    Upholstered furniture
    328 Posts 54 Posters 238.6k Views 54 Watching
    • Bryan KB
      Top notch.
      I was going to give this a try as my next project.
      Just got Artisan a few months ago and have been watching the tutorials and trying get the hang of it.
      • alvisA
        alvis
        Thanks guys for the comments. Bedding and pillows are borrowed from elsewhere.
        I can not say that it is very easy to do with Sketchup, bearing in mind that Sketchup is not friendly with polygons, and I'm probably stupid, because in the world is a better programs. Slowly, I can see a few steps ahead, how to do it. Excellent Plugin (VertexTool, FredoTools, Artisan and many other) improved capabilities, but...
        I'm starting to think that Sketchup evolution is too slow... 😒
        • pbacotP
          These look fantastic though
            Excellent! β˜€
            I suppose Artisan as Subdivisions making ?
            • C
              cuttingedge
              Im always challenged with this tufted furnitures. Its kind of tidious to come up with
              a proxy that would yield a good subdivision.- (non destructive). Much much easier with Max for example. But i still do it in Sketchup for the love of the software... Yeah, we are everyday hoping for better handling of polys..πŸ˜„
              • alvisA
                alvis
                Thanks for the coments, guys. next model...and render from THEA
                • HieruH
                  Hieru
                  Just curious, did you get rid of the ngons after stage three in your workflow?
                  www.davidhier.co.uk
                  • alexandre skA
                    alexandre sk
                    Great models.
                    How many entities have the last couch?
                    • C
                      cuttingedge
                      lovely... you have mastered this incredibly. May I ask you one question. This last sofa you made, (the red one)how much time will it take you to do a typical sofa like this, if you have the idea in your mind how the proxy should look like?
                      • alvisA
                        alvis
                        I will not lie, it takes 4 to 6 hours. The most commonly used UNDO and SAVE function. How to look like a proxy, as a sculptor does. stylized shape formed long for good result
                        • jo-keJ
                          jo-ke
                          I don't understand the step between the 3rd and 4th step. How do you built the vertikal lines for the chesterfield pattern before artisan?
                          http://www.zz7.de
                            sketchuh
                            this is insanely Amazing. i bet the process has to be very precise. i modelled a tufted cushion in modo which is easier to do in sketchup. in the end , sketchup is Not a sub-d modelling program. even with artisan, and other plugins, still not perfect. but from your post. it's possible!. great job. i will stick with modo or blender or 3ds max πŸ˜›
                            • olisheaO
                              olishea
                              +1
                              Looks like subdividing with hard edges.
                              oli
                              • RichardR
                                Richard
                                Mate, seriously you are getting just enough subtle variances in the models - you have that NAILED!
                                BUILTBRAND.COM.AU
                                • C
                                  catialilianacoelho
                                  I need your help, how i draw this beds please, what plugin i need too? thanks
                                  bed
                                  • massimoM
                                    massimo Moderator
                                    Hi, I think that the thread itself can give an answer to your questions. No? πŸ˜‰
                                    • C
                                      catialilianacoelho
                                      i dont know how make capitone with this organic shape bed...
                                        Surely you have some attempts to display?
                                        • alvisA
                                          alvis
                                          Well, a short course on how to make a simple and rather realistic tuft with Sketchup. Step by step ... day by day making lessons. You must have Artisan and VertexTool.
                                          First lessons:
                                          Photomatch your model, Draw the contour of the bed and double lines by tuft.
                                          To be continued...
                                          • olisheaO
                                            olishea
                                            This is awesome! 100% convincing models and renders. The creases, tufts, everything just spectacular. πŸ‘
                                            oli
                                            • 16
                                            • 17
                                            • 1 / 17
