    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 130.1k Views 39 Watching
      Regular Polygon
      @andybot:
      Thank you!
      Iโ€™m glad you are finding the plugin useful. ๐Ÿ˜„
      My SketchUp Plugins
      • monsterzeroM Offline
        monsterzero
        Adding scale and vert animation would be powerful. Squash and stretch are essential for character animation. That would be awesome!
        monsterzero
        My New Twitch Stream!
        https://www.twitch.tv/infinitestorylab
        infinitemachine.com
        • mariochaM Offline
          mariocha
          more feedback in favor of animating the size of objects,
          Count my vote in. ๐Ÿ˜„
          %(#008000)[Mario C.
          • mariochaM Offline
            mariocha
            Anyone knows if there are issues with Keyframe on MacOS Lion ?
            %(#008000)[Mario C.
              @ecuadorian said:
              Is there a way to export these animations as FBX?
              What have you in mind, Miguel? ๐Ÿ˜‰
              • E Offline
                Ecuadorian
                Importing it in Lumion, of course.
                -Miguel Lescano
                  Regular Polygon
                  There have been a few updates to Keyframe Animation since it was released three months ago. The current version is 1.3. The plug-in and user manual are available on the Download Page.
                  Version 1.1 made improvements to much of the code. A new algorithm generates the in between scenes over twice as fast as the original. They are important because you can export the tween scenes to an AVI movie.
                  Versions 1.2 and 1.3 have simplified the process for creating an animation. You no longer need to assign a unique name to each instance that you want to animate โ€“ that seemed to be the least intuitive, most tedious step in the whole process. The script will now automatically distinguish which instances are active and which are static. You donโ€™t have to do anything.
                  The basic workflow can be summarized in five easy steps:
                  1. Add some scenes.
                  2. Select the first scene.
                  3. Move the objects where you want them.
                  4. Record the position data.
                  5. Select the next scene, and go to step 3.
                  This video tutorial illustrates the new workflow in version 1.3, and in the process, shows how to animate a Rubikโ€™s Cube.
                  [flash=640,510:5q5jjjp5]http://www.youtube.com/v/ZmNmQ3izNnI?fs=1&hl=en_US&rel=0[/flash:5q5jjjp5]
                  My SketchUp Plugins
                    Regular Polygon
                    Thanks for bringing this to my attention everyone. ๐Ÿ‘ Especially thanks to cperkins for sending me his model so I could see what was going on.
                    File size is not the problem. It turns out, there was an actual bug that stops the execution of the script before the tweens are generated. It was most prone to occur in models that have a lot of sub-components, so that is why large file size seemed to be a factor. ๐Ÿค“
                    The bug must of crept into version 1.2. Anyway, it has been fixed, the new version is 1.3.1, and it is available on the Download page.
                    If you still have any issues after installing this new version, feel free to post them here, or send me a PM.
                    Thanks,
                    My SketchUp Plugins
                      Regular Polygon
                      Hi Everyone,
                      Just thought I'd mention that version 1.4 is available. There is now a toolbar to facilitate the animation process. Here's a screenshot:
                      Keyframe Animation Toolbar
                      My SketchUp Plugins
                      • N Offline
                        nickdk
                        What is the status with VRay support? I couldn't locate the ticket at Chaosgroup.
                        Regards
                        Nick
                          Regular Polygon
                          Greetings,
                          There have been a couple updates since I last posted. The most frequent request (at least from the email I receive) has been to animate the objectsโ€™ visibility. So, as of version 1.6, objects can appear or disappear at any point in the animation.
                          Their visibility is controlled by putting the objects on layers, and then turning those layers on or off for each key frame. The tweens generate the objects with the same visibility that they had on the key frames, so the animation can be exported to a movie.
                          This demo animates the object visibility in a construction process. The bookcase parts all start off hidden. Their visibility is turned on when they are required for assembly, and they stay visible for the rest of the animation.
                          [flash=480,360:3oqdsb0a]http://www.youtube.com/v/WGozLwOerfY?version=3&hl=en_US&rel=0[/flash:3oqdsb0a]
                          BTW, I ought to mention that there is a new website for all my plugins. If you havenโ€™t visited, please check it out. The landing page for Keyframe Animation is regularpolygon.org/keyframe-animation/
                          My SketchUp Plugins
                          • iichiversiiI Offline
                            iichiversii
                            Correct me if im wrong but couldnt we do this with version 1.5 , once tweens are created you could turn off/on the layers in each tween and update each tween/scene, i dont understand how version 1.6 is different, is there any new features in 1.6 you can share with us, thank you
                            Bring on the Rain...
                              Regular Polygon
                              iichiversii, technically you could do this yourself in version 1.5. But to imply that it is simple to do, and no plugin is necessary to automate the process, is just plain false.
                              When the tweens are created for an animation, there are usually 500+ tweens, often over a 1000. Are you really going to go through 1000 scenes and manually adjust the visibility of the layers for each one? Even if you could update one scene every 10 seconds that would still take nearly three hours. You must have a lot more time on your hands than I do. I think most people would consider a script that automates this process to be a new feature. And that is probably why I received so many emails requesting it.
                              My SketchUp Plugins
                              • andybotA Offline
                                andybot
                                Regards
                                Nick
                                Are you asking if vray will render the animations from Keyframe animation? The answer is no because vray loads the model and the views from the initial scene and then renders only that state. No layer or geometry changes will be generated.
                                • andybotA Offline
                                  andybot
                                  By the way RP, nice to see added features ๐Ÿ‘ Any progress on changing objects' scale? ๐ŸŽ‰
                                    iichiversii
                                    Im sorry if i offend, i didnt understand the feature fully, normally i do short clips with 30-50 tweens, i adjust my tweens then with layers, doesnt take to much time to do with so little tweens, im a great fan of keyframe_animation, with out it i wouldnt be able to create the animations im doing now, looking forward to the new updates, thank you
                                      Regular Polygon
                                      Hey iichiversii, thanks for putting things into perspective. I am sorry if I overreacted, which I probably did. I shouldn't write posts at 3 am, I guess. ๐Ÿ˜’
                                      My SketchUp Plugins
                                        iichiversii
                                        lol, no worries,really am a fan of this plugin tho, its fantastic and im constantly mentioning it in my posts, heres a short clip i did using it, im looking forward to the next updates, im having 1 problem tho, my animations bugsplat everytime i animate a componant within a group, may i ask for a tutorial so i can see if im doing something i shouldnt be doing or does this happen alot??? ๐Ÿ˜† , please dont over react, ๐Ÿ˜†
                                        [flash=640,480:1amf8kr5]http://www.youtube.com/v/QP1ILu_IWII?version=3&hl=en_US[/flash:1amf8kr5][/quote]
                                          Regular Polygon
                                          You should be able to do that. I will PM you with the email address to send me your model so I can look into it.
                                          My SketchUp Plugins
                                            Regular Polygon
                                            Now that animating object visibility is out of the way, animating the scale of objects is the new most requested feature. It has moved up to third place on my list of Planned Updates. I hope to knock off the first two items in version 1.7, and release it in January. They are more essential to the basic workflow, so I need to do them first. After that, I will get serious about trying to animate the scale of objects.
                                            My SketchUp Plugins
                                            • 5 / 8
