    OnKeyDown: getting the charcater value from key
    32 Posts 7 Posters 2.7k Views 7 Watching
      Anton_S
      @tt_su said:
      You're talking about ToAscii?
      I was looking at ToUnicode.
      Yes, the ToUnicode and ToAscii both return same formatted Ruby strings, but on the actual approach they don't. When I initially created a buffer char = 0.chr*2 it was already formatted in US-ASCII. The ToUnicodeand ToAscii simply fills the the specified buffer with ascii/unicode characters without changing the format of the Ruby string.
      Changing char = 0.chr*2 to char= ' ' will initially create a UTF-8 formatted string, rather than the US-ASCII. The format remains unchanged when the ToUnicode/ToAscii functions fills the char string.
      @tt_su said:
      I'd be careful with force_encoding...
      For some reason force_encoding even managed to crash SketchUp at some points when testing key_test.
      • Dan RathbunD Offline
        Dan Rathbun
        Ya'all need to be careful where testing string encoding, until MR1 comes out.
        The correct default encoding is not properly set in MR0.
        I'm not here much anymore.
          driven
          if anyones prepared to admit it...
          the other issue is why these things are so difficult on a mac...
          apple doesn't support key logging and goes out of it's way to prevent it occurring...
          apple does allow it IF it's for assistive devices to aid those with disabilities...
          if you want to use 'assistive devices api' to do ordinary tasks, you need to connivence the 'admin' user to turn it on.
          mac folk are reluctant to do this as it's system wide, and would enable malicious 'key loggers' to, key-log...
            Dan Rathbun
            Err.. found a Ruby Core bug.
            Even after setting Encoding::default_internal="UTF-8"
            the Integer#chr() method does not return a string in the default internal encoding.
            .. however there is a workaround. Ruby 2.0's Integer#chr() method now takes an encoding argument, so, this:
            char = 0.chr(Encoding::default_internal)*2
            or this:
            char = 0.chr("UTF-8")*2
            WILL work.
              Anton_S
              Nice find Dan 👍 I re-edited the Ruby code above.
                Dan Rathbun
                But you did not enclosed the encoding nickname string in quotes. That'll raise a NameError exception ("uninitialized constant UTF".)
                  Anton_S
                  Okay, I figured a way to get key via the Windows API. The code below will give you the key code of the exact character that your pressing. For instance,
                  • Pressing 1 yields 1; Pressing Shift-1 returns !.
                  • Pressing w yields w; Pressing Shift-w returns W.
                  I guess it should work properly on the Français keyboard as well. Test it out.
                  require 'Win32API'
                  class KeyTest
                    GetKeyboardState = Win32API.new('User32', 'GetKeyboardState', 'P', 'L')
                    ToAscii          = Win32API.new('User32', 'ToAscii', 'LLPPL', 'L')
                    ToUnicode        = Win32API.new('User32', 'ToUnicode', 'LLPPLL', 'L')
                    def onKeyDown(key, repeat, flags, view)
                      buffer = 0.chr*256
                      char = 0.chr('UTF-8')*2 # maintain UTF-8 encoding
                      GetKeyboardState.call(buffer)
                      res = ToUnicode.call(key, repeat, buffer, char, char.size, 0)
                      #res = ToAscii.call(key, repeat, buffer, char, 0)
                      return if res == 0
                      char.strip!
                      p char
                      # process
                  unless file_loaded?(__FILE__)
                    UI.menu('Plugins').add_item('Key Test'){
                      Sketchup.active_model.select_tool(KeyTest.new)
                  You need Win32API.so for SU2013 and below though.
                  Place in the Plugins folder. Access: Plugins > Key Test
                    Anton_S
                    Oh 😆 Fixed
                    • tt_suT Offline
                      tt_su
                      sigh "Unicode support" grumble kicks Ruby on the shin
                        Dan Rathbun
                        Yea did you look at the C code by clicking the method in the CHM ?
                        It has a kind of convoluted switch statement.
                        • 2 / 2
