    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.6k Views 110 Watching
    • I Offline
      ivreich
      @jiminy-billy-bob said:
      Does it happen in every file? Even a brand new one?
      Yup, even with brand new files. I'm also having problems creating layer groups and new layers...they either simply won't create or when they are created they can't be renamed, and nothing can be added to them, visibility controls won't work etc.
      Sometimes I lose all of the layer group structures I've created previously as well. This happens when I open more than one session of sketchup side by side...
      Error message when I try to create new layer groups attached.
      Cheers
      Joel
      Error messge when creating new group
      • JQLJ Offline
        JQL
        Side by side you say?... I'll double check on that as I'm permanently doing it too!
        With the new files I can create groups again though.
        www.casca.pt
        Visit us on facebook!
          ckho1985
          This is getting better and better! many thanks!!
          small hick-up here. Is that the Layer Status does not work occasionally. I can still click it, but it won't update the layers I want to see.
          Running on SU2014 on Mac
            matt.gordon320
            Ok guys, I found the issue. I'll release a fixed version ASAP.
            In the meantime, you can replace the two files attached in the folder
            Awesome! That seems to be it! I think everything is working now, so I'll start testing it out! Thanks again, this is a fantastic extension.
            -Matt
            • jiminy-billy-bobJ Offline
              jiminy-billy-bob
              I guess when having more than one models opened? If so, this will be fixed in the next release.
              • EdsonE Offline
                Edson
                I started getting these error messages. is there a way to fix it? I am also not being able to add groups.
                http://www.mahfuz.arq.br
                  jiminy-billy-bob
                  Try this: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=53906%26amp;start=510#p525061
                  • EdsonE Offline
                    Edson
                    yep, it worked. no more error messages and I am able to create groups again.
                    however, I still have an old complaint: LP does not remember where I place its panel: at start it always opens on the same spot on the screen. if the native windows can remember where they were placed last why can't yours?
                    once more, thanks for a wonderful plugin.
                      jiminy-billy-bob
                      Because this is bugged in OSX. I've not yet managed to find a workaround.
                      Solution: Use Sketchup in windows 😄
                      • EdsonE Offline
                        Edson
                        no problem. it is a minor inconvenience compared to what your plugin offers.
                        I will pretend I did not read your suggestion to switch to windows... 😉
                          jiminy-billy-bob
                          New version 1.1.1 !
                          Changelog :
                          • Fixed a major issue that would freeze Layers Panel when using several features (e.g adding a group)
                          • Added an API that allows other plugins to interact with Layers Panel
                          Download in the plugin store !
                          • F Offline
                            function
                            cool stuff, thanks for continued development~!
                            • EdsonE Offline
                              Edson
                              jbb,
                              now that I am using LP as my main access to layers, I found another glitch which may or may not be caused by some oddity inherent to mac os. but I thought you should know of it anyway.
                              two things. one is the fact that I cannot select adjacent layers by shift-clicking the top and the bottom ones. it happens once in a long while. in general I have to command-click each layer to get a group selected at once.
                              the other is that, differently from the native layers window, if have a few layers selected, clicking on the eye to switch them off succeeds in switching only one off, not all of the selected layers as intended. as a result, to do that I revert to native window.
                              can this be fixed?
                              best regards.
                                jiminy-billy-bob
                                This is weird, could you try to find out in which case it works?
                                In the meantime, you can also click and drag the mouse to draw a rectangle, just like you would to in SU to select entities.
                                You need to shift-click on the eye.
                                Take a look at shortcuts: http://sketchucation.com/plugin/751-layers_panel (See "Quick start")
                                • EdsonE Offline
                                  Edson
                                  yes to both. click and drag works as well as shift-click. thanks.
                                    RBSTEAL
                                    Hi there awesome plugin! Can you add twilight support at some point?
                                    Regards.
                                      jiminy-billy-bob
                                      Just like Thea, I can't trigger the Twilight render from ruby, so I can't add support for it.
                                      It would have to be Twilight that reads Layers Panel data.
                                      • EdsonE Offline
                                        Edson
                                        jbb,
                                        One more question. can Layers Panel deal with special characters from other languages? in my case, Portuguese is my native tongue and LP is not allowing me to write well in it.
                                        As an example, when I write Proteção it comes out like this: Prote√ß√£o.
                                        Any thoughts on that?
                                        Cheers.
                                          matt.gordon320
                                          Hi JBB,
                                          I have a couple more things to report back. LP is working well in the office environment so far. There are a couple things that cause no issue, but aren't working 100% for some reason.
                                          On my station, everything works perfectly. I have full admin access to the folder which the plugin network runs from. The users to whom I've rolled the plugin out, who have read only access, cannot alter colors for the LP layers, nor do the color previews show. The little grip by which the color is chosen and the layer is moved shows as grey only.
                                          Let me know what else I can provide or be of any help!
                                          Thanks,
                                          Matt
                                            jiminy-billy-bob
                                            @matt.gordon320 said:
                                            On my station, everything works perfectly. I have full admin access to the folder which the plugin network runs from. The users to whom I've rolled the plugin out, who have read only access, cannot alter colors for the LP layers, nor do the color previews show. The little grip by which the color is chosen and the layer is moved shows as grey only.t
                                            I bet you have SU2014 and the other user runs SU2013? 😄
                                            SU2014 introduced a new API method which allows me to add colors to LP. But it was non-existant in earlier versions.
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 33
                                            • 34
                                            • 28 / 34
