    [Plugin] Add comments to your file
    104 Posts 20 Posters 30.7k Views 20 Watching
    • inteloideI
      inteloide
      Hello Alexanor,
      Thank you for your post.
      I'am currently abroad but I will make some update when comming back to France.
      I think I will add more options or more buttons to let people choose.Options would be :
      • close calculator after result inserted
      • add return to line after result inserted
      • show calculation formula
      I'm also working on having the possibility to have the text area with colors, links... But I think it will reduce such optimizations as I will use a script not developped by me.
      But let's see.
      About the fact thag plugin is not update in the store, it's just because I post it on forum before store to avoid publishing plugin with big error inside.Once stable, I do an official release. That the way I work.
      I keep you informed soon !
      Inteloide (in direct from Tchek Republic)
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
        alexanor
        All clear! So we will wait for new updates with new features!
        Have a good trip and all the best to you and your family.
        • inteloideI
          inteloide
          Hello,
          Just work a bit on plugin (lots of hours actually... 😉 )
          I integrated the CKEditor javascript code, that allow to have rich text editor.
          Please find here an overview of the result :
          Version 2.0.0
          Just one thing that worry me is that the toolbar icons can take a lots of place :
          Too much place for toolbar
          Pending also to add options required by alexanor.
          Inteloide
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Maybe make your design responsive, so that when the dialog is too narrow, these icons collapse into single icons that pop up a menu with all the other icons nested?
            • inteloideI
              inteloide
              Hello !
              Just post the new version (on first post), with follwing updates :
              2.0.0: Added : Change text editor to CKEditor, to add possibilty to have rich text format
              Added : Function to add calculator formula and result in the text area
              Added : Options to close or not the calculator after result inserting
              Removed : Option to show bottom of content (could not program it with CKEditor)
              Corrected : Missing tab action button translation for last tab.
              Optimized : Change action buttons size
              %(#FF0000)[Please note that this version is for test : lots of modifications have been introduced.
              Pay attention not to lose your previous comments (it shouldn't...)]
              On this version, plugin is getting heavier, but for such improvments, I think we can accept it.
              Please tell me your feedbacks.
              Inteloide
              • inteloideI
                inteloide
                Hello
                Does anyone tried version 2.0.0 ? Is there anything ok ?
                New version 2.1.0 will introduce new changes :
                • a new menu for actions (instead of button on bottom)
                • a "check for update" feature (could be disabled from options)
                Here is a view :
                Version 2.1.0 to come soon
                Inteloide
                • inteloideI
                  inteloide
                  Hello !
                  Not a lot of answers... 😞 Only 6 downloads... 😞
                  Just post the new version, that introduce the follow updates:
                  Added : Update checking ! To be sure to have the latest version of the plugin !Added : Change button icon to a menu.
                  PS : Note that plugin try to load an external javascript code from http://bgsketchup.esy.es. This code allow the plugin to check the latest version. No information is transfered to the website. The script only send to Sketchup the latest version.
                  Inteloide
                  • G
                    glro
                    @inteloide said:
                    Hello !
                    Inteloide
                    just installed version 2.1.0
                    i was eager to try the possibility to insert a link in a comment
                    but for me it doesn't work... at least, as i thought it would
                    i was expecting the possibility to link to a webpage; but when i click on it, nothing happens; parameters can be set for the link, but they are not documented in the help file (yet)
                    i suppose i am missing something
                    After many atempts, i understood i had to keep the finger pressed on the mouse and drag from the button just below the cross; the bar with additionnal buttons would appear and disappear just after i move the mouse, otherwise
                    i haven't used this plugin in a real situation, yet, but i shall if i manage to get an active link to a webpage
                    • inteloideI
                      inteloide
                      Hello glro !
                      Please try the new version (2.2.0), the hyperlink follow function is now implemented.
                      Checked the options : you may change the way to follow a link : by double click or simple click, by pressing 'ctrl' in parallel or not... It's you who decide !
                      Note also that, if you run plugin before to update, you should have a prompt that told you to update the plugin, with a link to this forum. I hope it works !
