    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.1k Views 172 Watching
      You have float values saved as 0,8 rather than 0.8 so the commas breaks the conversion of the read_defaults string back into the hash ! There are some commas it needs, and some that should be '.' !
      You use a commas as your decimal separator rather than the '.', but Ruby uses '.' always...
      It should be something like:
      {:gravity=>{:vector=>[0, 0, -1], :weight=>1,0}, :branch=>{:radius=>0,8, :nodesize=>3, :detail=>4, :probability=>0,97, :floatlength=>150, :spread=>1,0, :pattern=>0,8}, :wind=>{:weight=>0,1}, :random=>{:weight=>0,3}, :adhesion=>{:weight=>0,2, :max_adhesion_distance=>50}, :legacy=>{:weight=>0,8}, :leaf=>{:probability=>0,75, :size=>5,0, :pattern=>1}}
      but you have:
      {:gravity=>{:vector=>[0, 0, -1], :weight=>1,0}, :branch=>{:radius=>0.8, :nodesize=>3, :detail=>4, :probability=>0.97, :floatlength=>150, :spread=>1,0, :pattern=>0.8}, :wind=>{:weight=>0.1}, :random=>{:weight=>0.3}, :adhesion=>{:weight=>0.2, :max_adhesion_distance=>50}, :legacy=>{:weight=>0.8}, :leaf=>{:probability=>0.75, :size=>5,0, :pattern=>1}}
      If you edit the file 'LiveVector_core.rb' with a plain-text editor and find line #61 that says:
      return eval(str)
      and now insert these lines of code just in front of it, thus:
      split=str.split('=>') split.dup.each_with_index{|e, i| next unless e=~/^[0-9]/; next unless e.count(',')==2; split[i]=e.sub(/,/, '.') } str=split.join('=>')
      then
      return eval(str)
      This should change the ',' to '.' - but only in the numbers like 0,8 >>> 0.8 but vector arrays and simple integers are ignored.
      The hash should now eval OK... πŸ˜’
      • OxerO Offline
        Oxer
        Hi TIG,
        I done that you say me but it continue with the same Ruby Console Error, after try all possibilities (uninstall all plugins, delete SU preferences, etc) and to see that the problem persisted I have opted for delete SU2013 folder, all preferences (SU preferences, all plugins preferences, hide files related) and reinstall SU and the plugins and voila! now all work fine.
        I had time to try more things, perhaps it were a corrupt preference file or a conflict with other plugin, I don't know, mystery! ❓
        • JBJDesignsJ Offline
          JBJDesigns
          @krisidious said:
          Gravity might be your problem. Try setting it lower... Somewhere earlier in these posts there are default settings.
          The gravity settings were set at various levels, i.e., low, mid and high values. The leaves still droop. Also, I haven't heard anything back about the leaves turning up in every new project I start as components. Although it is now easier to "delete" the leaved and purge from materials, it's still annoying. Great idea, but I'd love to see further refinements.
          ...you send them to school, you give them books, and they eat the pages...
            ayarriquitukis
            i fix a problem with the alpha img i can use in sketchup 2014... if you want tell me ... "for search a way to upload my new files"excuse me for the bad english....
              Jorgensen
              When I press SHIFT+CLICK, I get the attaced errors.
              Does anyone know if I can fix this?
              Thanks πŸ˜„
              Jorgensen
                Jorgensen
                I made second instance of Sketchup, copied my model to the new file, and then Ivy works.
                Strange - my project file must miss someting that Ivy needs... does anyone have an idea to what that could be?
                • cottyC Offline
                  cotty
                  From your screenshot: material named "ivy_stem". I don't know that plugin, but maybe you purged it away?
                  my SketchUp gallery
                    Jorgensen
                    Hi cotty
                    You are right about the matrials.
                    If i create a new project, the materials seems to be created, but if I open an old one project, the materials are not created.
                      mattao987
                      It's frustrating... It works on my "stagiaire" windows PC and not on my mac!!!
                      What should I do?
                      The Ivy window open but clicking on the object as no effect ( as if I was using no tools)
                      Please help
                      Mat
                      • OxerO Offline
                        Oxer
                        For my experience, this may be due to haven't the ivy components when you open a new file, check in the Components Window to see if they are three when you open a new file, check the Materials window too.
