    [Plugin] InfinitePanOrbit [Now on OSX]
    38 Posts 14 Posters 19.2k Views 14 Watching
    • BoxB Offline
      A handy little tool, almost works for me.
      It will orbit top and bottom and to the left side but going to the right it hits a wall.
      I'm currently on a single display setup but there would normally be one or two other screens off to the right side, perhaps that is causing it.
      • ludnidL Offline
        ludnid
        Awesome. Just Awesome.
        If you don't ask, the answer will always be no.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          @dave r said:
          I installed it on my Win 7 machine from the PluginStore and it worked with the blank drawing window that was open before installing but I opened a model file and tried it. It didn't work. I've tried closing and reopening SketchUp several times. No change. 😞
          Indeed... I'll fix it.
          You're right, it's probably related to that. Although, I don't get why.
          What does this window show you?
          http://i.imgur.com/HMmLM.png
          • JQLJ Offline
            JQL
            Jiminy, I'm also on single display and it's not working to the right too.
            EDIT: I use a projector on this PC sometimes though. Those screens display the following:
            www.casca.pt
            Visit us on facebook!
              jiminy-billy-bob
              New version 1.0.1
              Changelog :
              • The plugin now works with models created or opened after SU startup
              • It should now trigger correctly on all screen borders
              Download in the plugin store !
                Thanks JBB. I'll give it a try when I get home after work.
                • CadFatherC Offline
                  CadFather
                  Thanks JBB - Pure Zen ! 😎
                  • BoxB Offline
                    Thanks JBB works perfectly now.
                    • JQLJ Offline
                      JQL
                      I'm getting used to this really fast... Thanks!
                      www.casca.pt
                        Works perfectly for me now. Even with a second display. Only problem is my mouse pad isn't big enough. πŸ˜†
                        • BoxB Offline
                          When the discussion about this plugin started I thought, hmm, interesting idea but don't think I would use it much. Then when you released the plugin I thought, Ok I'll try it but I hope he's made it easy to turn off as I'm certain I'll only use it occasionally.
                          Now that I have it and have used it for a day or so I can't think why I would turn it off and don't understand why it isn't a normal feature. Bloody Brilliant, thanks again.
                          • O Offline
                            othmanalazzam
                            Wow, that what was I waiting for ^_^
                            • O Offline
                              othmanalazzam
                              it's running smoothly in your video (on your machine) but it doesn't in my sketchup.. when it reaches the edge, it goes reverse and the go forward.. I hope you can try it on another machine please, or try to add more plugins in the Main UserInterface to your sketchup and test it again.
                              thanks.
                              • O Offline
                                othmanalazzam
                                what happened with me (each time I switch over the edge) is actually similar to what happened at 0:35 in your video.
                                  jiminy-billy-bob
                                  Yes, this is what I meant by:
                                  @jiminy-billy-bob said:
                                  Known issues:
                                  • The view flashes sometimes.
                                  The length of this "flash" is heavily dependent on the model's complexity. The more complex the model, the more you're gonna experience this issue. For now, I can only advise you to disable it when working on heavy models.
                                  I found a solution, but it resets the center of rotation. And as you know, the center of rotation depends on the location of the mouse when you activate the pan/orbit tool. So this leads to some really weird things depending on the geometry configuration in the view.
                                  I don't think this is a good solution...
                                  I'll keep searching for a solution.
                                    The Orbit tool does it naturally sometimes, too.
                                      jiminy-billy-bob
                                      New version 1.0.2
                                      It now works on OSX.
                                      You should all thank Driven for this!
                                      Changelog :
                                      • OSX support
                                        driven
                                        but blame jiminy-billy-bob if it doesn't work....
                                          jiminy-billy-bob
                                          Haha πŸ˜„
                                            Pherim
                                            Hello,
                                            this plugin no longer works for me in SU2017.
