloide
                                    • G
                                      glro
                                      @inteloide said:
                                      Hello glro !
                                      Inteloide
                                      yes, i got a message when i launched the old version, telling me there is a new one
                                      i downloaded and installed it
                                      i tried the feature to add a web link in a comment: it works !
                                      not at the first time: it took me a few seconds to understand you have to press CTRL while you clic on the link to make it work; i should have red the help window at first... double click seems more natural to me though
                                      but this feature widens a lot the possibilities; for example, you can upload a document to dropbox, and link the model to this document to give textual information about the model
                                      you have reached the perfection; congratulation!
                                      • inteloideI
                                        inteloide
                                        Glro,
                                        please have a look at options, you can choose if you want to click or double click to follow a link, with or without pressing on ctrl key at same time.
                                        Glad this function fits your wish !
                                        Inteloide
                                        • JClementsJ
                                          JClements
                                          Any chance you could post an SU file which includes comment tabs with a link to a URL and a tab with a link to an image file so I can see how the field entries were made?
                                          Thanks.
                                          • inteloideI
                                            inteloide
                                            Thanks.
                                            Hello John,
                                            I was updating the help file when I found some issue the hyperlink system.
                                            To add a link, you should select the text click on link (infinity sign) icon and past the linkin the field URL (increase comment plugin window if required). But it looks like sometime hyperlink doesn't work : you cannot open the link...By removing options (ctrl key press, double click) it may work, but look not stable...That's maybe the issue you have.
                                            I need to have a look.
                                            HAS ANYBODY ELSE THE ISSUE ?
                                            For the image inserting, you have to click on "Picture" icon and past your link to the picture. Just press ok at bottom and your picture will appear. Again, you may need to increase plugin window size to be able to see the "OK" button.
                                            I will have a look to the hyperlink issue and I will upload last version of the help file.
                                            Inteloide
                                            • 4 / 6
