    [Plugin] Align tool 3D (bug fix)
    58 Posts 38 Posters 155.7k Views 38 Watching
    • kuponoK Offline
      kupono
      Align tool 3D doesn't want to work with SU 2014. Is this a ruby version thing? I miss being able to use it.
      • O Offline
        otb designworks
        Can anyone confirm that this is not working in Su14 on a mac mavericks?
        I installed the plugin both through the sketchucation plugin store and also through Didier's thread here.
        Neither plugin appears in TOOLS and there is no align choice in the context menu when something is selected.
        It's like the plugin doesn't exist, though it shows up in the plugin manager, and is in the user/library.../plugins location.
        Thoughts?
        Cheers, Chuck
        OTB Designworks is on Youtube
        • BoxB Offline
          This might get it going for you. On the appropriate file, this is copied from the lines to tubes thread.
          @tig said:
          Didier needs to rework his rb file for v2014 compatibility and republish it...
          BUT you can do it temporarily for your own use, even though his script is 'packed'.
          Open the file lines2tubes.rb in Notepad, and go to the end:
          Change
          ...}.unpack("m")**.to_s**
          to read
          ...}.unpack("m")**[0]**
          Save the changes.
          Restart SketchUp.
          The script will then load and work in v2014 !
          This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
          These edited scripts will also load and work in earlier SketchUp versions too... ๐Ÿค“
          • kuponoK Offline
            kupono
            This is what I get when opening align_tool.rb in notepad.Bytecode?
            • BoxB Offline
              And if you scroll to the end as Tig says do you not see the bit that needs to be changed.
              • O Offline
                otb designworks
                Thanks for the response!
                I changed the code to read as TIG said it should (image 1). I also tried it with a space between the ) and the [ with no difference
                Now, when I start SU, I get this error message (image 2)
                thoughts?
                Cheers, Chuck
                • BoxB Offline
                  Sorry, I only know it works on windows.
                  • O Offline
                    otb designworks
                    Weird...
                    While I understand the drive to "upgrade" to Ruby 2.0, it is pretty frustrating that many old plugins don't work any more.
                    Cheers, Chuck
                    • N Offline
                      nagrom345
                      I can't get this plugin to work with Sketchup 2014. Does anyone have and ideas about this. Thanks.
                        agrazdi
                        Is it posible to update it for SU 2014 ?
                          agrazdi
                          I didn`t read TIG's post. I followed his instructions and it works fine in su 14.
                          Thanks TIG
                            Didier has agreed that I might update some of his Plugins in the PluginStore so they are v2014/2015 compatible.
                            This is the latest version http://sketchucation.com/pluginstore?pln=align_tool
                            • kuponoK Offline
                              kupono
                              Thanks for the updates Tig. I was missing Align 3D.
                              • john2J Offline
                                john2
                                this tool is not showing up in context menu. I am using version 2014 make
                                Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                  It works fine in v2014 and v2015.
                                  It appears near the end of the Context menu as 'Align' - you must have something Selected...
                                  What happens if you copy+paste this command into the Ruby Console + <enter> ?
                                  load 'align_tool.rb'
                                  The older versions <=v1.1 are NOT compatible beyond v2013, because of the Ruby upgrade.
                                  So, are you using the very latest version [v1.1x] available from the PluginStore which was made compatible with all SketchUp versions [sorry but it's in ENglish only]...
                                  http://sketchucation.com/forums/viewtopic.php?p=76774#p76774
                                  If NOT then please get the latest version's RBZ installed...
                                  Report back if there are continuing issues...
                                  • john2J Offline
                                    john2
                                    I get this
                                    true
                                    That's really weird. I am getting this option align in my right click menu. Restarted sketchup and wow! my option is coming.
                                    This problem was occuring in both my PC and laptop. I am sitting on my laptop currently and the problem is gone. Didn't know what created it. Moreover on both my machines, I installed the latest version straightaway by accessing the plugin store inside sketchup via SCF plugin. Thanks for replying. ๐Ÿ˜„ ๐Ÿ‘ Maybe this ruby console has healed my problem, dont know. ๐Ÿ˜„
                                      If it recurs see if there are any Ruby Console messages and post them.
                                      Maybe it was just a general glitch that needed a SketchUp restart to fix it ?
                                        rv1974
                                        There's a huge issue with this tool (I noticed it after dekade of using ๐Ÿ˜ฎ ) -
                                        it distorts objects. Additional operation needed (reset skew, rotation) afterwards. Any chance to to fix it please?
                                        • 3 / 3
