    OnKeyDown: getting the charcater value from key
    32 Posts 7 Posters 4.0k Views 7 Watching
    • Dan RathbunD
      Dan Rathbun
      @Anton: Would using ToUnicode() be better than ToAscii() ?
      I'm not here much anymore.
        Anton_S
        I just tested and seen no difference. I think it doesn't matter much.
        • tt_suT
          tt_su
          Indeed this appear to be the correct function to use:
          http://msdn.microsoft.com/en-us/library/windows/desktop/ms646320(v=vs.85.aspx
          Translates the specified virtual-key code and keyboard state to the corresponding Unicode character or characters.
          Though, it probably produce a UTF-16LE string, transposing to UTF-8 would probably be best for interoperability with the rest of the SketchUp environment.
            Anton_S
            Nah, both of them are encoded in US-ASCII. πŸ˜•
            adding char.force_encoding('UTF-8') should do the tick, aint it?
            • tt_suT
              tt_su
              You're talking about ToAscii?
              I was looking at ToUnicode.
              I'd be careful with force_encoding - it should only be used if you have raw binary data representing a string or if you know the string is incorrectly encoded. Otherwise one should transpose the en encoding.
              foo = bar.encode("UTF-8")
                Anton_S
                Yes, the ToUnicode and ToAscii both return same formatted Ruby strings, but on the actual approach they don't. When I initially created a buffer char = 0.chr*2 it was already formatted in US-ASCII. The ToUnicodeand ToAscii simply fills the the specified buffer with ascii/unicode characters without changing the format of the Ruby string.
                Changing char = 0.chr*2 to char= ' ' will initially create a UTF-8 formatted string, rather than the US-ASCII. The format remains unchanged when the ToUnicode/ToAscii functions fills the char string.
                @tt_su said:
                I'd be careful with force_encoding...
                For some reason force_encoding even managed to crash SketchUp at some points when testing key_test.
                • Dan RathbunD
                  Dan Rathbun
                  Ya'all need to be careful where testing string encoding, until MR1 comes out.
                  The correct default encoding is not properly set in MR0.
                    driven
                    if anyones prepared to admit it...
                    the other issue is why these things are so difficult on a mac...
                    apple doesn't support key logging and goes out of it's way to prevent it occurring...
                    apple does allow it IF it's for assistive devices to aid those with disabilities...
                    if you want to use 'assistive devices api' to do ordinary tasks, you need to connivence the 'admin' user to turn it on.
                    mac folk are reluctant to do this as it's system wide, and would enable malicious 'key loggers' to, key-log...
                    • Dan RathbunD
                      Dan Rathbun
                      Err.. found a Ruby Core bug.
                      Even after setting Encoding::default_internal="UTF-8"
                      the Integer#chr() method does not return a string in the default internal encoding.
                      .. however there is a workaround. Ruby 2.0's Integer#chr() method now takes an encoding argument, so, this:
                      char = 0.chr(Encoding::default_internal)*2
                      or this:
                      char = 0.chr("UTF-8")*2
                      WILL work.
                        Anton_S
                        Nice find Dan πŸ‘ I re-edited the Ruby code above.
                        • Dan RathbunD
                          Dan Rathbun
                          But you did not enclosed the encoding nickname string in quotes. That'll raise a NameError exception ("uninitialized constant UTF".)
                            Anton_S
                            Okay, I figured a way to get key via the Windows API. The code below will give you the key code of the exact character that your pressing. For instance,
                            • Pressing 1 yields 1; Pressing Shift-1 returns !.
                            • Pressing w yields w; Pressing Shift-w returns W.
                            I guess it should work properly on the FranΓ§ais keyboard as well. Test it out.
                            require 'Win32API'
                            class KeyTest
                              GetKeyboardState = Win32API.new('User32', 'GetKeyboardState', 'P', 'L')
                              ToAscii          = Win32API.new('User32', 'ToAscii', 'LLPPL', 'L')
                              ToUnicode        = Win32API.new('User32', 'ToUnicode', 'LLPPLL', 'L')
                              def onKeyDown(key, repeat, flags, view)
                                buffer = 0.chr*256
                                char = 0.chr('UTF-8')*2 # maintain UTF-8 encoding
                                GetKeyboardState.call(buffer)
                                res = ToUnicode.call(key, repeat, buffer, char, char.size, 0)
                                #res = ToAscii.call(key, repeat, buffer, char, 0)
                                return if res == 0
                                char.strip!
                                p char
                                # process
                            unless file_loaded?(__FILE__)
                              UI.menu('Plugins').add_item('Key Test'){
                                Sketchup.active_model.select_tool(KeyTest.new)
                            You need Win32API.so for SU2013 and below though.
                            Place in the Plugins folder. Access: Plugins > Key Test
                              Anton_S
                              Oh πŸ˜† Fixed
                              • tt_suT
                                tt_su
                                sigh "Unicode support" grumble kicks Ruby on the shin
                                • Dan RathbunD
                                  Dan Rathbun
                                  Yea did you look at the C code by clicking the method in the CHM ?
                                  It has a kind of convoluted switch statement.
                                  • 2 / 2
