    [Plugin] MoveIt
    56 Posts 29 Posters 51.9k Views 29 Watching
      rv1974
      Hi Jim!
      May I humbly request to add "scale department" to your 'mover 2'?
      With uniform\non uniform\random\by axis\ lock the component insert point features it'd be a killer plugin.
      Thanks in advance.
        rv1974
        something like this:
          rv1974
          Some 3ds max analog:
            Jim
            Ah, that's what I need - pictures! Let me see what I can do. Thanks.
              Jim
              I renamed it MoveIt and it's in the SketchUcation store.
              • Bob JamesB Offline
                Bob James
                Tried to download Mover2.
                http://sketchuptips.blogspot.com/2007/0%20...%20ver-2.html
                Got this error.
                Also no download arrow available for 'makeorthoviews' 😞
                  Bob James
                  Whew!! I was worried there πŸ˜„
                  Thanks for the quick reply.
                  How about Makeorthoviews?
                    Jim
                    I sent that via email since it's a paid plugin.
                      Bob James
                      Lest everyone gets the wrong idea, I previously bought Makeorthoviews from SMustard but forgot I did so it was all above board that Jim sent me a copy rather than my having to download it again. πŸ˜„
                      • ElibjrE Offline
                        Elibjr
                        This was always a favorite plugin in my arsenal. Nothing else works quite like this! I hope it "plays well" with the other plugins.
                          Jim
                          I'm glad you like it. There are no known conflicts, and code is written using the communities best practices to minimize the chance of future conflicts.
                            pegaze
                            i'm still searching how to selected multiple objects without copying them ... cause i'm using CTRL of course ...
                            • soloS Offline
                              Jim, could you test something for me, I am getting errors using this with SU 2107, seems like on some groups when I move them they duplicate when moved, does not happen with components.
                                Jim
                                I have tested on 2017 and it works the same for me on 2016 & 2017.
                                The only time you should get a copy is when holding the Ctrl key and clicking an arrow (and/or using the cursor keys.) I don't suppose you unintentionally had your pinky on the Ctrl key?
                                I just remembered something about the dialog - the dialog is what handles the keyboard input. I think I remember it used to get confused as to what state the ctrl key was in. I thought I added an indicator to the dialog, but maybe it never got done. If it happens again, click on the dialog and toggle the Ctrl key to see if it clears things up.
                                Other than that, it's difficult to say what's happening.
                                  skippert
                                  I just downloaded MoveIt. The CW and CCW directions are backward on the X and Z axis. I drew a simple box and labeled the TOP and FRONT surfaces, so I know I'm looking at the correct surfaces.
                                    bjocktane
                                    thank you for this plugin Movelt
                                    • V Offline
                                      vmsremy66
                                      Hello. it seems that the plugin is not yet available..... could you fix this problem? thanks
                                        Jim [the author] has withdrawn all of his plugins from here and elsewhere...
                                        Sorry !
                                          smiggyuk1000
                                          hi * loved this plug-in and now doing a refresher for SketchUp after a few years not using it . Just wondering where I can download the extension if it still works with 2025 SketchUp.
                                          • Rich O BrienR Online
                                            Its discontinued,
                                            You could try Axyz and it allows similar movements using the Arrow keys.
                                            SketchUp Plugins | PluginStore | SketchUcation
                                            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                            (sketchucation.com)
                                            • 3 / 3
