    OnKeyDown: getting the charcater value from key
    32 Posts 7 Posters 4.0k Views 7 Watching
    • fredo6F
      @driven said:
      could this be adapted for SU ruby?
      https://gist.github.com/acook/4190379
      Thanks. Unfortunately, I did not find a way to get anything out of $stdin. The problem is that the class Tool is based on events and therefore, the class is notified about keys, once entered, and cannot get the key.
      • fredo6F
        @dan rathbun said:
        This kind of thing was discussed years ago, in a topic that Jim posted his key inspector tool.
        Dan,
        I had already browsed some of these threads. Thanks.
        I think for tracking Shoft, Ctrl and arrows, it is clear.
        But what I am trying to do is simplyget a natural character(like the digits [0-9)) and I really do not understand the logic.
        • the key seems to be the ascii value, but only on main keyboard and for the main key (i.e. ignoring the Shift state)
        • the flag value is for me totally cryptic (in addition it is very different on keydown and keyup for the same key).
        I guess there must be some logic encoded Under the Hood and that's what I am trying to understand.
        • Dan RathbunD
          Dan Rathbun
          Oh yes it is quite clear that there are issues, and it IS a pain in the butt.
          I remember vaguely someone explaining how the flag bit masks worked, and how to | and & them properly.
          It would be nicve if the API creates a KeyFlag subclass of integer with methods like:
          .shift? .control? .command? .alt?
          ... etc.
          I'm not here much anymore.
            Anton_S
            @fredo6 said:
            My goal was to see if the keys could be transformed into characters in order to trap the 0-9, =, +, -, *, / characters.
            The tool onKeyDown method returns virtual key constant value, key repeat, key flags, and view instance.
            Here is the list of Virtual Key Codes on Windows: http://msdn.microsoft.com/en-us/library/windows/desktop/dd375731(v=vs.85).aspx
            key.chr will return the character of the value.
            for instance 87.chr returns 'W'
            You can filter the keys like this:
            def onKeyDown(key, repeat, flags, view)
              if %w(1 2 3 4 5 6 7 8 9 0 = + - * /).include?(key.chr)
                # process code here
              else
                return
            How to convert numeric decimal to hexadecimal:
            87.to_s(16) # => '57' or 0x57 which can be found in the virtual key codes list.
            When viewing flags you might first want to convert them to hexadecimal.
            The flags don't give you anything special about the key.
            Here is what they give: http://msdn.microsoft.com/en-us/library/windows/desktop/ms646267(v=vs.85).aspx#_win32_Keystroke_Message_Flags
              Anton_S
              Apparently key.chr doesn't return proper characters for all values. For that, we might want to sett up a hash of values and characters.
              CHARS = {
              # Standard keys
              0x30 => '0'
              0x31 => '1'
              0x32 => '2'
              0x33 => '3'
              0x34 => '4'
              0x35 => '5'
              0x36 => '6'
              0x37 => '7'
              0x38 => '8'
              0x39 => '9'
              0xBD => '-'
              0xBB => '+'
              0x0D => '=' # use enter key for =
              # Numpads
              0x60 => '0'
              0x61 => '1'
              0x62 => '2'
              0x63 => '3'
              0x64 => '4'
              0x65 => '5'
              0x66 => '6'
              0x67 => '7'
              0x68 => '8'
              0x69 => '9'
              0x6B => '+'
              0x6D => '-'
              0x6A => '*'
              0x6F => '/'
              So the filter set up would look like this now.
                key_char = CHARS[key]
                return unless key_char
                # process
              This technique should work on Windows. I don't know about Macs though.
              • fredo6F
                Anton,
                Thanks very much.
                I have the virtual keycodes on Mac too.
                The main issue is that these map physical keys, so it will be very difficult to have a reliable result for non-US keyboards for the the digits for instance, which may require a Shift (like on French keyboard).
                And you are right that flags does not bring much info.
                • tt_suT
                  tt_su
                  Yea, the Tool class return key codes, not character codes. And they are system dependant.
                  I'm not sure how you'd get the resulting character that would be produced, though should think there should be some system API for this. I'd have to search for that.
                  • Dan RathbunD
                    Dan Rathbun
                    @Anton: Would using ToUnicode() be better than ToAscii() ?
                      Anton_S
                      I just tested and seen no difference. I think it doesn't matter much.
