    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      I don't think so, but I don't know where it could come from.
      So, maybe...
      • I
        ivreich
        @jiminy-billy-bob said:
        Does it happen in every file? Even a brand new one?
        Yup, even with brand new files. I'm also having problems creating layer groups and new layers...they either simply won't create or when they are created they can't be renamed, and nothing can be added to them, visibility controls won't work etc.
        Sometimes I lose all of the layer group structures I've created previously as well. This happens when I open more than one session of sketchup side by side...
        Error message when I try to create new layer groups attached.
        Cheers
        Joel
        Error messge when creating new group
        • JQLJ
          JQL
          Side by side you say?... I'll double check on that as I'm permanently doing it too!
          With the new files I can create groups again though.
          www.casca.pt
          Visit us on facebook!
          • C
            ckho1985
            This is getting better and better! many thanks!!
            small hick-up here. Is that the Layer Status does not work occasionally. I can still click it, but it won't update the layers I want to see.
            Running on SU2014 on Mac
              matt.gordon320
              Ok guys, I found the issue. I'll release a fixed version ASAP.
              In the meantime, you can replace the two files attached in the folder
              Awesome! That seems to be it! I think everything is working now, so I'll start testing it out! Thanks again, this is a fantastic extension.
              -Matt
              • jiminy-billy-bobJ
                jiminy-billy-bob
                I guess when having more than one models opened? If so, this will be fixed in the next release.
                • EdsonE
                  Edson
                  I started getting these error messages. is there a way to fix it? I am also not being able to add groups.
                  http://www.mahfuz.arq.br
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    Try this: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=53906%26amp;start=510#p525061
                    • EdsonE
                      Edson
                      yep, it worked. no more error messages and I am able to create groups again.
                      however, I still have an old complaint: LP does not remember where I place its panel: at start it always opens on the same spot on the screen. if the native windows can remember where they were placed last why can't yours?
                      once more, thanks for a wonderful plugin.
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Because this is bugged in OSX. I've not yet managed to find a workaround.
                        Solution: Use Sketchup in windows 😄
                        • EdsonE
                          Edson
                          no problem. it is a minor inconvenience compared to what your plugin offers.
                          I will pretend I did not read your suggestion to switch to windows... 😉
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            New version 1.1.1 !
                            Changelog :
                            • Fixed a major issue that would freeze Layers Panel when using several features (e.g adding a group)
                            • Added an API that allows other plugins to interact with Layers Panel
                            Download in the plugin store !
                            • F
                              function
                              cool stuff, thanks for continued development~!
                              • EdsonE
                                Edson
                                jbb,
                                now that I am using LP as my main access to layers, I found another glitch which may or may not be caused by some oddity inherent to mac os. but I thought you should know of it anyway.
                                two things. one is the fact that I cannot select adjacent layers by shift-clicking the top and the bottom ones. it happens once in a long while. in general I have to command-click each layer to get a group selected at once.
                                the other is that, differently from the native layers window, if have a few layers selected, clicking on the eye to switch them off succeeds in switching only one off, not all of the selected layers as intended. as a result, to do that I revert to native window.
                                can this be fixed?
                                best regards.
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  This is weird, could you try to find out in which case it works?
                                  In the meantime, you can also click and drag the mouse to draw a rectangle, just like you would to in SU to select entities.
                                  You need to shift-click on the eye.
                                  Take a look at shortcuts: http://sketchucation.com/plugin/751-layers_panel (See "Quick start")
                                  • EdsonE
                                    Edson
                                    yes to both. click and drag works as well as shift-click. thanks.
                                      RBSTEAL
                                      Hi there awesome plugin! Can you add twilight support at some point?
                                      Regards.
                                      • jiminy-billy-bobJ
                                        jiminy-billy-bob
                                        Just like Thea, I can't trigger the Twilight render from ruby, so I can't add support for it.
                                        It would have to be Twilight that reads Layers Panel data.
                                        • EdsonE
                                          Edson
                                          jbb,
                                          One more question. can Layers Panel deal with special characters from other languages? in my case, Portuguese is my native tongue and LP is not allowing me to write well in it.
                                          As an example, when I write Proteção it comes out like this: Prote√ß√£o.
                                          Any thoughts on that?
                                          Cheers.
                                            matt.gordon320
                                            Hi JBB,
                                            I have a couple more things to report back. LP is working well in the office environment so far. There are a couple things that cause no issue, but aren't working 100% for some reason.
                                            On my station, everything works perfectly. I have full admin access to the folder which the plugin network runs from. The users to whom I've rolled the plugin out, who have read only access, cannot alter colors for the LP layers, nor do the color previews show. The little grip by which the color is chosen and the layer is moved shows as grey only.
                                            Let me know what else I can provide or be of any help!
                                            Thanks,
                                            Matt
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 33
                                            • 34
                                            • 28 / 34
