    SKP file association gone
    8 Posts 5 Posters 542 Views 5 Watching
    • PixeroP Offline
      Pixero
      After I uninstalled SU 8, SU 2014 is no longer defaulted to open SKP files.
      I've tried right clicking an a file and choose "Open with" and check the "always open with" but nothing seems to work.
      Is there a registry entry that needs to be added?
      • sketch3d.deS Offline
        sketch3d.de
        check the registry for key:
        HKCR\SketchUp.Document\shell\open\command\(Standard);<short_name_path_to_sketchup>
        the key shows as:
        C;\PROGRA~2\SketchUp\SKETCH~1\SketchUp.exe "%1"
        with the SU program directory residing in the "C:\Programs (x86)" directory (aka default).
        alternatively re-installing SU14 should fix this issue too.
        Norbert
        • PixeroP Offline
          Pixero
          I've tried this also but it won't work.
          I believe Mystic Thumb has taken control over the skp format.
          • Rich O BrienR Online
            I don't like saying this but for me Mystics Thumbs is -1
            I experienced nothing but trouble with it when it came to file associations.
              mac1
              Have you tried default programs from the start menu. It is different for different version of windows?
              • Dan RathbunD Offline
                Dan Rathbun
                Start SketchUp 2014 from the StartMenu.
                Then close it. SketchUp always re-writes the file association when it closes.
                (This causes multiple versions to "fight" over it.)
                I'm not here much anymore.
                  Dan Rathbun
                  Also the default value of HKEY_CLASSES_ROOT\\.skp
                  should be " SketchUp.Document"
                  • PixeroP Offline
                    Pixero
                    I went into the settings for Mystic Thumb and discovered it had a "file overide" enabled.
                    Unchecking it made SU2014 to open skp by default.
