    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • SolarwiseLLCS Offline
      SolarwiseLLC
      @jiminy-billy-bob said:
      Of course, LP should behave normally after this. It's a fresh start.
      After resetting the folders as you outlined. I was able to regroup and work in the file successfully. After closing SU and restarting my computer, the layers panel stop being responsive in that file. After working in the same file, using just the layers window, the layers panel reset the folders/grouping by itself. Once it reset itself, the layers panel worked, but the folders/grouping were deleted. Wondering if it's the plugin or my file.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        I'm investigating with the file you gave me. This is weird.
        Do you actively use Didier's Layers Manager, or is it just installed?
        To you import geometry, or copy/paste between instances?
          SolarwiseLLC
          I do actively use the Didler's Layer Manager. When transferring geometry, I usually copy and paste.
            amis
            Hi, Jiminy! There's a problem when I use cyrillic font to rename new layer - some codes appear instead of cyrillic letters. Although it didn't happen before (win XP, SU 2013) Got any ideas?
              amis
              amis > You're not the first to tell me this. I forgot, thanks to remind me, I'll take a loot at it.
              So if I understand right, it works fine on winXP with SU2014, what is yout windows version now, and SU version?
              we didn't understand each other properly) Win XP, SU 2013 that's for now
                jiminy-billy-bob
                New version 1.0.4 !
                Changelog :
                • Added better feedback when sorting multiple layers/groups at once
                • Added support for Podium V2+
                • Fixed support for Indigo
                Download in the plugin store !
                • kenK Offline
                  ken
                  @tt_su said:
                  @sadyo said:
                  Seem like the LP 1.0.3 have problems when I updated TT_Lib 2.9.9 ❓
                  That's a co-incidence. When you launch SketchUp via a SKP file that is located on a drive different from where SketchUp is installed something gets messed up in SketchUp Ruby. Launch SketchUp first, then open your file - that's the workaround until we release a fix.
                  I open Sketchup files on my travel USB HD from XnView all the time. So are you telling me, the safest way to open Sketchup files is from Sketchup and not a viewer?
                  IF so, this could explain a lot.
                  Thanks for your reply.
                  Ken
                  • tt_suT Offline
                    tt_su
                    Yes, if you use plugins then until we get the fix released you're better of starting SketchUp first, then open the files from SketchUp. Apologies for the inconvenience.
                      jiminy-billy-bob
                      Do you have an ETA for the fixed release?
                      • tt_suT Offline
                        tt_su
                        Afraid not. WIP.
                          jiminy-billy-bob
                          Layers Panel reached 300 unique daily users
                          (as far as I can see, there are probably more if there are multiple users on a single IP adress)
                          A big thanks to all of you to motivate me pushing this plugin further and further! πŸ˜„
                          It wouldn't be what it is today if not thanks to all your feedback and ideas.
                          http://i.imgur.com/55yXgRP.png
                          • Bob JamesB Offline
                            Bob James
                            I still cannot undo without this appearing keeping the undo from happening:
                            Undo Layers Panel ID
                              jiminy-billy-bob
                              Every time you undo?
                                SolarwiseLLC
                                I installed v1.0.4. and I am getting the same results of unresponsiveness. I went through and organised everything and after saving, closing the file and restarting it, it became unresponsive. I have reorganized my layers so many times without them staying active and/or organised that I am about to give up on your layers panel for this drawing.
                                  Bob James
                                  Ctrl-z or Alt-backspace
                                  Have to repeat many times before undo happens: most times undo never happens.
                                  What's more, sometimes undo does work. πŸ˜’
                                    jiminy-billy-bob
                                    I may have found what's causing this issue. Not 100% sure, though.
                                    I'll release the fix soon.
                                    Hmm, so not every time? Do you know in which case it doesn't happen? Or in which case it happens?
                                    Does it happen in every file?
                                      jiminy-billy-bob
                                      New version 1.0.5 !
                                      Changelog :
                                      • Fixed major issues that would freeze Layers Panel, or delete every groups
                                      • Added API for rendering
                                        Bob James
                                        For large files (e.g., >100MB): Yes, but not on every attempt to undo!!
                                          jiminy-billy-bob
                                          Could you send me one of those files? (Maybe delete the geometry, if this doesn't affect the behaviour)
                                          • gullfoG Offline
                                            gullfo
                                            also noted: when i first loaded the latest version, i got an error about id being incorrect and used the "fix" link provided. that seemed ok, but then i noticed that the name-order of the layers is wrong - about 1/2 are ok, and 1/2 are not - i was assuming the order of the layers follows the regular layer when first initialized? an ability to sort the layers by name or groups would be handy β˜€
                                            otherwise it seems like i would manually need to re-order them...
                                            Glenn
                                            http://www.runnel.com
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 33
                                            • 34
                                            • 24 / 34
