    OnKeyDown: getting the charcater value from key
    32 Posts 7 Posters 3.4k Views 7 Watching
      Anton_S
      Apparently key.chr doesn't return proper characters for all values. For that, we might want to sett up a hash of values and characters.
      CHARS = {
      # Standard keys
      0x30 => '0'
      0x31 => '1'
      0x32 => '2'
      0x33 => '3'
      0x34 => '4'
      0x35 => '5'
      0x36 => '6'
      0x37 => '7'
      0x38 => '8'
      0x39 => '9'
      0xBD => '-'
      0xBB => '+'
      0x0D => '=' # use enter key for =
      # Numpads
      0x60 => '0'
      0x61 => '1'
      0x62 => '2'
      0x63 => '3'
      0x64 => '4'
      0x65 => '5'
      0x66 => '6'
      0x67 => '7'
      0x68 => '8'
      0x69 => '9'
      0x6B => '+'
      0x6D => '-'
      0x6A => '*'
      0x6F => '/'
      So the filter set up would look like this now.
      def onKeyDown(key, repeat, flags, view)
        key_char = CHARS[key]
        return unless key_char
        # process
      This technique should work on Windows. I don't know about Macs though.
      • fredo6F Offline
        Anton,
        Thanks very much.
        I have the virtual keycodes on Mac too.
        The main issue is that these map physical keys, so it will be very difficult to have a reliable result for non-US keyboards for the the digits for instance, which may require a Shift (like on French keyboard).
        And you are right that flags does not bring much info.
        • tt_suT Offline
          tt_su
          Yea, the Tool class return key codes, not character codes. And they are system dependant.
          I'm not sure how you'd get the resulting character that would be produced, though should think there should be some system API for this. I'd have to search for that.
          • Dan RathbunD Offline
            Dan Rathbun
            @Anton: Would using ToUnicode() be better than ToAscii() ?
            I'm not here much anymore.
              Anton_S
              I just tested and seen no difference. I think it doesn't matter much.
              • tt_suT Offline
                tt_su
                Indeed this appear to be the correct function to use:
                http://msdn.microsoft.com/en-us/library/windows/desktop/ms646320(v=vs.85.aspx
                Translates the specified virtual-key code and keyboard state to the corresponding Unicode character or characters.
                Though, it probably produce a UTF-16LE string, transposing to UTF-8 would probably be best for interoperability with the rest of the SketchUp environment.
                  Anton_S
                  Nah, both of them are encoded in US-ASCII. πŸ˜•
                  adding char.force_encoding('UTF-8') should do the tick, aint it?
                  • tt_suT Offline
                    tt_su
                    You're talking about ToAscii?
                    I was looking at ToUnicode.
                    I'd be careful with force_encoding - it should only be used if you have raw binary data representing a string or if you know the string is incorrectly encoded. Otherwise one should transpose the en encoding.
                    foo = bar.encode("UTF-8")
                      Anton_S
                      Yes, the ToUnicode and ToAscii both return same formatted Ruby strings, but on the actual approach they don't. When I initially created a buffer char = 0.chr*2 it was already formatted in US-ASCII. The ToUnicodeand ToAscii simply fills the the specified buffer with ascii/unicode characters without changing the format of the Ruby string.
                      Changing char = 0.chr*2 to char= ' ' will initially create a UTF-8 formatted string, rather than the US-ASCII. The format remains unchanged when the ToUnicode/ToAscii functions fills the char string.
                      @tt_su said:
                      I'd be careful with force_encoding...
                      For some reason force_encoding even managed to crash SketchUp at some points when testing key_test.
                        Dan Rathbun
                        Ya'all need to be careful where testing string encoding, until MR1 comes out.
                        The correct default encoding is not properly set in MR0.
                          driven
                          if anyones prepared to admit it...
                          the other issue is why these things are so difficult on a mac...
                          apple doesn't support key logging and goes out of it's way to prevent it occurring...
                          apple does allow it IF it's for assistive devices to aid those with disabilities...
                          if you want to use 'assistive devices api' to do ordinary tasks, you need to connivence the 'admin' user to turn it on.
                          mac folk are reluctant to do this as it's system wide, and would enable malicious 'key loggers' to, key-log...
                            Dan Rathbun
                            Err.. found a Ruby Core bug.
                            Even after setting Encoding::default_internal="UTF-8"
                            the Integer#chr() method does not return a string in the default internal encoding.
                            .. however there is a workaround. Ruby 2.0's Integer#chr() method now takes an encoding argument, so, this:
                            char = 0.chr(Encoding::default_internal)*2
                            or this:
                            char = 0.chr("UTF-8")*2
                            WILL work.
                              Anton_S
                              Nice find Dan πŸ‘ I re-edited the Ruby code above.
                                Dan Rathbun
                                But you did not enclosed the encoding nickname string in quotes. That'll raise a NameError exception ("uninitialized constant UTF".)
                                  Anton_S
                                  Okay, I figured a way to get key via the Windows API. The code below will give you the key code of the exact character that your pressing. For instance,
                                  • Pressing 1 yields 1; Pressing Shift-1 returns !.
                                  • Pressing w yields w; Pressing Shift-w returns W.
                                  I guess it should work properly on the FranΓ§ais keyboard as well. Test it out.
                                  require 'Win32API'
                                  class KeyTest
                                    GetKeyboardState = Win32API.new('User32', 'GetKeyboardState', 'P', 'L')
                                    ToAscii          = Win32API.new('User32', 'ToAscii', 'LLPPL', 'L')
                                    ToUnicode        = Win32API.new('User32', 'ToUnicode', 'LLPPLL', 'L')
                                      buffer = 0.chr*256
                                      char = 0.chr('UTF-8')*2 # maintain UTF-8 encoding
                                      GetKeyboardState.call(buffer)
                                      res = ToUnicode.call(key, repeat, buffer, char, char.size, 0)
                                      #res = ToAscii.call(key, repeat, buffer, char, 0)
                                      return if res == 0
                                      char.strip!
                                      p char
                                      # process
                                  unless file_loaded?(__FILE__)
                                    UI.menu('Plugins').add_item('Key Test'){
                                      Sketchup.active_model.select_tool(KeyTest.new)
                                  You need Win32API.so for SU2013 and below though.
                                  Place in the Plugins folder. Access: Plugins > Key Test
                                    Anton_S
                                    Oh πŸ˜† Fixed
                                    • tt_suT Offline
                                      tt_su
                                      sigh "Unicode support" grumble kicks Ruby on the shin
                                        Dan Rathbun
                                        Yea did you look at the C code by clicking the method in the CHM ?
                                        It has a kind of convoluted switch statement.
                                        • 2 / 2
