    VRay Problem - undulating reflections
    renderpluginsextensions
    24 Posts 8 Posters 5.2k Views 8 Watching
      reymond
      dkendig says it correctly. it's the image format.
      it is probably in connection with your light.
      I could see no light source in the kitchen cabinets. where does that light?
      used a square with a Emitter material as light source and a ies light.
      I think your patch in the stored image has to do with the light.
      in connection with the reflection of the materials.
      you Need try ...... but put the light sources as noted.
      and try for the high-gloss surface a standart plastic material.
      I had a thearender issue with a similar problem. and there were the light sources the Problem.
      Sketchup & Vray Trainer
      • G
        Gwint
        None of this I do not understand ... I put it anywhere else light source?
          reymond
          over 200 times has been viewed this question .
          out of dkendig and me no one has an answer?
          I think many do not understand the term "forum"!!! πŸ˜•
          • ToboboT
            Tobobo
            @gwint said:
            Thank you very much "reymond", but still the same ....
            have you tried upping the shadow subdivs on the lights?
            Toby
            Philippians 4:13
            • G
              Gwint
              I'm sorry, I'm a beginner. How to set it up?
              • ToboboT
                Tobobo
                Right click on the light group and go to the bottom of the context menu. It should say VRay light with a fly out arrow. the click on edit light. A dialog box should appear with a section for shadows
                Toby
                Philippians 4:13
                • G
                  Gwint
                  One problem (as shown in 2.jpg) have eliminated by changing Material - Reflection - Glossiness - Treat glossy as GI of Allways the GI rays only and increasing subdivs as written reymond and dkendig.
                  The problem (as shown in 1.jpg) is likely to eliminate possible options Material - Reflection - Glossiness - Hilight and Reflect.
                  Still unfortunately undulating reflections appear (shown in 3.jpg) and do not know how to get rid of them. They appear most often on the walls next to the items that reflect.
                  • andybotA
                    andybot
                    This is something that usually happens when there is not enough light on a surface - there is not enough information in the render in those areas, hence the splotchiness. Try increasing the amount of lighting in your scene. You could also try the Brute Force (DMC) method in your Indirect Illumination settings (Primary Bounces) That will give you a more photographic (slightly grainy) transition in these problem areas. If you use irradiance map, you can increase your "hsph subdivs" to something like "90" instead of the default 50. Hope that helps.
                    • C
                      cuttingedge
                      hey guys , had this similar problem and had not found solution. mine looks even worse..I posted this somewhere in this site but none was able to explain. Now Im thinking to shift rendering to another software because of this issue. Can anyone help please.
                      reflection prob
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        It's a sampling issue, either from the light or from the glass itself. Hard to know.
                        Could you post the skp file so we can have a look?
                        • chavinskeeC
                          chavinskee
                          i think i found a solution for this as i have also experienced this with close up shots. you have to uncheck "use light cache for glossy rays" in the light cache rollout. i hope that this tip would help you out. πŸ˜„
                          http://chavinskee.blogspot.com/
                          • 2 / 2
