    How do I only show the outline of model?
    14 Posts 6 Posters 1.3k Views 6 Watching
    • pbacotP
      What edges do you want to show? You can also Hide edges selectively. Maybe you just want the profile of the object outlined. Turn on "Profiles" under "edge style" (view menu). Turn off "edges". Then holding the shift key, use the erase tool on all profiles still showing that you don't want to see. Or select them and use "hide" function. Might help to weld the curves for easier selection later.
      • jeff hammondJ
        you can't turn off profiles individually πŸ˜‰
        they're view dependent and aren't necessarily actual geometry..
        (for example- draw a cylinder- turn off edges - turn on profiles - try to hide a profile line)
        [EDIT- but let me try that first before i have two feet in mouth instead of just one]
        [EDIT2 - yep.. feet in mouth πŸ˜„ ..one for the d'oh thread]
        • KrisidiousK
          Krisidious
          also, sometimes lines will not soften of they are unnecessary... Try thomthom's cleanup tools to rid yourself of unneeded lines.
          By: Kristoff Rand
          • dfswyfD
            dfswyf
            Thanks guys!
            What I mean is:
            Generate a face
            If I use soften edges...
            This is what I want... If I have a very complicated modle how do I show ANY LINES that I wanna show?
            • pbacotP
              I didn't turn them off, I just hid the edges for profiles I didn't want.
              BUT yeah, I don't think you can hide those profiles that are simply rendered on a curved face. There has to be a related edge for you to hide.
              Not sure what OP is after but this may work in this case.
              • BoxB
                Turn on hidden geometry and select the lines you want to be visible and unsoften or unhide them.
                • dfswyfD
                  dfswyf
                  Yup, but that takes time to select if it is a complicated shape. Too many segments...
                  • BoxB
                    ctrl shift eraser will do it.
                    • cottyC
                      cotty
                      There's a path select tool in the SketchUV plugin that might help with the selection...
                      my SketchUp gallery
                      • pbacotP
                        There's a Pen Tool plugin where you draw the sort of edges you want. Draw over the soft edge to make it hard. How could SU know otherwise what lines you want to show and not show?
                        ThruPaint also has a function to change appearance of lines by "painting" over them.
                        • BoxB
                          And quad tools, and select curve.
                          Vertex tools even lets you lasso the lines you want.
                          • jeff hammondJ
                            Thanks guys!
                            What I mean is:
                            it's usually best to think ahead in these situations.. copy the lines when they're more selectable then paste in place once the surface is made..
                            1. perimeter curves
                            2. curviLoft's geometry options -- generate only junctions or intermediate lines (or both)
                              using curvizard (other plugins available for this) , select a segment on the curve you want and it will automatically select the rest of the segments then weld.. do that for the lines you want visible then Copy
                            3. make the surface - smooth if necessary
                            4. Paste in Place
                            • dfswyfD
                              dfswyf
                              @jeff hammond said:
                              Thanks guys!
                              What I mean is:
                              [attachment=0:18rbck4m]<!-- ia0 -->untitled.jpg<!-- ia0 -->[/attachment:18rbck4m]
                              1. perimeter curves
                              4. Paste in Place
                              Thanks Jeff, that is what I want!