                      Let me know if everything works ok for you !
                      Inteloide
                      • G
                        glro
                        @inteloide said:
                        Hello glro !
                        Inteloide
                        yes, i got a message when i launched the old version, telling me there is a new one
                        i downloaded and installed it
                        i tried the feature to add a web link in a comment: it works !
                        not at the first time: it took me a few seconds to understand you have to press CTRL while you clic on the link to make it work; i should have red the help window at first... double click seems more natural to me though
                        but this feature widens a lot the possibilities; for example, you can upload a document to dropbox, and link the model to this document to give textual information about the model
                        you have reached the perfection; congratulation!
                        • inteloideI
                          inteloide
                          Glro,
                          please have a look at options, you can choose if you want to click or double click to follow a link, with or without pressing on ctrl key at same time.
                          Glad this function fits your wish !
                          Inteloide
                          • JClementsJ
                            JClements
                            Any chance you could post an SU file which includes comment tabs with a link to a URL and a tab with a link to an image file so I can see how the field entries were made?
                            Thanks.
                            • inteloideI
                              inteloide
                              Thanks.
                              Hello John,
                              I was updating the help file when I found some issue the hyperlink system.
                              To add a link, you should select the text click on link (infinity sign) icon and past the linkin the field URL (increase comment plugin window if required). But it looks like sometime hyperlink doesn't work : you cannot open the link...By removing options (ctrl key press, double click) it may work, but look not stable...That's maybe the issue you have.
                              I need to have a look.
                              HAS ANYBODY ELSE THE ISSUE ?
                              For the image inserting, you have to click on "Picture" icon and past your link to the picture. Just press ok at bottom and your picture will appear. Again, you may need to increase plugin window size to be able to see the "OK" button.
                              I will have a look to the hyperlink issue and I will upload last version of the help file.
                              Inteloide
                              • inteloideI
                                inteloide
                                Actually I just post the updated help file (look first post of this thread).
                                When I close SU and restart, it looks like the link system worked correctly...not stable... 😕
                                • JClementsJ
                                  JClements
                                  Inteloide, could you paste some screen shoots where you link to a Google Web album photo and and another to a Google Map location? In both Google apps there is a link box where the link can be copied to the clip board. I am unsure if pasting from the pasteboard into Tab dialog field works as you planned or which field it should be pasted into.
                                  • inteloideI
                                    inteloide
                                    Well I don't have a Google web album...sorry
                                    For a Google map link, I cannot found the field to copy the locailzation, only in the browser web address field, something like : https://www.google.fr/maps/@48.8391153,2.3269406,17z
                                    You can copy and past this address into the link foeld of the plugin.
                                    Well, I think tomorrow I will be able to send you a tiny video to explain that.
                                    Inteloide
                                    • JClementsJ
                                      JClements
                                      Hi I,
                                      Check your personal messages for link info.
                                      link to specific image
                                      link to entire album
                                      • chialiang168C
                                        chialiang168
                                        Comments-icon_v2.3.5 Test report
                                        An error occurred in IE10
                                        https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/Comments(文字註釋)v2.3.5/圖片/Error.gif
                                        Increase Chinese language file
                                        Increase China-Taiwan language files
                                        Dropbox - 404
                                        (dl.dropboxusercontent.com)
                                        • inteloideI
                                          inteloide
                                          Hello,
                                          thank you for translation : I added it to the plugin.
                                          Please try attached version which should solve your issue, and let me know in order to officially post this version.
                                          Improvements are :
                                          2.3.7 Corrected : Avoid menu error
                                          Optimized : Added chinese languages (thanks to chialiang168)
                                          2.3.6:	Updated : 	version of ckeditor update to 4.4.5
                                          		Added :		Change tab key behavior to add spaces (4)
                                          		Corrected : enter key now make a simple return to line
                                          Regards.
                                          Inteloide
                                          Version 2.3.7
                                          • chialiang168C
                                            chialiang168
                                            https://dl.dropboxusercontent.com/u/108539326/001-Share/022.gif
                                            • 4 / 6
