    [Plugin] QuadFaceTools
    680 Posts 116 Posters 700.9k Views 116 Watching
      After that messagebox you should have seen an Explorer window open that display the files in the VirtualStore. These files should be moved to the real Plugins folder.
        tabehe
        Thanks Thom all your plugs boot my workflow.Many thanks to you sharing your tools with us.
        • F Offline
          fallen_satori
          Hello!
          Need some help here please!
          I downloaded TT_Lib2 and TT_QuadFaceTools, unpack them and put in my plugin folder. But when I start SketchUp it came with:
          "TT_Lib2 detected that some of the files in plugins directory has ended up in Windows Virtual store. It happens because of insufficient permission for the plugin folder. Please move the files into the real Plugins folder."
          • BoxB Offline
            You need to fix the security permissions.
            Go here http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56005
            • tt_suT Offline
              tt_su
              @fallen_satori said:
              Hello!
              The Explorer window that opens up should contain the rogue files that should be moved to the real Plugins folder.
              However, if you install the latest version 2.9.8 then you should not get that message any more as I removed that check. If you do have version 2.9.8 it means that you have an older version of TT_Lib loading, which would be a result of files in Virtual Store.
              You say you extracted the files in your Plugins folder, why did you not install the RBZ package using SketchUp? (Preferences > Extensions > Install Extension) It's recommended to let SketchUp install it for you. Extension Warehouse or Plugin Store would also be good.
              • F Offline
                fallen_satori
                That was it! After changing my TT_Lib on 2.9.8 all things just works fine. But I've also change my permissions first.
                Thank you soooooo much πŸ˜‰
                • john2J Offline
                  john2
                  I'm getting error in SU 2014
                  C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_quadface.rb:39: syntax error, unexpected tSTRING_BEG, expecting keyword_end
                  ex.creator = 'Thomas Thomassen (thomas@thomthom.net)'
                  C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_quadface.rb:40: syntax error, unexpected tCONSTANT, expecting keyword_end
                  ex.description = 'Suite of tools for manipulating quad faces.'
                  C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_quadface.rb:40: syntax error, unexpected tIDENTIFIER, expecting keyword_do or '{' or '('
                  C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_quadface.rb:40: syntax error, unexpected tSTRING_BEG, expecting '('
                  C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_quadface.rb:40: unterminated string meets end of file
                  Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                    @John2
                    Have you installed the latest version of this Plugins AND the TT Lib [both available from the SketchUcation PluginStore] ?
                    It looks like you copied a older incompatible version from another SketchUp Plugins folder ?
                    All of TT's scripts should be compatible with v2014 [and earlier] IF you use the latest versions which have been updated to suit...
                    • john2J Offline
                      john2
                      @tig said:
                      @John2
                      I did copy files from my v8 folder πŸ˜’ , but I deleted all the tt_ files manually. Then I went to SCF plugin store and installed all tt_ plugins one by one. The error still there. Is there a way to purge obsolete files so that I don't get an error? Just like there is fredo6 library purge option?
                      • cottyC Offline
                        cotty
                        You can delete the files which are mentioned in the error message.
                        my SketchUp gallery
                          All my extensions should have a single root rb as well as a folder with the same name of the rb file. So there shouldn't be many files to remove.
                          • john2J Offline
                            john2
                            Thanks! I installed all your plugins again, deleted files of old ones. Now I'm free from errors πŸ˜„
                            • john2J Offline
                              john2
                                Excellent! πŸ˜„
                                • john2J Offline
                                  john2
                                  @thomthom said:
                                  Excellent! πŸ˜„
                                  πŸ‘
                                  • john2J Offline
                                    john2
                                    Can these tools somehow used to solve the problem I'm facing here?
                                    404 Not Found
                                    (sketchucation.com)
                                    • romboutR Offline
                                      rombout
                                      How does the blender quads to sketchup quads work, when i press the Suzanne (monkey) icon nothing happens?
                                        It's for converting imported geometry to Quads. When exporting geometry to blender and importing into SketchUp the edge that split the triangles in a non-planar quad is hidden - this function convert it to work with QuadFace Tools.
                                        https://bitbucket.org/thomthom/quadface-tools/wiki/Features#!convert-blender-quads-to-quadface-quads
                                          When Blender to Quads fails you can also try using selection toys to select faces and hidden lines. Delete them and then run wireframe to Quads
                                            When does it fail? 😲
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 33
                                            • 34
                                            • 18 / 34