                        I fixed the problem opening a file with ivy already generated and then delete it and save the file like my main template, IMPORTANT: Don't Purge the file.
                        PS: If you want to purge the model before save the template, do it before delete the ivy.
                          mattao987
                          Thanks for your fast reply Oxer
                          Unfortunately I got the components and the materials loaded in the "new file" and it do not work.
                          Could you send me a file loaded with some ivy? I would try to use the tool in your file.
                          • OxerO Offline
                            Oxer
                            This is the file with the Ivy included:
                            Ivy Model
                            If it works for you, delete the ivy and the square and save it like a template, remember DON'T PURGE the model.
                            PS: I work on Mac and the unique version that works for me is 0.6 beta.
                            SketchupIvy.0.6.beta
                              mattao987
                              Thanks to you oxer it works
                              I got Ivy growing ( no leaf yet...)
                                mattao987
                                Got leaves!
                                Got to find how to get stem
                                • OxerO Offline
                                  Oxer
                                  The keys for the Ivy on Mac:
                                  1. Click : Makes grow the main Ivy.
                                  2. Cmd+Click : Makes grow the Ivy in the direction of mouse.
                                  3. Alt+Click : Makes grow the Leafs.
                                  4. SHIFT+Click : Finish the Ivy.
                                  5. i Key : Resume.
                                    razvan
                                    trouble with the leafs after generate. the background is not transparent. I'm missing something?
                                    • H Offline
                                      Heferkimbo
                                      Hello guys. I have been having problems with this amazing plugin.. version 0.6 did work for a few hours, but after turning the laptop again it only gave me errors. Other version didn't give errors, but they didn't do anything either, only 0.6 allowed me to play with the Ivy Generator!!..
                                      Anyway, this is a screenshot of the errors that i get after a click.
                                      Working on Mac.
                                        coreymurray
                                        Each time i start a new file the Ivy components are present even when i haven't used tool. Not a big issue, but it would be good if these could be added only once you run the plugin.
                                        Cheers
                                        Corey
                                          @coreymurray said:
                                          Cheers
                                          Corey
                                          This is a known limitation, as it loads them as it is loaded, not as it is used...
                                          This is how to fix it...
                                          In the ../Plugins/LiveIvy folder find the file LiveIvyTool.rb
                                          Open it with a plain text editor like Notepad or Notepad++ on PC, or TextWrangler on MAC.
                                          Find line #351 near the end that reads:
                                          LiveIvy::IvyTool.load_definitions
                                          add a # to the start of it so it doesn't load, thus:
                                          #LiveIvy::IvyTool.load_definitions
                                          Now to get them loaded as the tool is used, edit>copy the text:
                                          LiveIvy::IvyTool.load_definitions [NO #]
                                          and go up to line #10 which says:
                                          def initialize
                                          Add a new line below it, and then edit>paste:
                                          That will now load the definitions as the tool is first used, or subsequently if you have purged the definitions etc...
                                          Save the file and restart SketchUp to see the changes...
                                          Another possible tweak while you are at it... πŸ€“
                                          In the same file, around line ~#298 it says:
                                          #path = File.join(pathname, 'Textures/ivyleaf_1.skp') pathname = Sketchup.find_support_file "ivyleaf_1.skp", "Plugins/LiveIvy/Textures/"
                                          and also below in two similar blocks of text, at lines ~#303/#309***: this code means that the tool only works if you install it into the default Plugins folder, so if you really want it to also potentially run from elsewhere, then swap the #'d around AND change some of the text, so it reads.
                                          path**name** = File.join(**my_**pathname, 'Textures/ivyleaf_1.skp') **#**pathname = Sketchup.find_support_file "ivyleaf_1.skp", "Plugins/LiveIvy/Textures/"
                                          repeat for the other two blocks of code***
                                          AND then also remember to change line earlier on. in ~#294 from:
                                          pathname = File.expand_path(File.dirname(__FILE__))
                                          to read:
                                          **my_**pathname = File.expand_path(File.dirname(__FILE__))
                                          so that it looks into the correct folder.
                                          πŸ€“
                                          • OxerO Offline
                                            Oxer
                                            Thanks for the info!!
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 36
                                            • 37
                                            • 17 / 37
