    OnKeyDown: getting the charcater value from key
    32 Posts 7 Posters 2.9k Views 7 Watching
    • dukejazzD Offline
      dukejazz
      by fredo6 Β» Today, 11:09 am
      This give me a key down swicth Ideas
      Great !!!
      thanks fredo
      • fredo6F Offline
        @dan rathbun said:
        @fredo6 said:
        My goal was to see if the keys could be transformed into characters in order to trap the 0-9, =, +, -, *, / characters.
        The API indicates you should probably use the onUserText() callback, instead.
        Dan,
        I was trying to see if it is possible to have a independent VCB as a web dialog box.
        Basically, when you type the first character ([0-9], or *=+-/()) you switch to a regular web dialog field where you are free to type other letters, in particular a suffix, which may happen to be a shortcut. So it does not really change the workflow of the user.
        The benefit could also be to have more extended syntax, add a calculator, etc....
        The only issue is to decode correctly the first character.
        I can of course hard code the key / flags, but would need to check on Mac too.
        Anyway, at this stage, I was first trying to understand the logic.
        • Dan RathbunD Offline
          Dan Rathbun
          @vcb_active = true
            def enableVCB?
              return @vcb_active
          ... then get the 1st char with onUserText()
          if it is "a special character" then set @vcb_active = false and show your special vcb dialog (or input box).
          When things return to normal, set @vcb_active = true again.
          I'm not here much anymore.
            Another little foible is that [unlike PC] .onKeyDown with TAB doesn't "fire" on MAC, but .onKeyUp with TAB it does πŸ˜’
            • fredo6F Offline
              Dan,
              It does not work, and for two good reasons:
              1. EnableVCB? is not checked continuously but only after a click
              2. onUserText fires when you have type Enter, not before. To keep the same workflow, the VCB psuedo input box has to appear 'naturally when typing characters.
              My original question was about the logic in key and flags on onKeyDown/Up events, but apparently this is not an obvious one.
              @TIG: Currently, I am just trying to trap and decode a few characters: numeric and arithmetic signs, whether typed on the main keyboard or numpad. I know for TAB and always use it on key Up (in general, I prefer to trigger actions on key up, to avoid pending events).
                Dan Rathbun
                These "rules" should be IN the API dictioanry. πŸ˜’
                  Dan Rathbun
                  This kind of thing was discussed years ago, in a topic that Jim posted his key inspector tool.
                  Jim's tool:
                  https://sites.google.com/site/jimfoltz/my-sketchup-plugins/key-code-tool/jf_KeyTool.rb
                  See:
                  [url=http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=34002:24695zr7]My Apple Keyboard VK_KEYS[/url:24695zr7]
                  [url=http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=37217%26amp;p=328264:24695zr7]very difficult key codes![/url:24695zr7]
                  [url=http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=18860:24695zr7]flags on onKeyDown?[/url:24695zr7]
                  [url=http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=12642:24695zr7]keycodes intelmac[/url:24695zr7]
                  • Jim's KeyTool.rb is also posted in this topic thread, but not sure if it is the latest version ?
                  [url=http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=2012:24695zr7]Key sequence in ruby[/url:24695zr7]
                    driven
                    could this be adapted for SU ruby?
                    https://gist.github.com/acook/4190379
                    • fredo6F Offline
                      Thanks. Unfortunately, I did not find a way to get anything out of $stdin. The problem is that the class Tool is based on events and therefore, the class is notified about keys, once entered, and cannot get the key.
                      • fredo6F Offline
                        Dan,
                        I had already browsed some of these threads. Thanks.
                        I think for tracking Shoft, Ctrl and arrows, it is clear.
                        But what I am trying to do is simplyget a natural character(like the digits [0-9)) and I really do not understand the logic.
                        • the key seems to be the ascii value, but only on main keyboard and for the main key (i.e. ignoring the Shift state)
                        • the flag value is for me totally cryptic (in addition it is very different on keydown and keyup for the same key).
                        I guess there must be some logic encoded Under the Hood and that's what I am trying to understand.
                          Dan Rathbun
                          Oh yes it is quite clear that there are issues, and it IS a pain in the butt.
