    Slope analysis of 2d Autocad contour drawing
    23 Posts 7 Posters 5.8k Views 7 Watching
    • jeff hammondJ
      if you read through the color by slope thread, you'll see that TIG has written the code to get the desired function.. it hasn't been added to the published version though..
      i'm going to assume neither chris nor tig are going to combine it or else it would of been done already.. most of the requests in the thread were to have the functionality which tig addressed.
      basically, someone with some ruby knowledge will have to explain (in simple terms) how to add tig's code to color by slope..
      (i just tried and failed miserably.. πŸ˜† )
      • john2J
        john2
        @krisidious said:
        Perhaps you could use Photoshop or Gimp to replace colors?
        Oh wait. It's not letting you dictate certain slopes. just it's own determination huh? I think this is going to be something that doesn't exist.
        Yes, it is determining by itself. Auto mode, i just enter rgb values and it does the thing by itself.
        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
          I've PM's you an adjusted version of Chris's RB that should do what you want...
          • KrisidiousK
            Krisidious
            Oh do share Tig...
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              Oh it's Chris' plugin adjusted... I understand. 😞
              By: Kristoff Rand
              • john2J
                john2
                Thanks a lot!
                There's one little problem.
                I made the terrain using topo plugin of fredo. The faces that i colour using modified plugin are coming in ugly triangular fashion. What can i do to make the colour smoother?
                  You can't. πŸ˜•
                  The facets are individually colored depending on their slope %.
                  If you make a more subdivided mesh [with finer settings or using say Artisan to post-process it ?] the facets will get smaller... but they'll always be small triangles of a single color, no matter how small they get.
                  You don't want to go too fine as the extra geometry will slow down SketchUp significantly...
                  There is way of using a 'projected' graduated textured material initially on a large vertical face to show faces of differing heights smoothly transitioning - from dark to light say - on a terrain mesh.
                  https://3dwarehouse.sketchup.com/model.html?redirect=1%26amp;mid=77627ea5941ff3d387ecd6083924dba
                  http://sketchucation.com/forums/viewtopic.php?p=149747#p149747
                  But if you think about it a little... you can't do the same with 'sloped' facets because those can occur anywhere in 'elevation'...
                  How could you ever get the right effect between two adjacent slopes which could be at any other slope compared to the first one you considered ? Also every triangle would usually have three neighbors each needing a different transitional graded color/texture and then those in turn etc...
                  • john2J
                    john2
                    Okay, so what is the most visually cleanest way to do this?
                    Subdividing with Artisan only or any other free alternative?
                    And I'd like to thank everyone who guided me to this stage.
                    I've visited this forum after a really long time and getting a specially customized plugin messages to me, simply blew my mind away.
                    Thank you TIG sir and everyone
                    • KrisidiousK
                      Krisidious
                      This place is mind blowing... It's a fantastic community of dedicated folks who love to help. It's the best forum I've ever known. Tig is one of our Rock Stars... His personal contributions to our community are staggering.
                      By: Kristoff Rand
                      • O
                        originalsurfmex
                        I am looking for the exact same thing. Would you mind PM'ing me a modified .rb as well? Thanks so much for constantly helping out the community.
                        • srxS
                          srx
                          When reading this a thought came to my mind - how does SketchUp shadows work? Isn't it a graphic representation of the angle between sun and the face. And it is smooth. The same could be used in this case. Sorry if I am talking nonsense. I am not the TIG πŸ˜‰
                          www.saurus.rs
                          • 2 / 2
