    How do I only show the outline of model?
    14 Posts 6 Posters 707 Views 6 Watching
    • dfswyfD Offline
      dfswyf
      What if the soften edges does not work?
      • pbacotP Offline
        What edges do you want to show? You can also Hide edges selectively. Maybe you just want the profile of the object outlined. Turn on "Profiles" under "edge style" (view menu). Turn off "edges". Then holding the shift key, use the erase tool on all profiles still showing that you don't want to see. Or select them and use "hide" function. Might help to weld the curves for easier selection later.
        • jeff hammondJ Offline
          you can't turn off profiles individually πŸ˜‰
          they're view dependent and aren't necessarily actual geometry..
          (for example- draw a cylinder- turn off edges - turn on profiles - try to hide a profile line)
          [EDIT- but let me try that first before i have two feet in mouth instead of just one]
          [EDIT2 - yep.. feet in mouth πŸ˜„ ..one for the d'oh thread]
          • KrisidiousK Offline
            Krisidious
            also, sometimes lines will not soften of they are unnecessary... Try thomthom's cleanup tools to rid yourself of unneeded lines.
            By: Kristoff Rand
            • dfswyfD Offline
              dfswyf
              Thanks guys!
              What I mean is:
              Generate a face
              If I use soften edges...
              This is what I want... If I have a very complicated modle how do I show ANY LINES that I wanna show?
              • pbacotP Offline
                I didn't turn them off, I just hid the edges for profiles I didn't want.
                BUT yeah, I don't think you can hide those profiles that are simply rendered on a curved face. There has to be a related edge for you to hide.
                Not sure what OP is after but this may work in this case.
                • BoxB Offline
                  Turn on hidden geometry and select the lines you want to be visible and unsoften or unhide them.
                  • dfswyfD Offline
                    dfswyf
                    Yup, but that takes time to select if it is a complicated shape. Too many segments...
                    • BoxB Offline
                      ctrl shift eraser will do it.
                      • cottyC Offline
                        cotty
                        There's a path select tool in the SketchUV plugin that might help with the selection...
                        my SketchUp gallery
                        • pbacotP Offline
                          There's a Pen Tool plugin where you draw the sort of edges you want. Draw over the soft edge to make it hard. How could SU know otherwise what lines you want to show and not show?
                          ThruPaint also has a function to change appearance of lines by "painting" over them.
                          • BoxB Offline
                            And quad tools, and select curve.
                            Vertex tools even lets you lasso the lines you want.
                              Thanks guys!
                              What I mean is:
                              it's usually best to think ahead in these situations.. copy the lines when they're more selectable then paste in place once the surface is made..
                              1. perimeter curves
                              2. curviLoft's geometry options -- generate only junctions or intermediate lines (or both)
                                using curvizard (other plugins available for this) , select a segment on the curve you want and it will automatically select the rest of the segments then weld.. do that for the lines you want visible then Copy
                              3. make the surface - smooth if necessary
                              4. Paste in Place
                              • dfswyfD Offline
                                dfswyf
                                @jeff hammond said:
                                Thanks guys!
                                What I mean is:
                                [attachment=0:18rbck4m]<!-- ia0 -->untitled.jpg<!-- ia0 -->[/attachment:18rbck4m]
                                1. perimeter curves
                                4. Paste in Place
                                Thanks Jeff, that is what I want!
