    [Plugin] Align tool 3D (bug fix)
    58 Posts 38 Posters 159.2k Views 38 Watching
      JPC2j3
      I recently down loaded and installed the plug-in in the zip file. I have been experimenting with the plug-in to learn how it works. When I try to use the tool, my SketchUp crashes every time. Let me explain as best as I can what happens.
      I create two objects (usually two cubes or rectangles; Iโ€™m just experimenting). I pick a corner of one object and create an X and Y axis (should there be a Z axis showing at this point?). When I try to connect the origin point of the first object to the corner of the second object, I get a crash.
      I have viewed the training video numerous times so I believe I am using the plug-in correctly. Iโ€™m seeking some help in understanding what I am doing wrong.
      • robertWanR
        robertWan
        Could you add an option to copy (Ctrl) for plugin ALIGN 3D? Now objects are moved.
        Robert
        • kuponoK
          kupono
          Align tool 3D doesn't want to work with SU 2014. Is this a ruby version thing? I miss being able to use it.
          • O
            otb designworks
            Can anyone confirm that this is not working in Su14 on a mac mavericks?
            I installed the plugin both through the sketchucation plugin store and also through Didier's thread here.
            Neither plugin appears in TOOLS and there is no align choice in the context menu when something is selected.
            It's like the plugin doesn't exist, though it shows up in the plugin manager, and is in the user/library.../plugins location.
            Thoughts?
            Cheers, Chuck
            OTB Designworks is on Youtube
            • BoxB
              This might get it going for you. On the appropriate file, this is copied from the lines to tubes thread.
              @tig said:
              Didier needs to rework his rb file for v2014 compatibility and republish it...
              BUT you can do it temporarily for your own use, even though his script is 'packed'.
              Open the file lines2tubes.rb in Notepad, and go to the end:
              Change
              ...}.unpack("m")**.to_s**
              to read
              ...}.unpack("m")**[0]**
              Save the changes.
              Restart SketchUp.
              The script will then load and work in v2014 !
              This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
              These edited scripts will also load and work in earlier SketchUp versions too... ๐Ÿค“
              • kuponoK
                kupono
                This is what I get when opening align_tool.rb in notepad.Bytecode?
                • BoxB
                  And if you scroll to the end as Tig says do you not see the bit that needs to be changed.
                  • O
                    otb designworks
                    Thanks for the response!
                    I changed the code to read as TIG said it should (image 1). I also tried it with a space between the ) and the [ with no difference
                    Now, when I start SU, I get this error message (image 2)
                    thoughts?
                    Cheers, Chuck
                    • BoxB
                      Sorry, I only know it works on windows.
                      • O
                        otb designworks
                        Weird...
                        While I understand the drive to "upgrade" to Ruby 2.0, it is pretty frustrating that many old plugins don't work any more.
                        Cheers, Chuck
                        • N
                          nagrom345
                          I can't get this plugin to work with Sketchup 2014. Does anyone have and ideas about this. Thanks.
                            agrazdi
                            Is it posible to update it for SU 2014 ?
                              agrazdi
                              I didn`t read TIG's post. I followed his instructions and it works fine in su 14.
                              Thanks TIG
                                Didier has agreed that I might update some of his Plugins in the PluginStore so they are v2014/2015 compatible.
                                This is the latest version http://sketchucation.com/pluginstore?pln=align_tool
                                • kuponoK
                                  kupono
                                  Thanks for the updates Tig. I was missing Align 3D.
                                  • john2J
                                    john2
                                    this tool is not showing up in context menu. I am using version 2014 make
                                    Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                      It works fine in v2014 and v2015.
                                      It appears near the end of the Context menu as 'Align' - you must have something Selected...
                                      What happens if you copy+paste this command into the Ruby Console + <enter> ?
                                      load 'align_tool.rb'
                                      The older versions <=v1.1 are NOT compatible beyond v2013, because of the Ruby upgrade.
                                      So, are you using the very latest version [v1.1x] available from the PluginStore which was made compatible with all SketchUp versions [sorry but it's in ENglish only]...
                                      http://sketchucation.com/forums/viewtopic.php?p=76774#p76774
                                      If NOT then please get the latest version's RBZ installed...
                                      Report back if there are continuing issues...
                                      • john2J
                                        john2
                                        I get this
                                        true
                                        That's really weird. I am getting this option align in my right click menu. Restarted sketchup and wow! my option is coming.
                                        This problem was occuring in both my PC and laptop. I am sitting on my laptop currently and the problem is gone. Didn't know what created it. Moreover on both my machines, I installed the latest version straightaway by accessing the plugin store inside sketchup via SCF plugin. Thanks for replying. ๐Ÿ˜„ ๐Ÿ‘ Maybe this ruby console has healed my problem, dont know. ๐Ÿ˜„
                                          If it recurs see if there are any Ruby Console messages and post them.
                                          Maybe it was just a general glitch that needed a SketchUp restart to fix it ?
                                            rv1974
                                            There's a huge issue with this tool (I noticed it after dekade of using ๐Ÿ˜ฎ ) -
                                            it distorts objects. Additional operation needed (reset skew, rotation) afterwards. Any chance to to fix it please?
                                            • 3 / 3
