    Jumpers
    40 Posts 8 Posters 3.0k Views 8 Watching
    • KrisidiousK Offline
      Krisidious
      there's a folding pattern plugin around here somewhere. It unfolds models.
      By: Kristoff Rand
        jumpersrfun
        @driven said:
        where are you based?
        maybe there someone local that can talk you through the whole process... [ offer a ' free lunch ' ]
        The first thing I'd be asking are are 'you' doing the fabrication, or who is?
        I am in Los Angeles.
          jumpersrfun
          Yes, I will be doing to fabrication along with another person.
          • jeff hammondJ Offline
            getting a good Unroll Surface function will make things much easier on you.. i'm not sure how the sketchup plugins work out but i will say that in another software, this is a one click operation..
            after that, you'll need to research or trial&error how much tag(?) you'll need to extend the surfaces by in order to do the sewing (but i take it you're already have some sewing knowledge that you'll be bringing to the table?)
            how good are you at sketchup? like- do you already have the designs roughed out and you just need to figure out how to slice it up -or- do you need help with drawing the ideas as well?
              jumpersrfun
              [attachment=0:1esn4guh]<!-- ia0 -->Screen Shot 2014-04-22 at 12.02.57 AM.jpg<!-- ia0 -->[/attachment:1esn4guh]
              Thanks Jeff, and wow, that looks good, but I don't see the unrolled pillars, or maybe I'm not seeing it correctly. I'm a newby to sketchup. Been using it for 2 days now and I don't even have the design yet, other than the photo I uploaded here. I played around in Sketchup, but there's so much to learn with so little time. So yeah, I'll need the design, as well as how to slice it all up.
              As for the allowable extension for sewing, it's simple: 1" to 2" depending if the part is going to be sewed using a double, or single needle sewing machine, and if it's a critical part of the jumper (for example, the area where the floor attaches to the pillars, windows, etc) that needs reinforcement.
                here's a color coded look at a portion of it.. (you can also adjust where the seams are so the vertical seam isn't slicing through another hole as shown here etc.. i just did a quick&dirty version for sake of example)
                when you really do it, there are labels placed on each seam and each corresponding piece which sews together at that point.. if i show that from a wide view, it looks too cluttered.. a small example of that:
                but i think that's getting too far ahead.. you should first try just drawing ,say, the house pictured in your top post.. people here will help you along with that part.. once you get an ok grasp at basic modeling in sketchup, then slice it up πŸ˜‰
                have you tried drawing the house already? did you finish it or are you getting stuck in any certain part?
                [edit] or- are you not super interested in learning sketchup and more interested in hiring someone to do the drawings? or somewhere in the middle?
                  Krisidious
                  You can mention that other program Jeff... lol
                  By: Kristoff Rand
                    ha.. i feel i mention a little too much lately.. but it's rhino.
                      Krisidious
                      If sketchup can't do something, I think it's perfectly reasonable to tell people what will. Especially if they are needing something done.
                      By: Kristoff Rand
                        jumpersrfun
                        [attachment=1:2k2l1ejx]<!-- ia1 -->Screen Shot 2014-04-22 at 12.38.35 AM.jpg<!-- ia1 -->[/attachment:2k2l1ejx]
                        [attachment=0:2k2l1ejx]<!-- ia0 -->Screen Shot 2014-04-22 at 12.42.59 AM.jpg<!-- ia0 -->[/attachment:2k2l1ejx]
                        Thanks Jeff, that makes a lot more sense now. I have one of these bounce houses already, and one thing I noticed, is that that the vertical pillars are made out of two pieces as opposed to one which you show. I know the guy who used to make these and I can ask him why it's two pieces instead of one.
                        I haven't began drawing the house. I'm still learning what each tool does in sketchup. Most video tutorials I watch about sketchup are about architectural modeling. Of course, I prefer to do the work in sketchup myself since I have other bounce houses and modeling each one is going to be an ongoing project. Besides, having someone else do it for me means extra expense I may not be able to afford, but I'm open for bids πŸ˜„
                          jumpersrfun
                          But it appears that Rhino is a windoze based program and a super expensive at that. I'm not a windoze user. Used to be, but recovered a long time ago πŸ˜„
                            Krisidious
                            I didn't say it was sketchup... But, you haven't fully recovered from being overcharged if you're using a Mac.
                            By: Kristoff Rand
                            • BoxB Offline
                              As nice as Jeff's flattened rhino is I think it might be a little overkill for what you want. Or more to the point, the sizes you are working with are too large for simple printout of templates.
