    Upholstered furniture
    328 Posts 54 Posters 202.8k Views 54 Watching
    • cheddaC Offline
      chedda
      Quite masterful modelling, are the bed sheets also made with sketchup ?
      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
      • Bryan KB Offline
        Top notch.
        I was going to give this a try as my next project.
        Just got Artisan a few months ago and have been watching the tutorials and trying get the hang of it.
        • alvisA Offline
          alvis
          Thanks guys for the comments. Bedding and pillows are borrowed from elsewhere.
          I can not say that it is very easy to do with Sketchup, bearing in mind that Sketchup is not friendly with polygons, and I'm probably stupid, because in the world is a better programs. Slowly, I can see a few steps ahead, how to do it. Excellent Plugin (VertexTool, FredoTools, Artisan and many other) improved capabilities, but...
          I'm starting to think that Sketchup evolution is too slow... 😒
          • pbacotP Offline
            These look fantastic though
              Excellent! β˜€
              I suppose Artisan as Subdivisions making ?
                cuttingedge
                Im always challenged with this tufted furnitures. Its kind of tidious to come up with
                a proxy that would yield a good subdivision.- (non destructive). Much much easier with Max for example. But i still do it in Sketchup for the love of the software... Yeah, we are everyday hoping for better handling of polys..πŸ˜„
                • alvisA Offline
                  alvis
                  Thanks for the coments, guys. next model...and render from THEA
                  • HieruH Offline
                    Hieru
                    Just curious, did you get rid of the ngons after stage three in your workflow?
                    www.davidhier.co.uk
                    • alexandre skA Offline
                      alexandre sk
                      Great models.
                      How many entities have the last couch?
                        cuttingedge
                        lovely... you have mastered this incredibly. May I ask you one question. This last sofa you made, (the red one)how much time will it take you to do a typical sofa like this, if you have the idea in your mind how the proxy should look like?
                        • alvisA Offline
                          alvis
                          I will not lie, it takes 4 to 6 hours. The most commonly used UNDO and SAVE function. How to look like a proxy, as a sculptor does. stylized shape formed long for good result
                          • jo-keJ Offline
                            jo-ke
                            I don't understand the step between the 3rd and 4th step. How do you built the vertikal lines for the chesterfield pattern before artisan?
                            http://www.zz7.de
                              sketchuh
                              this is insanely Amazing. i bet the process has to be very precise. i modelled a tufted cushion in modo which is easier to do in sketchup. in the end , sketchup is Not a sub-d modelling program. even with artisan, and other plugins, still not perfect. but from your post. it's possible!. great job. i will stick with modo or blender or 3ds max πŸ˜›
                              • olisheaO Offline
                                olishea
                                +1
                                Looks like subdividing with hard edges.
                                oli
                                • RichardR Offline
                                  Richard
                                  Mate, seriously you are getting just enough subtle variances in the models - you have that NAILED!
                                  [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                    catialilianacoelho
                                    I need your help, how i draw this beds please, what plugin i need too? thanks
                                    bed
                                    • massimoM Offline
                                      massimo Moderator
                                      Hi, I think that the thread itself can give an answer to your questions. No? πŸ˜‰
                                        catialilianacoelho
                                        i dont know how make capitone with this organic shape bed...
                                          Surely you have some attempts to display?
                                          • alvisA Offline
                                            alvis
                                            Well, a short course on how to make a simple and rather realistic tuft with Sketchup. Step by step ... day by day making lessons. You must have Artisan and VertexTool.
                                            First lessons:
                                            Photomatch your model, Draw the contour of the bed and double lines by tuft.
                                            To be continued...
                                            • 16
                                            • 17
                                            • 1 / 17
