    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • mitcorbM Offline
      mitcorb
      Hi, Fredo:
      See my posting above your update announcement. I updated and then went back to the model. I got a bugsplat and sent it in. This was just an attempt to overcompensate for the bend repeatedly falling short. I measured the angle for the bend with the Sketchup protractor. The value was ~-4.475 deg. Doing the bend with the inferencing I saw ~-4.5 deg.
      What I did differently is set the center of the bend on the ground plane below the center of the standing circle and inferenced. Still got the extremity to go only ~half the distance. While attempting to correct this in the Measurement Box, the Bugsplat occurred.
      I am sure you are busy.
        tulacong
        Happy new years luna 2014
        • fredo6F Offline
          @mitcorb said:
          Hi, Fredo:
          I need to revisit the way target is inferenced in this tool, for sure. And post-edition too, as you crash may be related to the fact that, once bent, the shape becomes overly triangulated.
          It's an old plugin, and I don't even remember if there is a trick to achieve what you wish to do.
          In any case, the value of the angle in the VCB is twice the actual angle measured with the Protractor. I measured 6.382 degree with the Protractor, so you need to enter 12,75 degree in the VCB.
          I'll have a look when I have time.
          • mitcorbM Offline
            mitcorb
            Thanks, Fredo:
            This is an example of something that I have noticed from some time back. I just assumed it had something to do with the nature of 3d modeling in Sketchup, and did not pursue it until now. JQL's question resparked it while I was doodling this model. FredoBend works well enough for modeling by eye and impromptu modification. And, I really wasn't intending to be very precise, because there are other ways to achieve what I was doing.
            Thanks again for all you do.
            • H Offline
              hiroya
              good
                Mike Whitton
                I have just installed SU 2014 - I cannot get any of the Fredo 6 plugins to work. Am I doing anything wrong or are they all not yet compatible with SU 2014?
                  Did you just copy the files over from the old installation? Download fresh version of Fredo's plugins from the Plugin Store. Or better, install the SCF Plugin Store plugin and install Fredo's plugins automatically. Make sure you get the current version of LibFredo, too.
                  • V Offline
                    veerlexyz
                    Mike,
                    Turn your Sketchup off and on again. That worked for me.
                    This is what I wrote about it in the topic Sketchup 2014.
                    Libfredo6 keeps "Uninstalled" in the list "My Extensions" in "Extension Warehouse" although it is working. I could not install it with the Extension Warehouse but used the .rbz file instead. Same with Fredo Scale and Fredo Tools. These ones were not visible in Sketchup untill I turned the programm off and on again. Although they stay marked "Uninstalled" in "Extension Warehouse" the plugins do work fine.
                    My other plugins seem to work. Not done them all...
                    Veerle
                      dacastror
                      The tools in this plugin having to modify geometry, causing "bugs plats" in one instance with instances nested inside, works well when the tool only affects axes
                      I understand that exploiting all interior groups solved the problem, but would be good if the user had some kind of warning
                      I'm using the latest version of this plugin in Sketchup 8 (Spanish version)
                      I attached a file as an example of a group that can cause problems
                      grupos.skp
                      forgive errors of translation (google translator)
                        What a strange way of grouping things. It makes no sense.
                        Still, I'm not having any difficulty modifying it with FredoScale. Maybe you could show what you are trying to achieve?
                          dacastror
                          Dave tries to use "radial bend" (for example) on the largest group
                            Like this?
                            I see what you mean about the Bug Splat but after I gave it a logical grouping it works just fine. I expect it's caused by your strange method of grouping.
                              dacastror
                              right now I'm not designing something, I'm just writing a plugin and discovered this bug by chance
                              I think that could be a problem related to the issue that are not "unique groups" and are nested
                                joonnyy
                                Hello
                                I have installed SU 2014. I installed via the / install extensions / / Fredo6_! LibFredo6 - v5.7 - 15 Feb 14.rbz / a plugin / Fredo6_FredoScale - v2.6b - 05 Feb 14.rbz /
                                When I run SU 2014 I got a critical alert / LibFredo6 will be updated at next startup of Sketchup / when I click OK appears critical window / load errors /
                                Error loading file Fredo6_FredoScale.rb
                                Error: # <NameError: UNINITIALIZED constant Fredo6::Traductor>
                                C 😕 Users / Jan / AppData / Roaming / SketchUp / SketchUp 2014/SketchUp/Plugins/Fredo6_FredoScale.rb: 41: in <module:Fredo6> ' C :/ Users / Jan / AppData / Roaming / SketchUp / SketchUp 2014/SketchUp/Plugins/Fredo6_FredoScale.rb: 25: in <top (required)> '
                                Where I make mistakes when installing? Thanks
                                • bmikeB Offline
                                  bmike
                                  @dave r said:
                                  [attachment=3:lp5xixsu]<!-- ia3 -->Screenshot - 3_28_2014 , 8_50_20 PM.png<!-- ia3 -->[/attachment:lp5xixsu]
                                  [attachment=2:lp5xixsu]<!-- ia2 -->Screenshot - 3_28_2014 , 8_54_11 PM.png<!-- ia2 -->[/attachment:lp5xixsu]
                                  Like this?
                                  I used this plugin on an entire house - windows, doors, walls, compound roof, etc. etc.
                                  I crashed and crashed - until I started to pull apart the model into logical groups.
                                  After I figured that out - it worked perfectly.
                                  To solve a 'bending' a large model - draw an origin, and a line. Now take apart the model in logical groups (all the windows, all the doors, the walls, etc. etc.
                                  Copy / Paste in place into a new drawing the group of objects, and the origin and scale line.
                                  Group everything, FredoScale Bend.
                                  Copy / Paste in place into a new drawing.
                                  Repeat, but always paste the bent components in place together, in that new 'bent' drawing.
                                  It let me take this:
                                  [attachment=1:lp5xixsu]<!-- ia1 -->Screen Shot 2014-06-13 at 11.43.55 AM.png<!-- ia1 -->[/attachment:lp5xixsu]
                                  To this:
                                  [attachment=0:lp5xixsu]<!-- ia0 -->Screen Shot 2014-06-13 at 11.43.44 AM.png<!-- ia0 -->[/attachment:lp5xixsu]
                                  • N Offline
                                    numerobis
                                    Would it be possible to add a scale option for scaling around the base point of a group/component? And another one for scaling multiple groups/components based on their local origin? (as it works in max for instance)
                                    • fredo6F Offline
                                      What is the base point exactly? Currently FredoScale uses the center of the bounding box.
                                      This would be a different plugin, but I think there exists already one doing this.
                                        Scale rotate multiple by Chris Fullmer 😉
                                        • N Offline
                                          numerobis
                                          I meant the origin of the component
                                          Why wouldn't it be possible to have this as another option beside the normal scaling and the uniform scaling around the center (strg)?
                                          Yes, this works for uniform scaling, but it doesn't support scaling in one direction or did i miss something? And it is not interactive, you have to put in numerical values.
                                          • fredo6F Offline
                                            NEW RELEASE: FredoScale v2.7a - 19 Oct 14
                                            FredoScale 2.7a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                            FredoScale 2.7 requires LibFredo6 6.3 or higher.
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 56
                                            • 57
                                            • 47 / 57