                          I remember vaguely someone explaining how the flag bit masks worked, and how to | and & them properly.
                          It would be nicve if the API creates a KeyFlag subclass of integer with methods like:
                          .shift? .control? .command? .alt?
                          ... etc.
                            Anton_S
                            The tool onKeyDown method returns virtual key constant value, key repeat, key flags, and view instance.
                            Here is the list of Virtual Key Codes on Windows: http://msdn.microsoft.com/en-us/library/windows/desktop/dd375731(v=vs.85).aspx
                            key.chr will return the character of the value.
                            for instance 87.chr returns 'W'
                            You can filter the keys like this:
                            def onKeyDown(key, repeat, flags, view)
                              if %w(1 2 3 4 5 6 7 8 9 0 = + - * /).include?(key.chr)
                                # process code here
                              else
                                return
                            How to convert numeric decimal to hexadecimal:
                            87.to_s(16) # => '57' or 0x57 which can be found in the virtual key codes list.
                            When viewing flags you might first want to convert them to hexadecimal.
                            The flags don't give you anything special about the key.
                            Here is what they give: http://msdn.microsoft.com/en-us/library/windows/desktop/ms646267(v=vs.85).aspx#_win32_Keystroke_Message_Flags
                              Anton_S
                              Apparently key.chr doesn't return proper characters for all values. For that, we might want to sett up a hash of values and characters.
                              CHARS = {
                              # Standard keys
                              0x30 => '0'
                              0x31 => '1'
                              0x32 => '2'
                              0x33 => '3'
                              0x34 => '4'
                              0x35 => '5'
                              0x36 => '6'
                              0x37 => '7'
                              0x38 => '8'
                              0x39 => '9'
                              0xBD => '-'
                              0xBB => '+'
                              0x0D => '=' # use enter key for =
                              # Numpads
                              0x60 => '0'
                              0x61 => '1'
                              0x62 => '2'
                              0x63 => '3'
                              0x64 => '4'
                              0x65 => '5'
                              0x66 => '6'
                              0x67 => '7'
                              0x68 => '8'
                              0x69 => '9'
                              0x6B => '+'
                              0x6D => '-'
                              0x6A => '*'
                              0x6F => '/'
                              So the filter set up would look like this now.
                                key_char = CHARS[key]
                                return unless key_char
                                # process
                              This technique should work on Windows. I don't know about Macs though.
                              • fredo6F Offline
                                Anton,
                                Thanks very much.
                                I have the virtual keycodes on Mac too.
                                The main issue is that these map physical keys, so it will be very difficult to have a reliable result for non-US keyboards for the the digits for instance, which may require a Shift (like on French keyboard).
                                And you are right that flags does not bring much info.
                                • tt_suT Offline
                                  tt_su
                                  Yea, the Tool class return key codes, not character codes. And they are system dependant.
                                  I'm not sure how you'd get the resulting character that would be produced, though should think there should be some system API for this. I'd have to search for that.
                                    Dan Rathbun
                                    @Anton: Would using ToUnicode() be better than ToAscii() ?
                                      Anton_S
                                      I just tested and seen no difference. I think it doesn't matter much.
                                      • tt_suT Offline
                                        tt_su
                                        Indeed this appear to be the correct function to use:
                                        http://msdn.microsoft.com/en-us/library/windows/desktop/ms646320(v=vs.85.aspx
                                        Translates the specified virtual-key code and keyboard state to the corresponding Unicode character or characters.
                                        Though, it probably produce a UTF-16LE string, transposing to UTF-8 would probably be best for interoperability with the rest of the SketchUp environment.
                                          Anton_S
                                          Nah, both of them are encoded in US-ASCII. πŸ˜•
                                          adding char.force_encoding('UTF-8') should do the tick, aint it?
                                          • tt_suT Offline
                                            tt_su
                                            You're talking about ToAscii?
                                            I was looking at ToUnicode.
                                            I'd be careful with force_encoding - it should only be used if you have raw binary data representing a string or if you know the string is incorrectly encoded. Otherwise one should transpose the en encoding.
                                            foo = bar.encode("UTF-8")
