[Plugin] InfinitePanOrbit [Now on OSX]
Jiminy, I'm also on single display and it's not working to the right too.
EDIT: I use a projector on this PC sometimes though. Those screens display the following:
New version 1.0.1
Changelog :
- The plugin now works with models created or opened after SU startup
- It should now trigger correctly on all screen borders
Download in the plugin store !
Thanks JBB. I'll give it a try when I get home after work.
Thanks JBB - Pure Zen !
Thanks JBB works perfectly now.
I'm getting used to this really fast... Thanks!
Works perfectly for me now. Even with a second display. Only problem is my mouse pad isn't big enough.
When the discussion about this plugin started I thought, hmm, interesting idea but don't think I would use it much. Then when you released the plugin I thought, Ok I'll try it but I hope he's made it easy to turn off as I'm certain I'll only use it occasionally.
Now that I have it and have used it for a day or so I can't think why I would turn it off and don't understand why it isn't a normal feature. Bloody Brilliant, thanks again.
Wow, that what was I waiting for ^_^
it's running smoothly in your video (on your machine) but it doesn't in my sketchup.. when it reaches the edge, it goes reverse and the go forward.. I hope you can try it on another machine please, or try to add more plugins in the Main UserInterface to your sketchup and test it again.
thanks.
what happened with me (each time I switch over the edge) is actually similar to what happened at 0:35 in your video.
Yes, this is what I meant by:
@jiminy-billy-bob said:
Known issues:
- The view flashes sometimes.
The length of this "flash" is heavily dependent on the model's complexity. The more complex the model, the more you're gonna experience this issue. For now, I can only advise you to disable it when working on heavy models.
I found a solution, but it resets the center of rotation. And as you know, the center of rotation depends on the location of the mouse when you activate the pan/orbit tool. So this leads to some really weird things depending on the geometry configuration in the view.
I don't think this is a good solution...I'll keep searching for a solution.
The Orbit tool does it naturally sometimes, too.
New version 1.0.2
It now works on OSX.
You should all thank Driven for this!Changelog :
- OSX support
You should all thank Driven for this!but blame jiminy-billy-bob if it doesn't work....
Haha
Hello,
this plugin no longer works for me in SU2017. -
I didn't notice this plugin before, very handy.
But… I notice a "jump" when the cursor goes from a side to the other, so not a really 360° pan.
OSX 10.8.5, SU 15.
By the way, I can deal with that. Thanks.
I remember having experienced this as well, but in SU2016 (Windows) it works as intended for me. For you it seems to reset the view when the cursor jumps, so it is not really useful as you cannot pan more than without the plugin.
this is broken in 2017