                      • tt_suT
                        tt_su
                        Indeed this appear to be the correct function to use:
                        http://msdn.microsoft.com/en-us/library/windows/desktop/ms646320(v=vs.85.aspx
                        Translates the specified virtual-key code and keyboard state to the corresponding Unicode character or characters.
                        Though, it probably produce a UTF-16LE string, transposing to UTF-8 would probably be best for interoperability with the rest of the SketchUp environment.
                          Anton_S
                          Nah, both of them are encoded in US-ASCII. ๐Ÿ˜•
                          adding char.force_encoding('UTF-8') should do the tick, aint it?
                          • tt_suT
                            tt_su
                            You're talking about ToAscii?
                            I was looking at ToUnicode.
                            I'd be careful with force_encoding - it should only be used if you have raw binary data representing a string or if you know the string is incorrectly encoded. Otherwise one should transpose the en encoding.
                            foo = bar.encode("UTF-8")
                              Anton_S
                              Yes, the ToUnicode and ToAscii both return same formatted Ruby strings, but on the actual approach they don't. When I initially created a buffer char = 0.chr*2 it was already formatted in US-ASCII. The ToUnicodeand ToAscii simply fills the the specified buffer with ascii/unicode characters without changing the format of the Ruby string.
                              Changing char = 0.chr*2 to char= ' ' will initially create a UTF-8 formatted string, rather than the US-ASCII. The format remains unchanged when the ToUnicode/ToAscii functions fills the char string.
                              @tt_su said:
                              I'd be careful with force_encoding...
                              For some reason force_encoding even managed to crash SketchUp at some points when testing key_test.
                              • Dan RathbunD
                                Dan Rathbun
                                Ya'all need to be careful where testing string encoding, until MR1 comes out.
                                The correct default encoding is not properly set in MR0.
                                  driven
                                  if anyones prepared to admit it...
                                  the other issue is why these things are so difficult on a mac...
                                  apple doesn't support key logging and goes out of it's way to prevent it occurring...
                                  apple does allow it IF it's for assistive devices to aid those with disabilities...
                                  if you want to use 'assistive devices api' to do ordinary tasks, you need to connivence the 'admin' user to turn it on.
                                  mac folk are reluctant to do this as it's system wide, and would enable malicious 'key loggers' to, key-log...
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Err.. found a Ruby Core bug.
                                    Even after setting Encoding::default_internal="UTF-8"
                                    the Integer#chr() method does not return a string in the default internal encoding.
                                    .. however there is a workaround. Ruby 2.0's Integer#chr() method now takes an encoding argument, so, this:
                                    char = 0.chr(Encoding::default_internal)*2
                                    or this:
                                    char = 0.chr("UTF-8")*2
                                    WILL work.
                                      Anton_S
                                      Nice find Dan ๐Ÿ‘ I re-edited the Ruby code above.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        But you did not enclosed the encoding nickname string in quotes. That'll raise a NameError exception ("uninitialized constant UTF".)
                                          Anton_S
                                          Okay, I figured a way to get key via the Windows API. The code below will give you the key code of the exact character that your pressing. For instance,
                                          • Pressing 1 yields 1; Pressing Shift-1 returns !.
                                          • Pressing w yields w; Pressing Shift-w returns W.
                                          I guess it should work properly on the Franรงais keyboard as well. Test it out.
                                          require 'Win32API'
                                          class KeyTest
                                            GetKeyboardState = Win32API.new('User32', 'GetKeyboardState', 'P', 'L')
                                            ToAscii          = Win32API.new('User32', 'ToAscii', 'LLPPL', 'L')
                                            ToUnicode        = Win32API.new('User32', 'ToUnicode', 'LLPPLL', 'L')
                                              buffer = 0.chr*256
                                              char = 0.chr('UTF-8')*2 # maintain UTF-8 encoding
                                              GetKeyboardState.call(buffer)
                                              res = ToUnicode.call(key, repeat, buffer, char, char.size, 0)
                                              #res = ToAscii.call(key, repeat, buffer, char, 0)
                                              return if res == 0
                                              char.strip!
                                              p char
                                              # process
                                          unless file_loaded?(__FILE__)
                                            UI.menu('Plugins').add_item('Key Test'){
                                              Sketchup.active_model.select_tool(KeyTest.new)
                                          You need Win32API.so for SU2013 and below though.
                                          Place in the Plugins folder. Access: Plugins > Key Test
                                            Anton_S
                                            Oh ๐Ÿ˜† Fixed