                              From what I see and with no bouncy castle experience, it would appear that the majority of the the sections would be made from rectangles and cylinders. So measurements would be enough to work from for the most part. And sketchup will give you all those diameters and lengths etc easily.
                              When you have something a bit odd, like the top cone of the turret you could use the plugin "flattery" to flatten cone to get a template shape. So design to your hearts content using blocks and tubes and only a few sections would require more than simple measurements. The more fancy your design becomes the more you need to work out how to flatten the shapes to get the templates needed.
                              This is a very quick sketch, simple shapes that when inflated will become your rounded jumpy thing thing and a curtain wall and a turret that can be repeated to form the four walls, and I have used flattery to flatten the second turret top.
                                i haven't used windows in.. ever πŸ˜„
                                it's in beta on mac.. has been for a few years now.. and it's free to use
                                ERROR: The request could not be satisfied
                                (www.rhino3d.com)
                                • pbacotP Offline
                                  This all in your "free" rhino...hmmm do they have people doing architecture in Rhino?
                                  • pbacotP Offline
                                    You have to add the seams to the basic shapes--in case you haven't figured that out yet.
                                      yeah, it's pretty popular in architect world.. that's what i personally use it for but i wouldn't say I'm doing 'standard' architecture..
                                      https://www.google.com/search?q=rhino+architecture%26amp;client=safari%26amp;rls=en%26amp;tbm=isch%26amp;tbo=u%26amp;source=univ%26amp;sa=X%26amp;ei=sJZWU-rBO-7MsQSGqILoDw%26amp;ved=0CCgQsAQ%26amp;biw=1300%26amp;bih=956
                                      kinda the neat thing about rhino is that it started out as an industrial design tool.. so it's built around having incredible accuracy and smooth surfaces at crazy small tolerances so when you go in there with architecture sized objects, it easily handles anything you throw at it..
                                      mcneel is actively adopting the software to architecture specific stuff now though.. there are layouts which happen inside the app itself (though this hasn't been implemented on mac yet).. there are blocks (like su components).. built in rendering/texturing is improving.. etc.. the layer handling is great for architecture too (imo) since you can directly draw on layers.. i barely use layers in sketchup (well, i use them but only for what they're designed for- vis control).. i completely depend on them in rhino as a drawing tool.
                                      in my case, there were things i needed which sketchup couldn't do.. that's why i sought out other software as a supplement but in my case, it actually became a replacement.. if sketchup can already do what you need though and you already know how to do it in sketchup, i don't think rhino is so 'perfect' as switch over to it.. unless maybe you also like cad software from a hobby pov instead of strictly work related.. in which case, it can be pretty fun to use.
                                        jumpersrfun
                                        Boy, looks like I'm gonna have my work cut out for me! So here's a company website (link below) that I want to buy a computerized pattern cutter from in the future once I have the money and a big enough space. Here, they open a whole new can of worms by mentioning other 3D software such as Vectorworks, TouchCAD, AutoCAD, etc., lol. They also talk about a seam allowance plugin for Vectorworks. I have Vectorworks as well and I emailed them about the plugin, but is there such a plugin for sketchup?
                                        Then they talk about how I can use "Optitex to design 2D patterns, and using Runways very accurate 3D simulation, patterns are joined and inflated in the computer." I am really confused now.
                                        But most importantly, one issue which I find most disheartening is that hey emailed me a pdf document (uploaded here) in which they mention that "many of the shapes will look quite different when they are inflated." This is really frustrating. Anyone used Optitex to "inflate," as they say the the joined patterns?
                                        404 Not Found
                                        (aeronaut.org)
                                        PDF Doc
                                          Krisidious
                                          I wouldn't worry much about the seams or the difference in reality. I think you're already expecting the result they are legaleezing. Things are not going to be as sharp, turns will not be as abrupt, straight sections are going to sag. I think you're probably already expecting that. While I'm not sure how these are sewed together, I'm sure a simple offset of the pattern will allow for the meeting point.
                                          I think you're going to have to feel your way through a bit to gain that experience of what to do to get what you want. Start out with a few parts and make them then you'll get your groove on so to speak.
                                          By: Kristoff Rand
                                            driven
                                            I do make patterns for fabrics [ occasionally ], and have attempted to do it in SU, but...
                                            it's not as simple as adding seam allowances, as much as I like using it, there are limitation...
                                            That link is great,
                                            Your [ potential ] supplier is the first mac [first] hardware/software supplier for this scale of things I've come across that was affordable for my usage... give them a call, go have a chat...
                                            I'm going to look into a plugin to/from the nesting program/SU and TouchCAD/SU...
                                            that would be my ideal scenario...
