    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 357.3k Views 109 Watching
    • l_breaultL Offline
      l_breault
      Thank you very much! I can't wait to give this a go!
      Thanks,
      Leo Breault
      http://www.breaultdesignstudio.com
      • sdmitchS Offline
        sdmitch
        @rviz said:
        Sdmitch, first off thank you for helpful tool!
        Could you please polish the following things (though it was puplished as floorgenerator):
        Yes, I probably should have called it Pattern Generator instead.
        1. inconsistent grid origin\rotation (tried on simple cube, see pic.1)
          By design, the plugin aligns the pattern length with the longest edge of the face picked. In this case, I would undo and redo the face with 90 rotation selected.
        2. additional option 'respect user's pattern- one tile per face, consistent gaps (pic.2).
        3. 'don't penetrate corners' option(very important for metal panel siding\glazing)
          I guess, to implement p.1 and 2, the tool would have to work with multiple faces.
          This is a pattern generator not a groove cutter.
        4. respect adjacent faces!
          Nothing this plugin does should ever effect an adjacent face.
        5. pick up file's units (I'm on cm, for instance)?
          It does determine the units used but switches to inches or millimeters while executing then returns model to original units when exiting.
        6. presets saving?
          All the values for each option are saved in the registry and retrieved when needed.
        Thank you once again.
        http://sdmitch.blogspot.com/
        • JQLJ Offline
          JQL
          I'm thrilled that finally this is available in Sketchup!
          Unfortunatelly, it isn't available in the download link any more...
          Updating?
          EDIT: Yes... Updating! Can't wait to try it out!
          www.casca.pt
          Visit us on facebook!
          • rvizR Offline
            rviz
            πŸ™‚ I meant it's not only 'floor' but rather general building finishes modeller.
            So it could be tweaked (or 'polished') for wider use.
            I see. But may for vertical\ surfaces the horizontal direction set the lenth?
            1. additional option 'respect user's pattern- one tile per face, consistent gaps (pic.2).
            simply every single preselected polygon will turn into the single tile piece (multiple selection would be crucial in this case). see pic.2 in my previous reply.
            1. 'don't penetrate corners' option(very important for metal panel siding\glazing)
            I'd call it building finishes modeler. So in addition to bricks, tiles and parquet
            It'd be sweet to get metal panels which have special treatment at the corners. Please
            see:
            http://materialsandsources.com/wp-content/uploads/2010/01/residence-dri-design-1.jpg
            http://pfisterroofing.com/wp-content/uploads/2013/04/aluminum-wall-panel-composite-systems.jpg
            BTW have you ever thought about 'groove cutter'? It's really missing
            Many thanks for attention
            • U Offline
              unearthed
              Thanks sdmitch, another great tool, will speed up my decks and patios no end
              Growplan - People ∩ Plants ∩ Place
              windows 7 64b, 4GB RAM, SU 8.0.16846
              Gimp, QGIS, Vectorworks 12, Bricscad 11
                Ben Ritter
                SDMitch, thank you for your generosity and talent.
                  Ben Ritter
                  @pixero said:
                  I've said it before, but thanks you! 😍
                  I think you forgot to say that if you place a folder called BTW_Textures in your plugin folder and choose use Apply material: Rand_Tex it will use all textures in that folder. Here are a few tests I've made:
                  [attachment=3:1u96rdu7]<!-- ia3 -->Bricks01.jpg<!-- ia3 -->[/attachment:1u96rdu7]
                  Can you spot the tiling? No, because there is none. This is with 10 small seamless brick textures used.
                  [attachment=2:1u96rdu7]<!-- ia2 -->floor03.jpg<!-- ia2 -->[/attachment:1u96rdu7]
                  This is just one single seamless texture used.
                  [attachment=0:1u96rdu7]<!-- ia0 -->tiles01.jpg<!-- ia0 -->[/attachment:1u96rdu7]
                  This is also just one texture used.
                  Pixero, thank you very much.
                  • sdmitchS Offline
                    sdmitch
                    A new update. Added two new patterns.
                    • OxerO Offline
                      Oxer
                      Thanks you very much for this useful plugin!! πŸ‘
                      It works perfectly on Mac & SU2014. One question, the Row2Row Offset for Brick is 0.5 by default when you use mm units, I changed to 50 in line 69 of the rb file.
                      @defaults=["Corner","0","Current","Yes","Yes","50","No","No","0","No","No","30","150","50","12","6","3"] if @@opt=="Brick"
                      Thanks Pixero for the info and Textures πŸ‘
                      Another question, what units uses the Texture Size, mm, inches or pixels?
                      • sdmitchS Offline
                        sdmitch
                        Thanks for pointing that out. Originally I was using a fraction(0.5) instead of a %. Once it is corrected from within the plugin and Update is clicked, that should take care of it.
                        What ever units you are using in the model, either mm or inches. The API says inches but mm seemed to work for me.
                        • OxerO Offline
                          Oxer
                          I use metric units in my models for that, I suppose the Texture Size it will expressed in mm, is it so?
                          The Options Window is a bit little on Mac, I changed the window hight to 530 so I can see all options.
                          @@dlg=UI::WebDialog.new("FloorGenerator", false,"BTW",300,530,10,10,true)
                          • OxerO Offline
                            Oxer
                            I have created a icon for the plugin.
                            Floor Generator Icon
                            Icons FloorGenerator
                            • KrisidiousK Offline
                              Krisidious
                              Can we get something like this as a pattern?
                              Can you show us some patterns to build for you? let us help.
                              3D_Hatching_LedgeStone.skp
                              By: Kristoff Rand
                              • sdmitchS Offline
                                sdmitch
                                That pattern is just a bit to random I think. the closest I could get is a random length, width and thickness using the wood pattern
                                • pbacotP Offline
                                  Still after the holy grail, ay Kris? lol. I am trying to figure out how to do a stone wall surface (with SU hole punch components for windows etc.) and make some sort of detail at the corners that suggests the stone profile...
                                  That's not bad sdmitch Should keep looking at it!
                                    Krisidious
                                    lmao... And I will have it.
                                    By: Kristoff Rand
                                      Krisidious
                                      That looks pretty dame good sdmitch... if I had used a better tiling texture it would look better.
                                      By: Kristoff Rand
                                      • rvizR Offline
                                        rviz
                                        After 90 rotating the tool takes origins randomly: sometimes it's the upper corner, sometimes the lower one.
                                        But the most important: is there place for code optimization? It takes approx 5 min to put 2k tiles (to do it manually would take may be 0.5 min πŸ˜• ).
                                        • sdmitchS Offline
                                          sdmitch
                                          As with any plugin, if you can do it faster manually, then don't use the plugin.
                                          If you are using Corner origin, the corner closest to the point on the face that you pick will be used.
                                          • zieiosZ Offline
                                            zieios
                                            love it.... πŸ‘
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
