    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 136.8k Views 39 Watching
      Regular Polygon
      Greetings,
      There have been a couple updates since I last posted. The most frequent request (at least from the email I receive) has been to animate the objects’ visibility. So, as of version 1.6, objects can appear or disappear at any point in the animation.
      Their visibility is controlled by putting the objects on layers, and then turning those layers on or off for each key frame. The tweens generate the objects with the same visibility that they had on the key frames, so the animation can be exported to a movie.
      This demo animates the object visibility in a construction process. The bookcase parts all start off hidden. Their visibility is turned on when they are required for assembly, and they stay visible for the rest of the animation.
      [flash=480,360:3oqdsb0a]http://www.youtube.com/v/WGozLwOerfY?version=3&hl=en_US&rel=0[/flash:3oqdsb0a]
      BTW, I ought to mention that there is a new website for all my plugins. If you haven’t visited, please check it out. The landing page for Keyframe Animation is regularpolygon.org/keyframe-animation/
      My SketchUp Plugins
      • iichiversiiI Offline
        iichiversii
        Correct me if im wrong but couldnt we do this with version 1.5 , once tweens are created you could turn off/on the layers in each tween and update each tween/scene, i dont understand how version 1.6 is different, is there any new features in 1.6 you can share with us, thank you
        Bring on the Rain...
          Regular Polygon
          iichiversii, technically you could do this yourself in version 1.5. But to imply that it is simple to do, and no plugin is necessary to automate the process, is just plain false.
          When the tweens are created for an animation, there are usually 500+ tweens, often over a 1000. Are you really going to go through 1000 scenes and manually adjust the visibility of the layers for each one? Even if you could update one scene every 10 seconds that would still take nearly three hours. You must have a lot more time on your hands than I do. I think most people would consider a script that automates this process to be a new feature. And that is probably why I received so many emails requesting it.
          My SketchUp Plugins
          • andybotA Offline
            andybot
            @nickdk said:
            What is the status with VRay support? I couldn't locate the ticket at Chaosgroup.
            Regards
            Nick
            Are you asking if vray will render the animations from Keyframe animation? The answer is no because vray loads the model and the views from the initial scene and then renders only that state. No layer or geometry changes will be generated.
            • andybotA Offline
              andybot
              By the way RP, nice to see added features πŸ‘ Any progress on changing objects' scale? πŸŽ‰
                iichiversii
                Im sorry if i offend, i didnt understand the feature fully, normally i do short clips with 30-50 tweens, i adjust my tweens then with layers, doesnt take to much time to do with so little tweens, im a great fan of keyframe_animation, with out it i wouldnt be able to create the animations im doing now, looking forward to the new updates, thank you
                  Regular Polygon
                  Hey iichiversii, thanks for putting things into perspective. I am sorry if I overreacted, which I probably did. I shouldn't write posts at 3 am, I guess. πŸ˜’
                  My SketchUp Plugins
                    iichiversii
                    lol, no worries,really am a fan of this plugin tho, its fantastic and im constantly mentioning it in my posts, heres a short clip i did using it, im looking forward to the next updates, im having 1 problem tho, my animations bugsplat everytime i animate a componant within a group, may i ask for a tutorial so i can see if im doing something i shouldnt be doing or does this happen alot??? πŸ˜† , please dont over react, πŸ˜†
                    [flash=640,480:1amf8kr5]http://www.youtube.com/v/QP1ILu_IWII?version=3&hl=en_US[/flash:1amf8kr5][/quote]
                      Regular Polygon
                      You should be able to do that. I will PM you with the email address to send me your model so I can look into it.
                      My SketchUp Plugins
                        Regular Polygon
                        Now that animating object visibility is out of the way, animating the scale of objects is the new most requested feature. It has moved up to third place on my list of Planned Updates. I hope to knock off the first two items in version 1.7, and release it in January. They are more essential to the basic workflow, so I need to do them first. After that, I will get serious about trying to animate the scale of objects.
                        My SketchUp Plugins
                        • N Offline
                          nickdk
                          I'm testing the plugin and it seems very nice! But when i try to create the 'tweens' no scenes are added, what could be wrong? V. 1.6
                          the file i'm working on has a ton of sub components and heavy geometry but I read that it shouldn't be a problem anymore?
                          I have tried to explode some of the components but it didn't help.
                          I tried to create tweens for a simple model and it worked.
                          .. OK I tried to explode everything and with 10FPS and 3 sec transitions it worked, but with 25fps and 30sec transitions it failed as before... this is very frustrating
                            iichiversii
                            On a good note, after PM with Regular Polygon i was directed in the right way on issues i had with keyframe_Animation and sub componants can be animated in a parent group/componant with simply highlighting the subcomponant within the parent group/componant and recording the subcomponant, and then recording the parent componant in the same scene, thank you Regular Polygon for your instructions, remember i never doubted you Doug πŸ˜„
                              Regular Polygon
                              Thanks for clearing that up iichiversii. πŸ‘
                              I changed the workflow for subcomponents in version 1.5. Now, you have to open the parent component/group for editing by double-clicking on it. Then click the record button while the parent component is open. That records the position data for all the subcomponents.
                              It is not really any extra work, because you have to open the parent component in the first place to position the subcomponent. So, just click the record button at that time.
                              My SketchUp Plugins
                                Regular Polygon
                                The best way to reach me for support is at the email listed here on the Contact page. I don't check this forum every day, but I do check my email quite often. If your model is less than 25 MB, you can send it to that email address and I will check it out for any bugs.
                                My SketchUp Plugins
                                • fouronethirtyF Offline
                                  fouronethirty
                                  can't export section animation
                                    Regular Polygon
                                    That is true. But I never claimed you could. The only scene properties that can be exported are camera location and visible layers. The other ones may be supported in the future. Section planes are currently fourth on the list of planned updates.
                                    My SketchUp Plugins
                                    • emerald15E Offline
                                      emerald15
                                      I've posted this problem separately, but though it might find more attention here.
                                      http://forums.sketchucation.com/viewtopic.php?f=79&t=42931
                                      Love using keyframe Animation, but can't figure this problem out.
                                      • utilerU Offline
                                        utiler
                                        Just bought this plugin, Regular_Polygon; I have been meaning too for a while..... πŸ‘
                                        I use your other plugins quite a lot so I feel I should contribute!!
                                        Just Curious...
                                          Regular Polygon
                                          Thank you! πŸ‘ πŸ˜„
                                          My SketchUp Plugins
                                            Regular Polygon
                                            Hi emerald15,
                                            Trying to animate two folding doors is an interesting problem. The door on the right just rotates about its right edge, so that is easy to animate. But the other door, to the left, moves in a way that is neither a simple rotation, or translation. However, it is possible to represent this motion using animated subcomponents. When you animate a subcomponent (subgroup), it moves relative to the parent. So, the combined motion can be something more complex than a translation or rotation.
                                            First, clear/delete any position data you have recorded for the doors. Then make a group out of the two doors, so each door is a subgroup. The basic idea is, you rotate the left door about the hing through some angle less than 180 degrees. At the same time, you rotate the entire two door group about the right edge through an angle of 90 degrees. The combined motion causes the doors to fold together exactly like they do in real life.
                                            I am sure that a video would explain this much better than words. I hope to make some tutorials in the near future. If it isn't clear, you can just email me your model, and I can quickly set up the animation, and send it back to you.
                                            My SketchUp Plugins
                                            • 5 / 8
