    [Plugin] MoveIt
    56 Posts 29 Posters 51.1k Views 29 Watching
      rv1974
      something like this:
        rv1974
        Some 3ds max analog:
          Jim
          Ah, that's what I need - pictures! Let me see what I can do. Thanks.
            Jim
            I renamed it MoveIt and it's in the SketchUcation store.
            • Bob JamesB Offline
              Bob James
              Tried to download Mover2.
              http://sketchuptips.blogspot.com/2007/0%20...%20ver-2.html
              Got this error.
              Also no download arrow available for 'makeorthoviews' 😞
                Bob James
                Whew!! I was worried there πŸ˜„
                Thanks for the quick reply.
                How about Makeorthoviews?
                  Jim
                  I sent that via email since it's a paid plugin.
                    Bob James
                    Lest everyone gets the wrong idea, I previously bought Makeorthoviews from SMustard but forgot I did so it was all above board that Jim sent me a copy rather than my having to download it again. πŸ˜„
                    • ElibjrE Offline
                      Elibjr
                      This was always a favorite plugin in my arsenal. Nothing else works quite like this! I hope it "plays well" with the other plugins.
                        Jim
                        I'm glad you like it. There are no known conflicts, and code is written using the communities best practices to minimize the chance of future conflicts.
                          pegaze
                          i'm still searching how to selected multiple objects without copying them ... cause i'm using CTRL of course ...
                          • soloS Offline
                            Jim, could you test something for me, I am getting errors using this with SU 2107, seems like on some groups when I move them they duplicate when moved, does not happen with components.
                              Jim
                              I have tested on 2017 and it works the same for me on 2016 & 2017.
                              The only time you should get a copy is when holding the Ctrl key and clicking an arrow (and/or using the cursor keys.) I don't suppose you unintentionally had your pinky on the Ctrl key?
                              I just remembered something about the dialog - the dialog is what handles the keyboard input. I think I remember it used to get confused as to what state the ctrl key was in. I thought I added an indicator to the dialog, but maybe it never got done. If it happens again, click on the dialog and toggle the Ctrl key to see if it clears things up.
                              Other than that, it's difficult to say what's happening.
                                skippert
                                I just downloaded MoveIt. The CW and CCW directions are backward on the X and Z axis. I drew a simple box and labeled the TOP and FRONT surfaces, so I know I'm looking at the correct surfaces.
                                  bjocktane
                                  thank you for this plugin Movelt
                                  • V Offline
                                    vmsremy66
                                    Hello. it seems that the plugin is not yet available..... could you fix this problem? thanks
                                      Jim [the author] has withdrawn all of his plugins from here and elsewhere...
                                      Sorry !
                                        smiggyuk1000
                                        hi * loved this plug-in and now doing a refresher for SketchUp after a few years not using it . Just wondering where I can download the extension if it still works with 2025 SketchUp.
                                          Its discontinued,
                                          You could try Axyz and it allows similar movements using the Arrow keys.
                                          https://sketchucation.com/pluginstore?pln=axyz
                                            maxosmedia
                                            all links is dead! 😞
                                            • 3 / 3
