    360 VR questions
    extensions
    41 Posts 11 Posters 6.7k Views 11 Watching
    • PixeroP Offline
      Pixero
      Yes but it's an older version. I believe the price has gone up since then.
      • soloS Offline
        More questions.
        So I have a pano render, I have software to create it, I need to be able to embed it on a word press website as host then be able to show on a companies face Book page, how do i do this?
        • O Offline
          otb designworks
          I'd be interested in hearing a solution to this as well. I have never seen a virtual tour linked into Facebook and always thought it couldn't be done.
          I resort to producing an animation spinning around inside the tour (screen capture, sometimes native SU, etc) and hosting it on Youtube and then cross linking on Facebook. You lose the client navigation though, which is not ideal
          Cheers, Chuck
          OTB Designworks is on Youtube
          • FrederikF Offline
            Frederik
            You don't mention what software you finally decided to use for creating the pano views...
            If you did go with Pano2VR, there's a plugin which makes it easy to embed on a WordPress website... πŸ˜„
            Check out the http://ggnome.com/wiki/WordPress_Plugin
            Cheers
            Kim Frederik
            • AdamBA Offline
              AdamB
              Peoples,
              If you have software that can render 6 face skybox (like LightUp), you don't need special processing software - you can just embed it as WebGL in a HTML webpage.
              Here's a quick test I wrote: http://light-up.co.uk/pano.html
              Adam
              • PixeroP Offline
                Pixero
                But web GL doesn't work in all browsers and on all platforms. (IOS for example.)
                • FrederikF Offline
                  Frederik
                  Pixero is right...
                  Besides, Solo asked specifically for an easy way to embed on his WordPress website...
                  Perhaps an idea for you, Adam, to make a WP plugin, which would make it even easier to embed something made with LightUp on a WP website... πŸ˜‰
                  Hhmmm... It doesn't show anything on my screen... πŸ˜•
                  Cheers
                  Kim Frederik
                  • AdamBA Offline
                    AdamB
                    Frederick: Yes, it requires a browser that supports WebGL (and has it enabled).
                    [EDIT: Try again as I was using a file format Chrome didn't like.]
                    AFAIK The use of ANY plugins is going to be soon banned by browsers, so WebGL will be the only solution eventually. Not saying that is a GoodThing, just that its happening.
                    • PixeroP Offline
                      Pixero
                      What I meant was that the solution one should choose depends heavily on who your enduser is.
                      If you are aiming at "anyone" then the solution should work for as many as possible without special hardware and software requirements.
                      What I used for my panoramas was flash for those who had and html5 for the rest. Pano2VR can export to both and detect which version to use. It can also do a low resolution version for phones.
                      • AdamBA Offline
                        AdamB
                        Hmm.. iPhones do not support WebGL (aka html5) and also do not support Flash. So I wonder what Pano2VR (which is a great product that I also use) outputs for phones..
                        Adam
                        • FrederikF Offline
                          Frederik
                          I tried using Firefox and only saw a black box and then the text...
                          Any way... Now it works and I see the model... πŸ‘
                          Not sure I get you here... πŸ˜•
                          A plugin for WordPress isn't something special like a plugin for a browser...
                          Do you have any knowledge about WordPress...?
                          A plugin simply makes it easier for the average Joe to embed content on his/her website...
                          Most people are unable to make even simple web-code, thus a CMS is required...
                          Please remember that WordPress isn't just a blog-tool... It was, but today it's nothing less than the most widely used CMS in the world...
                          Cheers
                          Kim Frederik
                          • soloS Offline
                            Getting a VR to work with Wordpress is simple enough, I just upload the .mov file and using a copy and paste script I can easily host the pano, however the issue seems to be trying to get it onto FaceBook, Facebook has created the hurdle there and unless I can get my site white listed with them and use some meta scripts there is no way I can do it, in fact I have been unable to find an example of anyone actually succeeding. So the best one can do is a link at this point, I will investigate Google+ as I'm sure they have a way.
                            • AdamBA Offline
                              AdamB
                              Solo,
                              You can just post a URL to your website page that contains the QuickTime VR (aka .mov) file.
                              • AdamBA Offline
                                AdamB
                                Yes, I develop websites using it and know a lot about how it works under the hood.
                                The problem is not WP or WP plugins. The problem is that browsers handle text and images using HTML, however to deliver interactive graphics they need some help - to date this has come from a "low-level" plugin that extends the functions of your browser. Adobe Flash is a common plugin of this type. Unity player is another example. LightUp WebPlayer is another example of a plugin that extends the functions of your web browser - in this case it adds functions to draw realtime 3D .luca files and know what to do when you drag and drop a .luca file on your browser.
                                However, there has been a push to ban all these plugins and require using HTML5 / WebGL. While that might be a glorious plan in Google HQ, but as Pixero points out, the reality is that not all browsers support it. So deploying interactive 3D that works everywhere is currently not possible using 1 solution.
                                WP plugins are something much lighter and just some templates that make it simple to insert content into your WP webpages that would otherwise involve cutting and pasting HTML.
                                So having a WP plugin does not solve the problem. 😞
                                • soloS Offline
                                  @adamb said:
                                  Solo,
                                  Sure, here is a test version on my site, I still need to do changes and add details and rooms for final.
                                  There is a little noise.
                                  404 Not Found
                                  (www.solos-art.com)
                                  • PixeroP Offline
                                    Pixero
                                    Adam
                                    My VR presentation runs on iOS with html5 but without web GL:
                                    http://whiteclients.se/obo/vivalla/
                                    • soloS Offline
                                      @pixero said:
                                      Adam
                                      Yours are amazing, I need to learn how to get all the fluff you have, the map and hotspots.
                                      • olisheaO Offline
                                        olishea
                                        stunning work pixero! bravo!
                                        would be nice if we could texture bake the entire model with several spherical panoramas.
                                        oli
                                        • cottyC Offline
                                          cotty
                                          krpano uses HTML5 (and/or webGL) too and many devices are supported this way...
                                          my SketchUp gallery
                                          • FrederikF Offline
                                            Frederik
                                            It's fairly easy with Pano2VR... πŸ˜‰
                                            @Adam: I didn't know all that... I suppose I got a little confused by your comment about plugins... I interpreted it as if you didn't know what plugins does in WP... 😳 πŸ˜„
                                            Cheers
                                            Kim Frederik
                                            • 1 / 3
